Instructions For Cosworth BS Delete Kit... - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-15-2005, 07:15 AM   #1
zekester
zekester's Avatar
Fan#: 871
What I Drive: '04 CD Silver ZX3, 2.3L Duratec w/
FF Reputation: 8 zekester Good Standing Member
Following are the instructions for the installation of the Cosworth BS Delete kit. These were emailed to me yesterday from Ken Anderson of Cosworth. Basically the same as MM installation instructions. If you go to thier web site, you can down load them. There are more specific instructions there regarding the correct trq measurements when reinstalling the oil pan, more than likely taken from the below mentioned Fod Focus Shop maual. Anyway, here they are.....
Part Number :KK3484
Application: 2003-2005 Ford Focus
2.3L Duratec I4 (PZEV)
2003-2006 Mazda 3 and 6
Important!
To properly install this part, you MUST have access to a genuine Ford Focus Shop manual. The correct manual is available from Helm Publishing
(800-782-4356). Part #FCS-12949-04
1. The Cosworth Balance shaft delete kit is designed to block off the oil passage to the balance shaft assembly when the balance shaft assembly is removed from the engine.
2. Following the instructions in the factory shop manual, remove the oil pan from the vehicle.
3. Remove the oil pick up to allow access to the balance shaft assembly.
4. Remove 4 x 10mm bolts that hold the balance shaft assembly from the block. Use caution as the balance shaft assembly is heavy.
5. Place the Cosworth Balance shaft delete plate with the o-ringed bung into the oil supply port used by the balance shaft assembly.
6. Use a small amount of Red Loctite on the attachment bolt and secure the plate to the block.
The bolt should be torqued to 18 ft/lbs.
7. Reinstall the oil pickup tube and torque to 8-10 ft/lbs.
8. Reinstall the oil pan using a factory recommended sealant.
For technical questions, please contact
cosincsales@cosworth.com
Cosworth, Inc.
3031 Fujita Street
Torrance, Ca. 90505
Ken Anderson
Sales/Marketing
Cosworth, Inc.
3031 Fujita Street
Torrance, Ca. 90505 USA
310 534 1390 x 423
Fax 310 534 2866
Cell- 562 569 3737
New Email; ken.anderson@cosworth.com
New Whip" '09 Scion xB "Release Series 6.0"
Old Whip" '04 ZX3, 2.3 Duratec, CD Silver w/ some stuff....
zekester is offline
