Project: RS Focus @ over 300 whp - Page 6 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-30-2006, 11:01 PM   #61
AndrewBoy
AndrewBoy's Avatar
Fan#: 209
What I Drive: PantherBlack RS
FF Reputation: 3 AndrewBoy Good Standing Member
The RS springs arrived, i was working so fast i forgot to take pictures.
The front RS spring is lower by 5 centimeters compared to original. The front is lower now by 4 cm with the RS springs. Looking at the rear spring, i was shocked, it is lower by 6-7 cm compared to original ones. Also the rear RS absorter is shorter by 7 cm. After i installed the rear is lower by only 1,5 cm. I took a trial ride. Awesome suspension... Very stiff and handling is just better..
Just one picture i have now, i have to wash the car to show you;-))
Left spring: RS lowering 1,5 cm
Center spring: Enzo lowering 5 cm
Right spring: original
AndrewBoy is offline
Old 05-02-2006, 11:00 PM   #62
turbovation
all grown up
turbovation's Avatar
Fan#: 29834
What I Drive: 2006 Toyota tacoma work truck
Points 11,191, Level 69
Points: 11,191, Level: 69 Points: 11,191, Level: 69 Points: 11,191, Level: 69
Level Up 86% Completed
FF Reputation: 7 turbovation Good Standing Member
Good luck with this project Andrew! I'm gonna subscribe to this thread because I can not wait to see the progress you make..and it looks like there's at least hundreds if not more than a thousand other people who are gonna be watchin your progress! Those Brembo's are pretty damn impressive! I have to ask you though...are you having any help with this project or are you doing this all from technical know-how? I can not think of anything I would rather do with my life (assuming I had the money...which I'm assuming you do!) than modify my focus to RS-spec or greater...Cheers man take it easy don't work too hard!
-DanK
this is bob. bob has bitch tits.
turbovation is offline
Old 05-02-2006, 11:41 PM   #63
SkaAddict
Fan#: 1690
FF Reputation: 69 SkaAddict Excellent Standing Member
Buy-Sell-Trade Rating: (6)
I'm sort of in shock that AndrewBoy hasn't been flamed off the board yet by the same group that chased cochyn out of here when he did his RS swap (some BS garbage about how it wasn't a "pure" RS.)
Looks good...out of curiosity, have you checked what you're going to spend on all the parts vs. buying an actual RS? Or would insurance rates be through the roof on an RS and its cheaper to just adapt a regular Focus to RS specs and not pay the increased rates? Keep us posted
SkaAddict is offline
Old 05-15-2006, 07:37 AM   #64
AndrewBoy
AndrewBoy's Avatar
Fan#: 209
Actually nobody helps me, i do 95% the job alone. Of course when i had to put the knockle - ballbearing and hub together, i was not able to do it home. It's a slow project, lot of money and hard work. At the moment i spent abt 5000 usd for the suspension, brake, tyres, wheels and for the wider fenders, bumber. it can sound cheap, but i sold old bumper, old springs, brakes, wheels, tyres etc. and i'm working like a dog..
i checked everything before the project,
used rs: 30000-35000 usd
my car was with all the goodies: 11500-12000 USD
+ suspension, brake, full exterrior: 6000 USD
engine: 8500 USD
interrior: 2500 USD
this is almost 30000 USD
and have better car than the RS and with new tyres, brakes, engine etc.
The insurance is the same for the RS and normal 2.0 foci, here we pay insurance after the size of the engine, power does not matter.
the rear fenders will be ready for the next month, i shot some pictures in the weekend.
Other pictures are here
Old 05-15-2006, 09:54 AM   #65
Algorhythm
Fan#: 20623
What I Drive: 2005 ZX3, 2004 Kawasaki ZX6R 636
FF Reputation: 105 Algorhythm Excellent Standing Member Algorhythm Excellent Standing Member
Buy-Sell-Trade Rating: (17)
Amazing looking car.
Algorhythm is offline
Old 05-15-2006, 03:44 PM   #66
AndrewBoy
AndrewBoy's Avatar
Fan#: 209
just found this picture, my car was 5 days old;-)
Old 05-16-2006, 09:40 AM   #67
AndrewBoy
AndrewBoy's Avatar
Fan#: 209
So, just see where we are at the moment;-)
1st step: wheels/tyres, brakes, absorters, springs (whole suspension)
2nd step: front fenders/front bumper/RS springs
3rd step: rear fenders/rear bumper/RS springs
4th step: engine and engine management.
5th step: interrior (leather sparco, car pc, etc)
6th step: four wheel drive
First 2 steps are passed!
3rd step will be passed next month!
4th step will start soon. Turned out there is good chance to keep the original ecu and use an aftermarket for the engine management. Two possibilities i'm checking, motec and wolf, and there is another hungarian stuff which is very cheap, same capability as the motec, but eh... we will see.
I have to make an electronic device which enables o2 sensor, camshaft position sensor, crankshaft position sensor, temperature sensor to be splietted. the old ecu must receive data from sensors or the amplified inputs would die in case of no signals and brake the ecu down.
On the basis of the above, i can keep my old goodies in the car, abs, esp and a/c and the instrument cluster.
Once i have the extre ecu working fine, i will start build the engine.
I have few questions...
i have a used block with 95.000 mile.. can i keep it? or do i have to change? what pistons/connection rods do you suggest? i guess i will go for a fordracing intake manifold and also for a 70 mm throttle body. But question how can i link them together to have idle valve working? lot of questions;-) maybe t28bb turbo etc...
what do you suggest to reach 300 whp? what configuration do you recommend? i have never built a turbo engine.
thx
andrew
Old 05-16-2006, 12:52 PM   #68
project2point
project2point's Avatar
Fan#: 23521
What I Drive: 2010 genesis coupe track
FF Reputation: 7 project2point Good Standing Member
the 95,000 miles is fine when you take your motor apart just have it honed, crower rods and je 9:1 pistons will be fine. gt28rs is about 1,100 bux it is a great turbo but for 300 whp a t3 super 60 will be great and faster spooling.
anything else for turbo you need let me kno.
2010 genesis coupe 2.0t track.... Just a few things...
project2point is offline
Old 05-16-2006, 01:14 PM   #69
AndrewBoy
AndrewBoy's Avatar
Fan#: 209
Originally posted by project2point anything else for turbo you need let me kno. [/B]
PM Sent
Old 05-16-2006, 07:17 PM   #70
SkaAddict
Fan#: 1690
I've said it before; the reasons to move to Europe just keep piling up. If it was possible I'd do it in a heartbeat
That's one badass Focus you've got there...keep up the good work
Old 05-17-2006, 03:22 AM   #71
AndrewBoy
AndrewBoy's Avatar
Fan#: 209
Only in hungary;-) At the neighbours you have to pay on the basis of the power of the engine and also on the emission.
Old 05-17-2006, 12:49 PM   #72
BlackNRed01
Boost?
BlackNRed01's Avatar
Fan#: 21668
What I Drive: 2001 ZX3 MTX
FF Reputation: 4 BlackNRed01 Good Standing Member
Buy-Sell-Trade Rating: (8)
lose the dice
looks hot man
2001 Infra-Red ZX3
Boosted & Back: Parting Out
BlackNRed01 is offline
