Battery Light - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-16-2003, 01:13 PM   #1
fiupntballr
Fan#: 781
FF Reputation: 1 fiupntballr Good Standing Member
Unhappy Battery Light
Has anyone had an issue on battery light turning on?
I have had mine turn on a couple of times ( I just got the car on Tuesday)
and I brought it back on monday where they checked it out and said there is
nothing wrong with it.
Does anybody have any info on this?
Concerned new SVTF owner.
Emilio
'03 Focus 5dr SVT
CD Silver Red Int.
HID Light, Audiophile
fiupntballr is offline
Old 09-16-2003, 01:20 PM   #2
ElliSVT
ElliSVT's Avatar
Fan#: 540
Location: Vancouver (not B.C.) , Washington (not D.C.), WA
What I Drive: '03 SVTF w/EAP
FF Reputation: 1 ElliSVT Good Standing Member
I have about 1400 miles on mine, just recently had that happen. The first time, it came on while approaching a stoplight but was only on for about a second. The second happened when coasting to a stop at the exit to a parking lot. The second time, it completely died but had no problem restarting. Could being near power lines cause this sort of phenomena? There were powelines along the road both times. If it persists, I will take it in and have it checked out, although it desn't sound like that would accomplish anything.
HAVE: Competition Orange '03 SVTF w/EAP #1194 of 3985 -- THIS CAR ROCKS!!
HAD: CD Silver '03 SVT Focus w/EAP - Build #2144/3985 -- THIS CAR ROCKED!!-may she R.I.P. -Dec 17, 2003
Click here to see some pics!
ElliSVT is offline
Old 09-16-2003, 01:37 PM   #3
fiupntballr
Fan#: 781
Thanks
My run ins have had nothing to do with power lines.
And I would imagine that would not be the case.
I have found in some forums that there is a bade ECU
program that can cause this.
I may have to bring it back tomorrow.
Emilio
'03 Focus 5dr SVT
CD Silver Red Int.
Old 09-16-2003, 03:53 PM   #4
jonnyq
Fan#: 165
What I Drive: 73 Midget, 03 SVTF
FF Reputation: 1 jonnyq Good Standing Member
I have experienced this, which for me happens pretty regularly when I am on the brake and clutch at the same time. The program that fixes it is supposedly RLA7, which should be out in 2-4 weeks.
jonnyq is offline
Old 09-16-2003, 04:37 PM   #5
ElliSVT
ElliSVT's Avatar
Fan#: 540
Thanks for the heads-up. I am anxious to see if the new flash fixes the problem.
ElliSVT is offline
Old 09-18-2003, 07:45 AM   #6
mchedd
Fan#: 390
What I Drive: '02 SVTF #4241
Points 184, Level 3
Points: 184, Level: 3 Points: 184, Level: 3 Points: 184, Level: 3
Level Up 68% Completed
FF Reputation: 1 mchedd Good Standing Member
There's a TSB out already to resolve the battery light problem:
03-06-07 DRIVEABILITY - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED - DIAGNOSTIC TROUBLES CODES (DTCS) P1381/P0011 AND/OR P1383/P0012 - ROUGH IDLE, REDUCED POWER CONDITION, AND/OR STALL AT IDLE - FOCUS SVT MODEL ONLY
ISSUE:
Some SVT Focus vehicles may exhibit the Malfunction Indicator Lamp (MIL) illuminated with Diagnostic Troubles codes (DTCs) P1381/P0011 Variable Cam Timing over-advanced (Bank 1) and/or P1383/P0012 Variable Cam Timing over-retarded (Bank 1) stored in memory. The vehicle may also exhibit a rough idle, reduced power condition, and/or stall at idle. This may be caused by:
· Variable Camshaft Timing (VCT) control system stuck
· Intake camshaft CMP trigger wheel mis-positioned or loose
· Engine Cam timing incorrect
· Electrical conditions
ACTION:
Refer to the following Service Procedure to verify the Cam Timing, Intake Camshaft CMP Trigger wheel position, and VCT solenoid operation, then service as necessary.
The VCT Solenoid under the valve cover is causing the small oil leak there. I think dealerships are replacing the rubber seal on the VCT solenoid, or maybe they’re replacing the solenoid itself.
I had this TSB installed and haven't had a problem since.
Mike
'02 SVTF #4241
mchedd is offline
Similar Threads
Ford Focus: Bulb Sizes hotfocus MK1 Focus 2 10-17-2007 11:09 AM
Battery light on at idle... SVTbrit General Technical Chat 4 12-08-2005 12:22 PM
battery light and ground problems natdog General Technical Chat 0 01-19-2005 11:36 AM
Battery Light mr.squatch General Technical Chat 2 06-25-2004 08:15 AM
Battery Light? Lil PZEV Ford Focus & General Car Chat 1 09-21-2003 01:17 PM
