help, the spring things on the calipers are comming off - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-17-2006, 12:44 PM   #1
bryanjw82
bryanjw82's Avatar
Fan#: 222
What I Drive: 2004 Chevy Avalanche
FF Reputation: 1 bryanjw82 Good Standing Member
those wire spring type things that fit on the front caliper's are comming off, i put them back on after i did the ebc rotor and ebc brake pad change, put they are comming off and only on by one side. Are these things necessary anyway? I do alot of driving as i do pizza delivery right now, should i worry about these? i drove that way last night ok, let me know soo as possible thanks.
Performance Mods: FC short shifter, Magnaflow exhaust, HEI wrapped svt header, BBK TB, orp, MSD coil & wires, Diablo Tuner, VF engineering rear engine mount, EBC slotted and dimpled rotors f&r, EBC green stuff pads, PowerWorks Supercharged
bryanjw82 is offline
Old 01-17-2006, 02:32 PM   #2
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
They are necessary. They keep the pads from rubbing on the rotors when you're not using the brakes.
Geezer is offline
Old 01-17-2006, 02:37 PM   #3
Zach16789
Fan#: 1790
What I Drive: 2000 Pitch Black ZX3
FF Reputation: 1 Zach16789 Good Standing Member
Yeah the retaining clips I believe, some place installed mine wrong one time and needless to say I needed new stuff. I went with them like that way to long, mainly because I don't mess with my brakes in the winter to much, but I would go get em fixed.
Zach16789 is offline
Old 01-17-2006, 05:18 PM   #4
bryanjw82
bryanjw82's Avatar
Fan#: 222
that blows, can i get new clips from the dealer? because it might be because i bent the hell out of one of them and it doesn't stay in right?
Old 01-18-2006, 10:15 AM   #5
Geezer
Fan#: 1427
Be careful for what you ask for...there are clips and springs. The retention clips are inset in the caliper and go over the ends of the pads (lock and center the pads). I believe the correct name of the springs are tension or retractor springs ..... you can also call them the "wire spring things that go over the caliper" and they'll know what your referring to. Yes, the dealer will have them but you might want to check NAPA first.
Geezer is offline
Old 01-18-2006, 12:30 PM   #6
digitalvoid
Fan#: 31312
What I Drive: 2002 black ZX3
FF Reputation: 1 digitalvoid Good Standing Member
Re: help, the spring things on the calipers are comming off
Aren't they part of the pad? I just put replacement pads and those springs came as part of the pads? Mine were fairly tight so it took a bit of force to get them up and over the tabs on the calipers and short of prying them back over with a screw driver or something I can't imagine how they would be "coming off".
http://www.focussport.com/images/brakepads.gif
Perhaps you didn't push them all the way over the tips of the calipers? They go over and around and really secure the pad into the caliper and keep it from rattling off.
http://www.edmunds.com/media/roadtes...tupict.500.jpg
digitalvoid is offline
Old 01-19-2006, 10:12 PM   #7
bryanjw82
bryanjw82's Avatar
Fan#: 222
i seemed to get it back on and its seems secure, right now. I will take a pic to make sure you know what i mean. But its that odd shaped metal wire thing that goes into the holes of the caliper and is real tight to get on. Looks like a metal hanger bent to a certain form to fit.
Old 01-19-2006, 10:22 PM   #8
Gachi
Fan#: 26838
What I Drive: 03 ZX5 Focus / 96 GMC Jimmy
FF Reputation: 1 Gachi Good Standing Member
If it's what I'm thinking about, they normally come as part of the pads and they hold the one pad snug against the caliper, and the other just has clips of some sort that hold it inside the piston.
Gachi is offline
Old 01-20-2006, 05:14 PM   #9
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Maybe this will help? ...>>>Brake Caliper Clip...
WD40 is offline
