Engine & Transmission Swap The place to chat about any engine and transmission swap.
#1 | ||||
SVT tranny on my zx3
will a svt tranny and maybe axles fit on my 2.3 duratec (2003 zx3)? I can get one and I think it would be savage
Remove Advertisements |
Fan#: 1
#2 | ||||
I'm not sure if the duratec has the same bellhousing bolt pattern as the zetec. do some research. if it's the same bolt pattern, then yes, you can bolt it in.
#3 | ||||
Oh yeah!
Just curious, why do you want one? If your car isn't putting out a lot of power, it's going to make your Focus feel even slower since the gears are taller. The stock 5-spd is sufficient for everyday driving and autocross.
#4 | ||||
I wouldn't say the Getrag would make it 'slower'. It will make the launches slower (bad for quarter mile), but you'll keep the revs up better with the Getrag (better for road courses). IMO, it isn't worth swapping the mtx75 for the Getrag. You'll be better off swapping the SVT engine and tranny.
Give the toughest job to the laziest man and he'll find the easiest way to get it done. |
#5 | ||||
Oh yeah!
Unless you're running the car as a track car specifically, you'll almost never use the 5th or 6th gear of the Getrag for racing. The 5-speed should be geared a little lower than the Getrag (and not just in first), which will ultimately make the car accelerate faster since the gearing is better. If the Getrag can reach 40mph in first and 70mph in second, what do you need four more gears for when the power of the car cannot even push it fast enough to utilize the gearing of the six speed? The shorter gears of the 5-speed make it easier for the engine to accelerate the car than the taller gears of the six speed, which will in turn make the car faster or slower. Fifth gear is an economy gear in a sense. Even though it may be lower than the Getrag's final gear, it doesn't mean all gears are lower. It was most likely geared for fuel economy. Don't forget that the RS Focus uses the 5-speed as well, and I will bet Cosworth didn't just forget about that component when tuning the RS.
I'll say this, on an autocross course, I think the MTX-75 transmission would be better. On a race track, the Getrag would probably be better. You just don't really utilize the effectiveness of the Getrag until you've built substantial speed. I would agree about an engine swap with the transmission. The Getrag is geared for the Zetec (even though it is too tall, the gearing is set up to hit certain points in the powerband), which would probably make the Duratec feel out of its powerband or oddly placed at times. We need to get the gear ratios for the MTX-75 and a dyno graph on the Duratec to see how well the two would or would not work if mated together. That would give us a better answer than sort of guessing as to how well it will or won't perform. |
#6 | ||||
I think you need to consider your RPM redline as well. The SVT has a 7200 RPM redline stock and if I'm not mistaken the Getrag is geared to take advantage of the higher RPM levels of the SVT and I don't think the 2.3 could make full use of that gearing. Just a thought.
04‘ SVTF #204 of 1978 SVT Squad #66 Understeer scares the driver, oversteer scares the passenger. |
| Thread Tools | |
| Display Modes | |
