Go Back   Focus Fanatics > Ford Focus Racing Discussions > Autocross Racing
Autocross Racing The place to discuss information about autocross stats, tips and events. Track sanctioned events only.
Old 11-10-2005, 09:15 PM   #1
2.0TooSlow
Fan#: 27765
What I Drive: 02 SVT
FF Reputation: 1 2.0TooSlow Good Standing Member
Alignment
camber: -1.0 -1.0
caster: 3.0 3.0
toe: .02 .02
camber: -1.5 -1.5
toe: .06 .06
What do you all think of this setup for a decent daily driver/autocross setup?
2.0TooSlow is offline
Fan#: 1
Old 11-11-2005, 12:30 PM   #2
Carrera26
Carrera26's Avatar
Fan#: 12237
What I Drive: 2005 Mazda3 2.3/2003 VW Passat GLX
FF Reputation: 2 Carrera26 Good Standing Member
I would go with more toe-out in the front, which would improve turn-in, and really wouldn't show too much extra wear on the tires. Also, I sure wouldn't want more camber in the rear than at the fronts, but that can't be solved without the aftermarket...
Don't waste another minute waiting on parts, or anything else. Just get out there and start racing! You will suck at first, and you will be slower than many other cars, but the only thing you will regret is not starting earlier...
Carrera26 is offline
Old 11-17-2005, 10:34 PM   #3
2.0TooSlow
Fan#: 27765
Sorry. I just got around to this thread again.
I will have seperate wheels/tires for Autocross shortly, but yes, I do care about tire wear.
Old 11-18-2005, 07:53 AM   #4
barts
barts's Avatar
Fan#: 16187
FF Reputation: 1 barts Good Standing Member
This is my set-up for track and auto-x
Camber front: -2°
Camber rear: -1.7°
Caster front: 3.75
Toe front: 1/16 out each side for a total front toe out of 1/8
Toe rear: 0 total
This is an awesome set-up, the turn-in is sooooooooooo much better with that spec
barts is offline
Old 11-18-2005, 09:14 AM   #5
Carrera26
Carrera26's Avatar
Fan#: 12237
Looks like what I would do, given the aftermarket pieces to achieve it.
Do you keep this setup from AutoX to open track? I can understand that it's probably a b[:)][:)][:)][:)][:)][:)] to change (and not screw up), and you want consistency, but if you had the time and the setup equipment at home (corner scales, laser alignment tools, lift, etc.) and could make a specific AutoX and specific Road Course setup, what do you think they would be?
Old 11-18-2005, 10:02 AM   #6
barts
barts's Avatar
Fan#: 16187
Yes and for my daily driving too
juste some little tire wear inside front from the negative camber.
barts is offline
Old 11-18-2005, 10:07 AM   #7
barts
barts's Avatar
Fan#: 16187
Exactly the same set-up that i have with a bit more negative camber.
barts is offline
Old 11-18-2005, 10:25 AM   #8
WD40
The Librarian
WD40's Avatar
Fan#: 5157
FF Reputation: 136 WD40 Excellent Standing MemberWD40 Excellent Standing Member
I think what Carrera26 is getting at, is that's a lot of toe out for a road course.
It'll be rather "darty" shall I say when heading down the straights...
Have you actually run that setup on a road course?
WD40 is offline
Old 11-18-2005, 10:42 AM   #9
Carrera26
Carrera26's Avatar
Fan#: 12237
Yeah, that toe seemed great for the cones but fairly twitchy for high-speed. Of course, there are a dozen other factors we aren't discussing as well. I believe that you have a fairly extensive setup, so the ride height, rebound, sway-bar, etc. would change as well. Then there are rain, smooth track, bumpy track, R-Compound vs. Street tire, etc....
I just know that if I were out on the big track that I'd be running more camber and less toe, and it'd be different again if I was going to optimal cone-dodging setup. I could see -3 front camber on the road course, but not in the cones due to traction loss. Just wanted to see what you think you'd set yours at if you could "optimize" for each.
Old 11-18-2005, 11:07 AM   #10
barts
barts's Avatar
Fan#: 16187
I really like my set-up for both, even with some toe out the car is very stable in the straight at high speed, and the turn in is so much better.
it depend of your driving style too, i like it when i can put the front of the car exactly where i want so i need that toe out in front to do that, my rear 24mm sway bar help me a lot for that too.
it wont be a traction problem for me with -3° negative camber in autocross cause i have a torsen
this is what i have on my car
koni yellow, h&r race spring, h&r rear 24 mm sway bar (stock 21mm front) , camber plate & bolts, torsen t-2, front and rear strut bar (waste of money with a focus) , rota slipstream 16 x 7, rt-215 falken azenis 215-45-16
Yes, once a week i do road course during summer.
barts is offline
