The proper turn? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Autocross Racing
Autocross Racing The place to discuss information about autocross stats, tips and events. Track sanctioned events only.
Old 12-12-2005, 06:51 PM   #1
AllredEInUse21
AllredEInUse21's Avatar
Fan#: 30203
What I Drive: 2000 Sony Ed. Sedan
FF Reputation: 1 AllredEInUse21 Good Standing Member
The proper turn?
Im looking into autocross next year and Im interested in your comments how how to make a conistant clean turn. You can give all you examples and im sure there are bunch of different ways. This is my first standard car and ive only driven it a few months now. Im also just wondering a good technique on some twisty roads and what not. Im more interested in the shifting, clutch, wheel turn, and speed. I know there are diferent ways of downshifting like heal-toe and Im not looking for a slide because im not a rally driver with a proper e-brake. However fun in the winter, but thats still tricky now that I have to shift im so use to my dodge stratus auto. ANy tips appreciated.
AllredEInUse21 is offline
Old 12-12-2005, 09:06 PM   #2
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
The 5 cent lecture:
Its all about the tire friction circle. The tire can only give 100% of its traction before it starts slipping. If you are accelerating at the tire's limit, you can't steer. Same goes for braking. Similiarly, if 100% of the traction is going to steering, you can't use any brakes or gas.
This says bike, but its the same for a car:
For now, think of a standard apex corner, where the apex is in the center of the turn. (green line)
As you approach the corner, you will want to go hard into the brakes. Then as you start to turn, you want to ease out of the brakes. The more you turn the less you brake, until you aren't braking anymore, and devoting all your traction to turning. This should be near the apex. Then after you pass the apex, you want to start unwinding the steering and slowly apply the gas. The straighter the wheel, the more gas you can provide, until you are fully back on the gas.
Then there is late apexing and early apexing. You don't want to think of doing early apexing. (has special uses). Late apexing is safer, and usually taught to start out on.
If you really want to learn more, I suggest you sign up for a HPDE with NASA. They will teach you all this, and give you 3-4 hours of on-track experience learning all of this. It is much much safer than on the street. You never know what is going to happen on the street.
January 2008 Focus Fanatics ROTM
2003 Ford Focus ZX3 2.3l N/A = 221 HP, 162 ft-lbs, 13.967@100.88MPH
2006 Ford Fusion 2.3l Turbo = 244HP, 247ft-lbs
duratec.wikispaces.com - Duratec Wiki - Sign up and contribute!
Egz is offline
Old 12-12-2005, 10:12 PM   #3
AllredEInUse21
Fan#: 30203
thanks for the info, I also need some on clutch and shifting tips.
Old 12-12-2005, 11:30 PM   #4
PizZel
PizZel's Avatar
Fan#: 488
What I Drive: Turbo'd 03 CD Silver SVT
FF Reputation: 1 PizZel Good Standing Member
PRACTICE, PRACTICE, PRACTICE!!!!!!!!!!!!!!!!!
Thats the BEST advice I can give you is take it to a track and find what works best for you and your car. We can tell you how to drive till were blue in the face, but it can only help so much. It all comes down to YOU! Get out there and have some fun!
205whp 179tq @ 7psi
"Always do sober what you said you‘d do drunk. That will teach you to keep your mouth shut."
PizZel is offline
Old 12-13-2005, 04:22 AM   #5
Oni
Oh yeah!
Oni's Avatar
Fan#: 24899
What I Drive: An unloved Focus
FF Reputation: 4 Oni Good Standing Member
Buy-Sell-Trade Rating: (6)
Always start out slow and progressively become faster and find the limits of your car and tires. Second, I would suggest to have someone who's fairly experienced ride with you to give some pointers and techniques. Third, do what Ravage just said - practice. Like all things in life, that's about the only way to get better.
