A/C and power steering delete, need help on belt size - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-15-2006, 11:24 PM   #1
zGOTxBOOST2
Fan#: 18787
What I Drive: 1999 Ford ZX2
FF Reputation: 1 zGOTxBOOST2 Good Standing Member
I am doing weight reduction.
I have already delete the A/c and simply added a pulley in the compressors place.
I have recently came acrossed a way to by-pass both units with re-routing the belts and using a smaller belt.
Thats where I need your help. I have the F/C UDP kit whick uses the STOCK belt due to the bigger water pump pulley.
That being said, I need to find the smaller belt size to re-rout the belt to bypass the a/c compressor AND the power steering pump.
As always Thank you for your help with the NOob :fathand:
z to the x to the 2
zGOTxBOOST2 is offline
Old 01-15-2006, 11:29 PM   #2
zGOTxBOOST2
Fan#: 18787
Where the GREEN lines are, disregaurd the REd lines and arrows.
z to the x to the 2
Old 01-16-2006, 01:09 PM   #3
peanuts_parts
Fan#: 31185
What I Drive: a car
FF Reputation: 1 peanuts_parts Good Standing Member
like i told u on teamZX2.com Lose the FC water pump pulley and go with the belt i have for sale or geta new one. if u don't want to lose the FC waterpump pulley, just get a 49" belt. Go to ur local part store, and ask them for a 49" sepertine belt.
Before u do this, i want to worn u it's a lot of work. I took me a total of 2 days. and u still have to find that manual rack and pinion.
peanuts_parts is offline
Old 01-17-2006, 01:45 AM   #4
peanuts_parts
Fan#: 31185
What I Drive: a car
Sorry I'm wrong, keep the FC water pump pulley
Old 01-17-2006, 05:35 PM   #5
ozan
ozan's Avatar
Fan#: 29069
What I Drive: 2006 ink blue Mondeo TDCI
FF Reputation: 5 ozan Good Standing Member
i also asked AC deleting a week ago but there were no satisfying replies.. and i see that it is the best way to put a pulley instead of AC comp. pulley. so how much does the AC weigh? i am also thinking about AC deleting but i am not sure if it will worth or not...
ozan is offline
Old 01-17-2006, 11:10 PM   #6
zGOTxBOOST2
Fan#: 18787
40 lbs, I may have a a/c delete pulley for sale .
Just need to figure this out first
z to the x to the 2
Old 01-18-2006, 05:51 PM   #7
ozan
ozan's Avatar
Fan#: 29069
40lbs?? ohhh it really worth removing... i want to ask another thing.. when you are re-routing the belt, the length of belt around the crank pulley ( i meant the length of friction surface around the crank) reduced nearly 1/3 ... does it couse any problem ?? like cousing the belt slipping around the crank???
ozan is offline
Old 01-23-2006, 07:47 PM   #8
zGOTxBOOST2
Fan#: 18787
According tot he Zx2 peeps who HAVE done it, have no problems and drive there cars daily, talk to peanutsparts. I am removing P/S pump AND A/C wich is probably about 75lbs or so.
But this ISN'T comforatable for daily driving :(
Lighter For RACE :)
z to the x to the 2
Old 01-23-2006, 07:48 PM   #9
zGOTxBOOST2
Fan#: 18787
just help me find the perfect belt, so far its looking like a 43" belt.....
z to the x to the 2
Old 01-23-2006, 07:50 PM   #10
zGOTxBOOST2
Fan#: 18787
Peanut, what belt did you use when you had afx and ODP? Myn should be VERY close to that set-up due to the bigger alternator pulley you had .
z to the x to the 2
