Project: RS Focus @ over 300 whp - Page 18 - Focus Fanatics
Old 11-13-2006, 01:06 PM   #205
AndrewBoy
AndrewBoy's Avatar
Fan#: 209
What I Drive: PantherBlack RS
FF Reputation: 3 AndrewBoy Good Standing Member
After more than one month:
- RS block with crankshaft, pistons, connecting rods : ORDERED
- Turbo - exhaust system (original RS) have been bought recently
- Intercooler - oilcooler, piping system are under planning.
- ecu, still bigbig questions.
Questions to you:
standard MAF: enough to work with double airflow?
which maf shall i buy which is compatible with original and capable of handling double airflow?
what size of injectors shall i use for 300 hp?
worth to buy seanhyland's: intake manifold + thorttlebody + cylinder head?
i just want to put the car together with cca 220 hp, later will buy all the others.
what clutch do you recommend? (this is the most important now)
thx guys!
AndrewBoy is offline
Old 11-14-2006, 07:36 PM   #206
02SVTsilverstreak
02SVTsilverstreak's Avatar
Fan#: 20849
What I Drive: 1995 Chevrolet Z28 A4
FF Reputation: 1 02SVTsilverstreak Good Standing Member
i ♥ your focus. i shall have it....now...go look and see..its gone.
02SVTsilverstreak is offline
Old 11-15-2006, 12:29 AM   #207
SkaAddict
Fan#: 1690
FF Reputation: 69 SkaAddict Excellent Standing Member
Buy-Sell-Trade Rating: (6)
From what I've seen on here, the stock MAF is fine in turbo applications, however going to something bigger allows you to push the turbo further since the ECU is getting more accurate information. I'd also look into a blow-through MAF setup so the MAF is metering the compressed charge, again increasing accuracy and allowing you to push your setup further.
If you're serious about 300 WHP, I think 60 lb/hr injectors are what you need (not sure if that's how they're labeled over there.) However, bear in mind that only so much power is manageable through a FWD system...pushing that much, you could easily be spinning your tires through 3rd gear, meaning you'd be wasting a lot of power.
Again, I'd suggest posting in the Focus-Power subforum or PMing/e-mailing Tom (1turbofocus on here.) He used to build turbo kits and is the resident turbo expert.
SkaAddict is offline
Old 11-16-2006, 10:20 AM   #208
AndrewBoy
AndrewBoy's Avatar
Fan#: 209
You are right. I will go for the RS original MAF, it seems that i can buy with some guarantee trick on the price of the normal one. 60lb/hr seems to be more than enough. The main goal now to start the engine and use a turbo. Now i only have the original rs exhaust and turbo and manifold with all small parts i need.
Later will buy a bigger turbo to get 300 whp with all wheel drive. For fwd the max is 250-280bhp which is quite enough to learn how to drive this car. I dont want to die on the first day ;)
I took some pics about the short block, enjoy 'em gentlemen:
Next week i will install the engine, meanwhile have to prepare the paper work (here in europe we use both the vin and motorcode).
In the next few weeks i wont be able to spleep, just thinking of the development of my car ;)
Old 11-16-2006, 01:48 PM   #209
ozan
ozan's Avatar
Fan#: 29069
What I Drive: 2006 ink blue Mondeo TDCI
FF Reputation: 5 ozan Good Standing Member
wowwww u got the short block!! thats great are u going to change the bolts with ARP or r u going to keep them stock?
ozan is offline
Old 11-16-2006, 01:53 PM   #210
AndrewBoy
AndrewBoy's Avatar
Fan#: 209
Thx ;)
At the moment will use the stock ones (RS has the same stock ones).
Later if we are over 250 hp i will change them accordingly ;)
Still have to get a clutch.
What do you recommend guys?
Old 11-16-2006, 01:57 PM   #211
ozan
ozan's Avatar
Fan#: 29069
^^^i dont have any idea about the clutch that RS uses??? as i know its not same with zetec or duratec engines?
BTW u said "300whp with all wheel drive" :D how r u going to convert it to 4WD?
ozan is offline
Old 11-16-2006, 02:05 PM   #212
AndrewBoy
AndrewBoy's Avatar
Fan#: 209
RS has AP racing clutch, we have a guy here with an RS over 350bhp and the clutch is died after 5000 km-s. Now he is using a sinter one which is fine but not for daily use.
4wd:
- gearbox house of Mondeo '97 4x4 (same as mtx75)
- 4wd extension of Mondeo '97 4x4
- shaft of sierra 4x4
- custom made rear suspension, springs on the absorter, custom knuckle, etc.
Won't be an easy game.. but lets see first how the turbo charged engine is working ;)
I will put 4wd in the next year with other engine mods to reach the adequate power and tourqe.
Old 11-16-2006, 02:18 PM   #213
ozan
ozan's Avatar
Fan#: 29069
you can look for an AP then, but ofcourse a model which can handle 350-400hp and Tq...
if thats the gearbox i know it can handle max 300hp...
anyhow the 4WD system with an engine position like focus is very hard to convert...
cant wait to see the RS engine installed :))
ozan is offline
Old 11-16-2006, 02:53 PM   #214
AndrewBoy
AndrewBoy's Avatar
Fan#: 209
I mite go for a starforce clutch, not so expensive but i dunno whether ist capable of handling over 300bhp. The inside of the gearbox remain, i will keep everyting but the house which can receive the extension for 4x4. But we have planty of time to plan this.
Hehe, neither do I ;)
Will have to wait a week or so...
But will take lot of pix ;)
Old 11-17-2006, 08:09 AM   #215
ozan
ozan's Avatar
Fan#: 29069
that will be great we r waiting for the pics
ozan is offline
Old 11-18-2006, 07:43 AM   #216
AndrewBoy
AndrewBoy's Avatar
Fan#: 209
Just checked the block. I have an extra hole on the back nearby the oil filter. TIS says that this is the oiling for the turbo :-)
