Passive rear steer revisited - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Road Racing & Rally
Road Racing & Rally The place to discuss information about road/rally racing stats, tips and events. Track sanctioned events only.
View Poll Results: Good Idea??
Yes 2 33.33%
No 3 50.00%
Yes, but i must add something to this 1 16.67%
Voters: 6. You may not vote on this poll
Old 11-14-2005, 10:51 PM   #1
S1lkwrm
Fan#: 11458
What I Drive: 2000 ZX3
FF Reputation: 1 S1lkwrm Good Standing Member
Ok after messing with this online game called "live for speed" more specific the rear toe settings on the car I came up with what seems to be a brilliant idea (Mabye).
when tunning the rear of a car to rotate we generally sacrifice the independent suspension by upping the stiffness of the rear bar or reducing the front bar. then mabye some tire pressure. Why not play onto the rear steering of our car? Its been overlooked as far as I know.
Assumptions:
- Going straight rear tires point foward for most part.
- turn left and the suspension rolls right and rear right tire toes out and I think rear left toes in causing the rear steer.
- this could be tuned by replacing the arm or what ever it is that bends, flexes, or acts lever.
- more turn in could be had.
- better rotation could be had (rear will track aroujnd the turn vice drag ala large swaybar)
- as you let off the turn the body will start to go back to center as will the toe I think this may alow for you to get on the gas sooner as the rear is actually not breaking traction and you dont have to wait for traction to catch up.
- A non passive rear steer car with alot of rear toe out will be really tail happy and less effective as both tires are pointed outward and your scrubbing speed and eating tire even when going straight.
-Passive rear stear guides the rear based on whatever bends, flexes, or acts as a lever and by the body roll.
Assumed Aplication:
- make for a much better slip angle when tuned with your current suspension, almost feel like your drifting the corner but actualy are turning around the turn but have enuf stiffness to set you center quickly in transitions.
- on a stiff track car I assume you loose a good bit of (PRS) since your roll is reduced you can up the effect on whatever bends, flexes, or acts lever to regain some of this.
** heres an analogy for over clockers of the AMD type all others skip this:
Body roll = MGHZ (bus speed)
bends, flexes, or acts lever suspension part = CPU multiplier
CPU mghz = amount or rear steer
if you lower your mghz you can up the multiplier to regain some cpu power.
so
if you reduce body roll you can up the part that bends, flexes, or acts lever to get more (PRS)
[:)][:)][:)][:)][:)][:)]end of wierd analogy [:)][:)][:)][:)][:)][:)]
to summarize I really think this is a part of our suspension we have really been over looking.
S1lkwrm is offline
Old 11-15-2005, 08:42 AM   #2
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
Don't forget, some of the PRS works through bushing deflection as well. If one can engineer a different piece that could change its charactistics, its worth exploring then.
January 2008 Focus Fanatics ROTM
2003 Ford Focus ZX3 2.3l N/A = 221 HP, 162 ft-lbs, 13.967@100.88MPH
2006 Ford Fusion 2.3l Turbo = 244HP, 247ft-lbs
duratec.wikispaces.com - Duratec Wiki - Sign up and contribute!
Egz is offline
Old 11-15-2005, 10:25 AM   #3
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
Re: Passive rear steer revisited
"on a stiff track car I assume you loose a good bit of (PRS) since your roll is reduced you can up the effect on whatever bends, flexes, or acts lever to regain some of this."
PRS is immobilized on cars that have it when raced. Drivers prefer to be able to induce oversteer when necessary. Example, early Mitsubishi Galant 4wd turbos had PRS and the first thing people did whether it was for rally or the track was to disable the system.
Geezer is offline
Old 11-15-2005, 10:49 AM   #4
jboylan
jboylan's Avatar
Fan#: 5755
What I Drive: 2003 Silver SVT SVT Squad#
FF Reputation: 1 jboylan Good Standing Member
Same with some of the 300z turbos. A friend of mine bought one a few years back to build up, and I honestly thought it felt ALOT better with the PRS disabled. The car was more predictable in the turns, but maybe thats just me.
VF rear motor mount, K&N drop in filter, Wayne's tune, MSD plug wires and re-gapped plugs, Spec stage 2 clutch, spec aluminum flywheel, randomtech high flow cat, ebc slotted rotors, hawk hps pads.
jboylan is offline
Old 11-15-2005, 11:54 AM   #5
Carrera26
Carrera26's Avatar
Fan#: 12237
What I Drive: 2005 Mazda3 2.3/2003 VW Passat GLX
FF Reputation: 2 Carrera26 Good Standing Member
Rear steer, both active and passive, was a bit of a fad in the 90's, especially with the Japanese. Most racers who use those cars now actually buy kits that defeat them, as they are unpredictable and unreliable in nearly every incarnation that has been tried yet. The only one I know of that was really good and still used in the racers is the Porsche 928's "Weissach Axle."
Explanation
Don't waste another minute waiting on parts, or anything else. Just get out there and start racing! You will suck at first, and you will be slower than many other cars, but the only thing you will regret is not starting earlier...
Carrera26 is offline
Old 11-15-2005, 12:40 PM   #6
SVT_BMXer
SVT_BMXer's Avatar
Fan#: 11226
What I Drive: 1991 BMW 318is
FF Reputation: 20 SVT_BMXer Great Standing Member
Buy-Sell-Trade Rating: (17)
i believe the 3000GT, Dodge stealth R/T and the 94 (i think) Mitsu galant VR4 are the only ones i can think that had any kind of rear steer.
02 Jackson Racing supercharged SVT
SOLD
Current:1991 BMW 318is: Bilstein sports, H&R springs, TMS chip, UUC short shifter, dyna-max muffler
SVT_BMXer is offline
Old 11-15-2005, 12:59 PM   #7
thedaemon
Fan#: 23368
What I Drive: 2003 Black SVTF
FF Reputation: 1 thedaemon Good Standing Member
honda prelude, nissan 240sx, and probably a few other too my bmx'r
thedaemon is offline
Old 11-15-2005, 01:02 PM   #8
jeremy
jeremy's Avatar
Fan#: 2086
What I Drive: 2003 black ZX3 (2.3)
FF Reputation: 1 jeremy Good Standing Member
Buy-Sell-Trade Rating: (4)
^^^^^^honda prelude?
cheers,
Jbs
jeremy is offline
Old 11-15-2005, 01:03 PM   #9
Carrera26
Carrera26's Avatar
Fan#: 12237
Other cars with rear steer
Porsche 928
Nissan 300ZX, Skyline, Micra
Honda Prelude SH
Mazda RX-7 (FC3S), MX-6
SAAB 9-3 (ReAxs Equipped)
VW Corrado
2006 G35, M45
Rolls Royce Phantom
Several non-us cars (EDM, JDM, ROW cars)
Toyota Aristo (Lexus GS here I believe, not equipped so in US)
GM trucks (QuadraSteer)
And probably many others. Even the Focus's Control Blade suspension offers a bit of passive rear-steer.
Old 11-15-2005, 01:49 PM   #10
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Duplicate threads merged.
WD40 is offline
