How to separate rear blinker from the stop on hatchbacks (2002-2005) - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus First Generation > MK1 Focus
Old 11-11-2005, 06:11 AM   #1
Peterbilt
Peterbilt's Avatar
Fan#: 29126
What I Drive: 2003 Silver ZX3 2.3L
FF Reputation: 5 Peterbilt Good Standing Member
Lightbulb How to separate rear blinker from the stop on hatchbacks (2002-2005)
In this thread, I am going to describe how I separated the rear turn signal from the stop signal. I believe it should work for 2002-2005 hatchbacks models. I want to give a credit to Hunt-r from the Ford Focus Club RU who provided me with the detailed information on the GEM output. In no way can I be held liable for any damage you may cause to your car's electronics by attempting the following procedure.
Please try to figure out where you want to position your new reverse lights as the old ones will become blinkers.
Before you start working on this project, obtain the following tools:
The second picture depicts a 6-12 V curcuit tester. The wire in the first picture should be about 16 GA. The blue 3-way connectors should read 18-14 GA. Your local Wal-Mart would have all these tools very cheap.
Step 1
Empty your glovebox and move it to outside. Behind the glovebox on the right, you should see the following:
The whole thing is called a GENERIC ELECTRONIC MODULE (GEM). Those five harnesses that are secured to the GEM by the yellow locks are the outputs. Disconnect the gray harness (#1), the green harness (#2), and the blue harness (#3).
Step 2
Make sure you provide enough light to differentiate between the coloured wires. Remove the black insulation as to have free access to the coloured wires in each harness.
  1. In gray harness (#1), you have to find the blue wire. Cut it approximately 3 cm downward from the harness. It used to be your left rear turn/stop signal.
  2. In green harness (#2), find the blue-red wire, and cut it in the same way as you did in step a. It used to be the right rear turn/stop signal.
  3. In blue harness (#3), find the BLUE-white wire (blue part is wider than white), but don't cut it. Instead, connect the blue wire from step a in parallel to this BLUE-white wire as shown below in diagram 1.
  4. In the same blue harness (#3), find the blue-red wire, but don't cut it. Connect the blue-red wire from the green harness (step b) in parallel to this blue-red wire that you just found. Connect in the same manner as shown in diagram 1.
  5. Put the insulation tape on the end of blue and blue-red wires that are just hanging in the air now.
  6. Connect harnesses back. Right above the gray and green harnesses on the GEM, there is a colour diagram that will help you put them back in the proper slots.
diagram 1
Make sure that harnesses are secured back in the slots, and put back the glovebox. The front part is done. Now, the wires (from gray and green harnesses) that go to the tail lights will only have the corresponding turn signal without stop.
Step 3
Empty the trunk. Push the seats into the passenger area as to make more space for yourself, for you will sit in the trunk while re-wiring the wires.
Remove the plastic left frame that the seatbelt is coming from. You don't have to remove it completely, but loosen it enough to remove the side carpet-like material that covers the entire rear left wall. When you remove it, you will see the following:
Don't change anything below the harnesses. Start from the blue harness and go up until the thick black wire splits apart. One will go to the left tail light, and another - to the right one. Start working on them soon after they become separated. Let's call them the left sleeve and the right sleeve respectively. The left sleeve is relatively short because the left tail light is right up there. The right sleeve will go under the trunk carpet and finally reach the right tail light.
Left (short) sleeve:
  1. Remove the black insulation 2 cm upward from the point where the wires split. You will see five wires: orange, blue, black, green-black, black.
  2. Cut the blue wire. Turn on the left signal and with the curcuit tester check if the blue wire is really a left turn signal.
  3. Cut the green-black wire. Connect the harness end of the blue wire to the tail light end of the green-black wire.
  4. In step c, you made the left b/u light act as the blinker, but you lost the actual back-up light. The reverse signal is still availabe from the harness end of the green-black wire that is hanging in the air at this moment. It's up to you where to put the new reverse lights.
Right (Long) sleeve:
  1. Remove the black insulation 2 cm upward from the point where the wires split. You will see five wires: orange, blue-red, black, green-xxx, black (I am not sure what colour xxx is).
  2. Cut the blue-red wire. Turn on the right signal and with the curcuit tester check if the blue-red wire is really a right turn signal.
  3. Cut the green-xxx wire. Connect the harness end of the blue-red wire to the tail light end of the green-xxx wire.
  4. In step c, you made the right b/u light act as the blinker, but you lost the actual back-up light. The reverse signal is still availabe from the bottom end of the green-xxx wire that is hanging in the air at this moment. It's up to you where to put the new reverse lights.
Sharing the stops from the stop mount light:
  1. Start going up from the gray wider harness. Remove the insulation so that it is near the place where you did re-wiring on the left and right sleeves.
  2. Find the green-yellow wire. Don't cut it.
  3. Cut a fairly long stretch of the wire that you purchased at Wal-Mart (Autozone, Cragen, wherever). The wire should be 16 GA. Connect this wire in parallel with the green-yellow wire that you found in step b. From now on, let's call this extra wire a "stop" wire. See diagram 2.
