Mazdaspeed 6 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Discussions > Ford Focus & General Car Chat
Old 12-06-2005, 01:53 PM   #1
technyne
Fan#: 4422
What I Drive: 2003 InfraRED SVTF | Build 429 of 3985 | Born 3-6-2003
FF Reputation: 1 technyne Good Standing Member
Mazdaspeed 6 - Pictures!!
Check out this years Mazdaspeed selection, seems like a pretty kick ass car!! 2.3Turbo (Duratec?) All-Wheel Drive and every other option you could want. A little pricey but Im sure that can be heckled down.
Engine type 2.3L DOHC 16-valve Inline-4 with turbo
Horsepower (SAE net) 274 @ 5500 rpm*
Torque, (lb-ft, SAE net) 280 @ 3000 rpm
Redline 6700 rpm
Displacement (cubic inches) 137.9
Bore x stroke (inches) 3.44 x 3.70
Compression ratio 9.5:1
Fuel system Direct injection
Recommended fuel 93 octane*
Minimum fuel requirement Premium*
Valvetrain 4 valves per cylinder, mechanical lifters
Engine block Aluminum alloy
Cylinder heads Aluminum alloy
Emission control 3-way catalytic converter
Ignition system Full transistor breakerless electronic
Alternator 12V-110AH
Battery 55D23L
Starter 12V-1.4kw
Type All-Wheel Drive (AWD)
Transmissions 6-speed manual
Clutch type Single dry plate with diaphragm spring
Transmission ratios (:1) 1st 3.538
2nd 2.238
3rd 1.535
4th 1.171
5th 1.085
6th 0.853
Reverse 3.831
Final Drive 1st - 4th 3.941
5th, 6th, Rev. 3.350
Body type 5-passenger, monocoque unit
4-door sedan
Front suspension Independent, high-mount double wishbones, coil springs, and stabilizer bar
Rear suspension Independent, E-type multi-link, coil springs,
and stabilizer bar
Shock absorbers Front Cylindrical, double-acting, twin tube
Rear Cylindrical, double-acting, mono tube
Steering type Rack-and-pinion
Power assist Engine-rpm sensitive; variable power-assist
Overall steering ratio 16.1:1
Steering wheel turns-to-Lock 2.6
Turning circle, curb-to-curb (feet) 36.8
Braking system Power assist; 4-wheel, 4-sensor, 3-channel Anti-Lock Brake System with Electronic Brakeforce Distribution
Brake discs Front Ventilated discs (12.6 x 1.0 inches)
Rear Solid discs (12.4 x 0.4 inches)
Parking brake Mechanical, hand-operated on rear wheels
Tires P215/45R18 93Y summer radials
Tire Inflation Pressure (front/rear) 37.7 psi
Wheels 7.0JJ x 18
Temporary Spare Tire T145/70D17
Temporary Spare Wheel 17 x 4T
EPA Mileage (City/Highway) 19 / 25
Crankcase (U.S. quarts) 6.8
Engine coolant (U.S. quarts) 8.5
Fuel tank capacity (gallons) 15.9
Wheelbase 105.3
Track: (front & rear) 60.6
Length 186.8
Width 70.1
Height 56.3
Minimum ground clearance, laden 4.86
Weight distribution, % front:rear 60:40
Curb weight (Federal spec, lbs.) M/T 3589
GVWR (lbs.) Total 4552
Front 2449
Rear 2103
EPA Passenger Volume (cu ft) 96.1
EPA Total Volume (cu ft) 108.6
EPA Vehicle Size Category Compact car
Headroom (inches) Front 38.7
Front with moonroof 38.0
Rear 37.1
Leg room (inches) Front 42.3
Rear 36.5
Shoulder room (inches) Front 56.1
Rear 54.9
Hip room (inches) Front 54.7
Rear 54.1
Rear knee clearance 2.4
technyne is offline
Old 12-06-2005, 02:04 PM   #2
pio
pio's Avatar
Fan#: 198
What I Drive: 2014 focus electric
FF Reputation: 2 pio Good Standing Member
Buy-Sell-Trade Rating: (7)
thats a sweet car...
My focus is not even a shadow of what it once was...
pio is offline
Old 12-06-2005, 02:05 PM   #3
Alex Arce
Random Guy #31
Alex Arce's Avatar
Fan#: 21050
What I Drive: 04 2.3L stage 2 Roush
Points 4,789, Level 44
Points: 4,789, Level: 44 Points: 4,789, Level: 44 Points: 4,789, Level: 44
Level Up 20% Completed
FF Reputation: 2 Alex Arce Good Standing Member
Buy-Sell-Trade Rating: (17)
yeah thats an awsome car....might trade in one of my cars to get that one....well its going to be the wifes car when i get it.... how many were released? i heard only around 5 or 6 thousand
Team Dreamspeed
04 ZX3 2.3 Stage 2 Roush
02 SVT
02 Zetec
Alex Arce is offline
Old 12-06-2005, 02:21 PM   #4
pio
pio's Avatar
Fan#: 198
i think they only release 6k in the states...
they are made the japan plant
pio is offline
Old 12-06-2005, 02:26 PM   #5
technyne
Fan#: 4422
What is particularly cool is the direct gas injection, here is a great article explaining the differences http://www.babcox.com/editorial/cm/cm59726.htm although the ULTRA LEAN ideology is rather frightening for a turbocharged application.
This article is written around the Mitsubishi GDI engine, but I would generally assume the engineering was "generally" applied in the Mazda
-Technyne
SVT Squad #146
technyne is offline
Old 12-06-2005, 02:38 PM   #6
Lil PZEV
Lil PZEV's Avatar
Fan#: 242
What I Drive: 2003 TwiBlue 2.3 ZX3
FF Reputation: 15 Lil PZEV Great Standing Member
Buy-Sell-Trade Rating: (14)
I really like the 6, and other MS cars... which makes me think I'd really like this newest one too!
Mazda > Ford right now, imho. At least for cars, I mean Fusion's cool, but Mazda's got a few "hype" models. Well, it's the same family anyway.
Lil PZEV is offline
Old 12-06-2005, 02:52 PM   #7
technyne
Fan#: 4422
Pictures For the Masses
technyne is offline
Old 12-06-2005, 02:55 PM   #8
Lil PZEV
Lil PZEV's Avatar
Fan#: 242
Sexy beast, I think. I should talk my stepdad into one of those to replace his old Taurus Oh yeah, then I could have access to it!
I'm sure the Taurus' exceptionally good gas mileage would go right out the window though...
Lil PZEV is offline
Old 12-06-2005, 03:01 PM   #9
PapoSwing
Regulator...mount up
PapoSwing's Avatar
Fan#: 3062
What I Drive: 03 Pitch Black SVT
Points 5,930, Level 49
Points: 5,930, Level: 49 Points: 5,930, Level: 49 Points: 5,930, Level: 49
Level Up 90% Completed
FF Reputation: 28 PapoSwing Great Standing Member
Buy-Sell-Trade Rating: (10)
Houw much is this thing again
PapoSwing is offline
Old 12-06-2005, 03:02 PM   #10
Lil PZEV
Lil PZEV's Avatar
Fan#: 242
It's MSRP says 28,500. I don't know how Mazda pricing works, the way Ford's always lower than MSRP?
Lil PZEV is offline