As far as learning proper braking points, turn-in points, and different techniques for different corners and obstacles, the best suggestion I can make if you don't have the means (say a nice road where you can safely learn to drive through a corner), pick up a game like Gran Turismo 3 or 4 for the Playstation 2 and go through the license tests. Commence laughing at me now, but it's a great way to learn driving techniques from different corners - like slaloms, esses, and hairpins.
As far as shifting and the clutch, be nice to your clutch. If you're just looking in getting into autocross, most courses only require you to shift from first to second. You'll spend the remainder of the course in second gear, so there's not much shifting technique involved. Also, they have a short roll out before you trigger the timer for your autocross run, so there's no need to be abusive on the clutch.
SVT Squad #80
1365 of 3985
Born: 04/25/2003
formerly known as the member ilcowil
Oni is offline
Old 12-13-2005, 04:37 AM   #6
FocusInAlaska
FocusInAlaska's Avatar
Fan#: 18038
What I Drive: 2004 Ford Comp. Orange SVT Focus
FF Reputation: 5 FocusInAlaska Good Standing Member
For driving in the twisties being able to down shift as you approach a corner is important. Knowing how many rpm's to pick up when you push the clutch in and move the shifter to a lower gear is key. This is something you can get a feel for by practicing as you approach stops or slow down on exit ramps. Ideally you'll make a quick stab at the throttle, bring your engines up several hundred rpm's. When you quickly let out the clutch and there is no driveline shock you've got it down. You can contiue deaccelerating under engine compression, or be in the right gear for accelerating. I like to corner at around 5k rpm.
04 SVT Focus
"lunch box" muffler delete
15.35 @89mph, 2.29 60', 9.90 1/8 (100% stock)
FocusInAlaska is offline
Old 12-13-2005, 05:03 AM   #7
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,557, Level 100
Points: 138,557, Level: 100 Points: 138,557, Level: 100 Points: 138,557, Level: 100
Level Up 0% Completed
Forum Activity 60%
Activity: 60% Activity: 60% Activity: 60%
Buy-Sell-Trade Rating: (11)
Just practice but don't practice with other cars around or in neighborhoods you'll kill someone or your self just take it easy go slow around turns and slowy increase the speed at which you enter you will start to feel the car and whats its doing oh crap just listen to everybody here.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 12-13-2005, 12:50 PM   #8
Carrera26
Carrera26's Avatar
Fan#: 12237
What I Drive: 2005 Mazda3 2.3/2003 VW Passat GLX
FF Reputation: 2 Carrera26 Good Standing Member
3 BIG tips that will help you more than anything.
LOOK AHEAD!!! This is probably the most important technique there is. The vast majority of people look just a few feet ahead of them, and that tendency increases with speed. That's a very bad thing though, because when you're focussing on turn 1 you're making a 100% charge at that corner, and not seeing where you need to go when you get there. It's not just about taking that corner at the fastest possible speed, but lining up for what comes next. Let's take this graphic as an example.
The red and yellow lines are the incorrect lines, but are one's many people take, simply because they aren't looking ahead.
With the red line, the driver is probably staring right at the inside of the corner, charging full speed at it. When he gets there, though, he looks up and realizes that he isn't pointed at near where he wants to be, and to get going he'll have to brake and lose a ton of momentum. He'll get to that corner .3 seconds faster, but he'll get to the next one 3 full seconds slower.
The driver on the yellow line probably has their eyes glued to the tarmac right in front of them, concentrating on keeping his/her speeding car straight and on track. By the time they reach the corner and look up, it's too late. They again have to scrub off a ton of speed just to get turned into the corner and get going to the next one. Not as bad as the red line, but they are still far behind the wise Mr. Green Line. This is, by the way, the most common way people take corners.
