Broken part on suspension.. where do i get part from? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-28-2005, 09:14 PM   #1
island_boy49
Fan#: 12848
What I Drive: Black 2000 ZX3
FF Reputation: 1 island_boy49 Good Standing Member
Buy-Sell-Trade Rating: (10)
Ok so i was tightening the 3 bolts on each side of my struts... and i ended up snapping one of the bolts. Its in this pic.. what part im talking about.
so i wanted to know where i could get that top part of the struts where it has the 3 bolts comming out of it. i swear i found it before on some site but i dont know where it was. thanks a bunch..
mods:
AEM CAI w/ by pass valve, FC 65mm tb, steeda short shifter
more to come:-D
Check Out the New Hawaii Forum
island_boy49 is offline
Old 11-28-2005, 09:23 PM   #2
Obocecha
Obocecha's Avatar
Fan#: 28484
What I Drive: 2002 Yellow ZX3
Points 1,703, Level 24
Points: 1,703, Level: 24 Points: 1,703, Level: 24 Points: 1,703, Level: 24
Level Up 3% Completed
Level up: 3% Level up: 3% Level up: 3%
FF Reputation: 15 Obocecha Great Standing Member
Buy-Sell-Trade Rating: (9)
http://www.partsamerica.com/ProductD...px?mfrcode=KYB
&mfrpartnumber=SM5169&parttype=1193&ptset=A
This should be what you need right here. I believe it's the same part number for all year foci. HTH.
'02 Yellow ZX3
'85 Supra 6M-GTE
Obocecha is offline
Old 11-28-2005, 11:08 PM   #3
crazymechanic
Fan#: 12900
What I Drive: 2003 SVT Focus
FF Reputation: 1 crazymechanic Good Standing Member
it's the upper bearing plate, aka strut mount. to replace, you have to remove the whole strut assembly, compress the spring, and remove the old bearing plate, install new, decompress spring, and reinstall strut assembly
crazymechanic is offline
Old 11-28-2005, 11:32 PM   #4
DidHeFocus?
Fan#: 1704
What I Drive: 2003.5 ZTW PZEV
Points 26,532, Level 97
Points: 26,532, Level: 97 Points: 26,532, Level: 97 Points: 26,532, Level: 97
Level Up 19% Completed
FF Reputation: 1 DidHeFocus? Good Standing Member
I believe the torque spec on those nuts is only 27 nm. Why did you tighten it so much?
I'm a middle aged guy, with a middle school mind.
DidHeFocus? is offline
Old 11-29-2005, 12:14 AM   #5
island_boy49
Fan#: 12848
i dont have a torque wrench.. and there were other problems too... but yeah... i know i did torque it too much.. :x
mods:
more to come:-D
Old 11-29-2005, 12:18 AM   #6
island_boy49
Fan#: 12848
yeah.. i assume its pretty easy to change.. i changed the springs on the car before... but are there any torque settings for the other parts that i will bolt on and take off .. ect.. i dont wanna brake another part :/
mods:
more to come:-D
Old 11-29-2005, 10:01 AM   #7
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
You can also drill the bottom of the sheared stud out of the plate and insert a bolt of the same size thru the wheel well. Use a star washer to keep the bolt from spinning when you tighten the nut . I did this on both sides of my rally car and it worked just fine. Its a lot easier than pulling the strut assembly and replacing the bearing plate. You can do a permanent fix/replacement when you "have to" remove or replace the strut.
Geezer is offline