  4. Run the "stop" wire to the tail light end of the blue wire in the left sleeve. Connect the blue wire in parallel with the "stop" wire. In this step, don't cut the "stop" wire. Now, you connected the left tail light to the stop signal. Ask your friend to step on the brakes. If the mount stop light and the left stop light work good, proceed to the next step.
  5. Continue running the "stop" wire to the tail light end of the blue-red wire in the right sleeve. Connect the blue-red wire to the "stop" wire. Step on the brakes once again. If all three brake lights function, you are almost done.
Diagram 2
Check all your turning signals and observe the former back-up lights. Now, they should act as the blinkers. Check the brake lights once again. Install all frames back, and try to make the car look like it did before
Right now, you don't have the back-up lights. One solution would be to purchase a Euro-bumper with the back-up lights installed. Or, you may install custom clear lights wherever you want. Just don't forget which wire is your reverse signal (the harness end of the green-black wire that is hanging free).
Another link to HOW TO: http://olmikul.home.comcast.net/taillights.htm
Peterbilt is offline
Old 11-11-2005, 06:54 AM   #2
Zyghot
Zyghot's Avatar
Fan#: 21768
What I Drive: 2.3 ZX3 and 78' Camaro Z/28
FF Reputation: 1 Zyghot Good Standing Member
I really like how you went into detail using the GEM wires and the diagram, but why didn't you just remove the rear tail lights and the bulb assemblies and just cut the wires back there and splice them into the correct corresponding counterpart. I will be doing that sometime in the near future and then just going to get a pair of small fog lights to wire up and use as the back up lights.
"Only two things are infinite, the universe and human stupidity, and Im not sure about the former" ---Albert Einstein
Zyghot is offline
Old 11-11-2005, 07:39 AM   #3
hkysk8r07
hkysk8r07's Avatar
Fan#: 5957
What I Drive: 00 I-R ZX3/ 07 Reflex Silver GTI
FF Reputation: 1 hkysk8r07 Good Standing Member
Buy-Sell-Trade Rating: (11)
look in the other thread we tried that. it ONLY works this way
00 focus zx3
07 VW GTI
hkysk8r07 is offline
Old 11-11-2005, 08:27 AM   #4
W~Phoenix~{RC}
FF Bouncer
W~Phoenix~{RC}'s Avatar
Fan#: 11450
What I Drive: 2003 Silver Frost Sport Edition ATX
FF Reputation: 1 W~Phoenix~{RC} Good Standing Member
Buy-Sell-Trade Rating: (29)
Very nice write-up. I'm glad you found out how to do this. Do you have any pictures to go along with what you did?
Cheers!
W~Phoenix~{RC} is offline
Old 11-11-2005, 07:11 PM   #5
DrkKnight614
GO Green
DrkKnight614's Avatar
Fan#: 14522
FF Reputation: 47 DrkKnight614 Great Standing Member
nice write up...very detailed too. Im just wondering why you would bother to do this?
My 2003 Ford Focus ZX3 - Finally realized it's a 4cyl
DrkKnight614 is offline
Old 11-11-2005, 09:15 PM   #6
Peterbilt
Peterbilt's Avatar
Fan#: 29126
W~Phoenix~{RC}, right before I started working on this project, I accidentally fried my camera My analog camcorder is not a good substitute, but I will try to use it next time when I will hook up my new b/u lights.
DrkKnight614, to be brutally honest, I just hate red blinkers. Hate from the bottom of my heart
Old 11-11-2005, 09:31 PM   #7
DrkKnight614
GO Green
Fan#: 14522
^^^yea....but your not the one looking at them lol. I saw cars with white blinkers a few times, during the day they are ok, but at night they are just annoying....they make them red for a reason.
Old 11-11-2005, 09:37 PM   #8
Peterbilt
Peterbilt's Avatar
Fan#: 29126
Who said they were white? They are rather yellowish
Here is the video: http://mikul.net/video/rear_flashers.mpeg
Old 11-12-2005, 10:06 PM   #9
Peterbilt
Peterbilt's Avatar
Fan#: 29126
Ok, today I installed the new back-up lights near the license plate. Had to drill the holes in the body, so the modification is final. The lights are barely visible during the day, but pretty bright in the dark. Since the Calif Vehicle Code doesn't specify how bright they should be, I didn't bother much with this. I used a 10W bulb with the same shape as the license plate bulbs. It looks good, and it is legal - that's all I care about.
P.S. Drilling holes is not the hardest part, but running a wire trully was the pain in the ass.
Here is the video: >> Back-up lights <<
Thta's how the lights look like when not lighted:
We're all living in America,
Coca-Cola, sometimes WAR,
Amerika, Amerika.
Old 12-21-2005, 02:54 PM   #10
Fredness
Fan#: 26710
What I Drive: 2005 Cloud White ZX3
FF Reputation: 7 Fredness Good Standing Member
"Account for domain mikul.net has been suspended"
Broken links on pix....
I am looking to do this, but I could really use some pix!
'05 ZX3 ("S") Team Duratec #56
Engine: Modified MBRP Stainless Exhaust, K&N AirCharger, SCT LiveWire (dealer), ScanGauge, poly "dogbone" bushings.
Stereo: '05 Mustang Shaker500 H/U, Polk DB570's and an Infinity BassLink SubWoofer.
Fredness is offline