The good driver on the green line, let's call him Carrera26 , knows to start looking at the next turn way back on the straight. Not only that, but he's looking at the straight coming after the turn. Because he sees it early, he can see with great accuracy where he is going to have to start turning, and how much he'll have to turn in to make it through the turn with the least possible steering applied. Referring back the friction circle, he can maximize his braking and acceleration the entire time because he is keeping his cornering forces to a minimum. He'll know to slow down enough that he will be able to carve a single shallow arc through the corner, and not only come out of it with the highest speed, but also with the greatest ability to accelerate. And by the time he is close to the turn, he has already seen what the right line is, so he doesn't have to pay the corner any more mind. It's already taken care of, as he made that decision back on the straight. Now he's keeping an eye on the outside edge of the track to make sure his left wheels stay on the tarmac, and then down to the next turn. I would say by the time he reaches the apex, he's already looking down track to the next corner.
Never look where you are, or where you will be in just a second or two. Especially on track, you're going so fast that no matter what you see there, you won't be able to do a damn thing about it anyway so what use is it? Every time you are in a turn you should be looking at the next turn or even 2-3 turns ahead at the AutoX.
This is especially important on tighter courses or sections. Let's say you have the turn in the picture, and then a sharp left at the end. If you are looking ahead, you will already know that you need to be on the right of the track in time to set up for that turn. If you are looking right in front of you, you might get that first turn OK, but now you are screwed for the second turn. And in fighting to get back in line for turn 2, you'll not only lose time but probably screw yourself for turn 3, and so on and so forth.
You push your successes and failiures ahead of you. When you biff one turn, you probably screwed the next 2 or 3 turns as well. So if you do end up missing something, don't try to rush and make up time, because it'll just lose you even more. Calm down and get the next one as right as you can, and you'll be right back to where you should be.
BE IN YOUR EXIT GEAR GOING IN Turning is delicate and tough enough without having to worry about shifting at the same time, not to mention doing so will throw your balance off. If you are going to need 1st gear coming out of the turn, get into 1st before you get there. Do it while you're heading straight(ish), while you have a little time to slow down and do it right and sure. You might sacrifice .2 or .3 seconds because you get there slower, but like the turns, you'll lose 1 or 2 full seconds if you come out of the turn at 2500 RPM in 2nd gear with no power and taking a half second to shift when you could be accelerating. Often, in your rush, you'll miss the gear entirely and really screw the pooch. Many times, shifting at all takes so much time and concentration away that you shouldn't even worry about it. My instructor did one run at the AutoX School in 1st with a ton of power (and wheelspin) and shifted a couple times. Then he ran it again, short shifting to 2nd right away. Felt a ton slower, but he cut 1.2 seconds off his time on a 30 second course. He's a professional instructor, so he can shift with the best of them and was going 100% both times, and 1.2 seconds is huge. Without taking time to shift and worrying about wheelspin, he did massively better.
LOOK AHEAD Umm, did I mention how important this is?!?! Seriously, everything will become simple and easy if you are looking ahead right. When I did it right, it honestly felt like the course just melted away. Even though I hadn't looked at a single turn I went through for several seconds, I never touched a single cone. I could see exactly how fast I needed to go, when to turn, how sharp to turn, where I could go fast, where I needed to go slow, etc. etc. etc. The whole thing stopped being such a mystery, and it became obvious what I needed to do.
Don't waste another minute waiting on parts, or anything else. Just get out there and start racing! You will suck at first, and you will be slower than many other cars, but the only thing you will regret is not starting earlier...
Carrera26 is offline
Old 12-13-2005, 01:12 PM   #9
Algorhythm
Fan#: 20623
What I Drive: 2005 ZX3, 2004 Kawasaki ZX6R 636
FF Reputation: 105 Algorhythm Excellent Standing Member Algorhythm Excellent Standing Member
Buy-Sell-Trade Rating: (17)
^ GREAT post. Thanks. I'll read it tonight.
Algorhythm is offline
Old 12-13-2005, 03:28 PM   #10
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
Incorrect for the perfect line, but both have their uses. Especially with traffic, passing, and oh-shit situations.
But for ideal cornering, green is the fastest.
Egz is offline
