Go Back   Focus Fanatics > Ford Focus Tech Discussions > General Forced Induction
Old 02-10-2004, 01:26 AM   #1
MAD Performance
Fan#: 3346
FF Reputation: 1 MAD Performance Good Standing Member
i don't believe they sell a NON-aftercooled system....correct me if i'm wrong
MAD Performance is offline
Old 02-10-2004, 05:30 PM   #2
MAD Performance
Fan#: 3346
i couldn't find the non-aftercooled kit on that website.
here are the #'s for the aftercooled kit:
2000-2003 FOCUS ZX3 H.O. SUPERCHARGING SYSTEM*
horsepower from 130 to 195 and torque from 135lb./ft. to 170lb./ft. at 8 psig at the flywheel
2002-2003 FOCUS SVT H.O. SUPERCHARGING SYSTEM
increase horsepower from 170 to 276 and torque from 145lb./ft. to 204lb./ft. at approximately 10 psig at the flywheel
if they sell it without the aftercooler than i'm assuming it comes with a different pulley to run less boost. Maybe it comes with different injectors also since you'll be running rich with the lower boost also.
If you trying to save $$$ have you looked at the Jackson Racing kits? I carry both....
http://gallery.bcentral.com/Gallery/...90&Dept=341684
Old 02-10-2004, 11:00 PM   #3
Axman
Axman's Avatar
Fan#: 1868
What I Drive: 2005 liquid grey metalic ZX3 ses
FF Reputation: 1 Axman Good Standing Member
i actually plan on buying the vortech aftercooler at a later time. and it comes w/ the same size injectors as the other kits, and also, cfm is burning me a custom chip for the kit.
Euro wing, and powered M3 mirrors
FS Exhaust, CAI, Front & rear Strut Bar
Cosworth Flex Pipe, Stg 1 cams
FC TB,UDP
Axman is offline
Old 02-11-2004, 06:47 AM   #4
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
What I Drive: 2000 ZX3 / 2002 SVT , Turbocharged
FF Reputation: 146 1turbofocus Excellent Standing Member1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
Are you changing your MAF as well with the larger injectors
We have some of the best prices around on the Vortech kits
Customer Support
AIM: hpdyno
Email: tom@focus-power.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 02-11-2004, 08:07 AM   #5
Axman
Axman's Avatar
Fan#: 1868
Oh, and im looking for WHP, i dont think the numbers posted at superchargersonline are correct, cause how can 7 to 8 psi only give you 47 more hp at the crank/flywheel? when the JRSC gives less than that at the wheels w/ 7 to 8 psi
FC TB,UDP
Axman is offline
Old 02-11-2004, 01:38 PM   #6
MAD Performance
Fan#: 3346
the JRSC should give less than that at the WHEELS. also are they giving you a different pulley to run less boost?
Old 02-11-2004, 01:43 PM   #7
GonFishin
Fan#: 262
What I Drive: 2000 ZX3 / 2006 Mustang GT
FF Reputation: 1 GonFishin Good Standing Member
why does the ZX3 kit only have 8 psi and the SVT gets 10 psi? Is it because of rod strength because this seems like it'd be the opposite because of compression?
Someone in an earlier thread stated the stock ZX3 internals are good up to 14 psi. If this is true, then should someone tell Vortech? If it's good to 14, then Vortech should at least throw 10-11 at it.....to stay safe and all that.....
2000 ZX3 / Stage 1 + Gears / Intake / Exhaust / Tune
128whp @ 5000rpm and 135wtq @ 3800rpm
2006 Mustang GT / Intake / Exhaust / Tune
roughly 290rwhp & 315rwtq
GonFishin is offline
Old 02-11-2004, 01:53 PM   #8
MAD Performance
Fan#: 3346
not a foci expert, but possibly the SVT as a better fuel setup as well has internals even with the higher compression.
if the stock internals can handle 14psi that is really suprising for me, is that with stock fuel setup?
i'm sure vortech did plenty of testing and determined that 8psi is the best for the setup they provide (fuel upgrade is only bigger injectors with that kit).
I believe Focus Power runs more boost on thier kits, but they are running bigger injectors than the votech kit i'm sure and the chip manages the A/F to run the bigger injectors and boost.
correct me if i'm wrong Focus Power, nice kits BTW.
Old 02-11-2004, 11:06 PM   #9
Axman
Axman's Avatar
Fan#: 1868
for this i also ment to wrote that the JRSC gives more than 47 whp at 7-8 hp
i just think theres something wrong w/ someones numbers....
FC TB,UDP
Axman is offline
Old 02-14-2004, 11:33 AM   #10
Axman
Axman's Avatar
Fan#: 1868
well thats what vortech says about it. 9-10 w/ aftercooler and 7-8 w/o. dont know if this is true. i do plan on eventually getting the aftercooler. but not sure when.
FC TB,UDP
Axman is offline
Similar Threads
Vortech Tuner Satin Kits for zx3! LOW PRICE! cfmfocus2 Central Florida Motorsports 13 07-15-2008 11:37 AM
Back 2 Stock: Vortech, Borla, SCT, VF Engineering, and MORE! 2.0TooSlow Archive 15 02-13-2007 10:15 PM
- Vortech 101 - ampedout Ford Focus Builds & General Showroom 18 12-20-2005 08:35 PM
Numbers Numbers Numbers SuperFocusMan ZETEC Performance (2000-2004) 4 06-20-2005 08:45 PM
if u want a sc then u should read this good info blazealm General Forced Induction 15 01-26-2005 01:37 PM
