DURATEC Performance (2003-2011) The place to chat about any Duratec 23, 23E, and 20 engine performance, tuning and exhaust related upgrades.
#31 | ||||
I'll let everyone know.
ZX4ST_DFW Team Duratec #19 |
#32 | ||||
"Party Pic WHORE"
thanks for the info!!
ST crew #29 team DURATEC #53 MBRP exhaust, SRI, BFG G-Force sports, Steeda STS, painted stock rims, 1 12" diamond audio D6 sub, 3201T audiobahn amp, JVC headunit, Kicker 6X8's, 2 Farad cole cap, FC front strut bar, under body LED kit |
#33 | ||||
Well, mine did it again this morning. Haven't had a chance to mention it to the service dept. yet. Guess I'd better go do that now.
Roger I sell Ford, Lincoln, and Mercury vehicles one piece at a time. Shadow may be gone, but I am still around from time to time! |
#34 | ||||
Well, my SA has my car right now. They were pulling it into the shop about 30 minutes ago. It is cold this morning and I reminded him that if they shut it off, while the motor is cool and try to restart it, they'll see the issue. They assured me, that they would find this problem and fix it. I hope so, because I've been driving a loaner from the dealer and I just don't like it as much as my fun little ST.
I will know more later this afternoon, hopefully.
#37 | ||||
Okay, here is the scoop!
My local dealership worked with Ford Engineering and they checked all of the items that could have possibly caused this issue. 1.) They pulled the driver's seat and checked a harness under the seat that ties in with the Perimeter Security System. They disconnected and reconnected it. 2.) They reprogrammed the PCM according to the TSB and replaced the Idle Speed Control Valve and checked all of the grounding points on the Engine Wiring Harness. So far, I have not had any incidence of this issue, including the 'hiccup' at speed on the highway. I drove the car right at 600 miles since last Tuesday when I got it back and have not had a single 'Hard Starting' issue either. So, with them checking all connections and reprogramming and replacing the ISC, it looks like they fixed it. But, only time will tell. Hey, I love my ST, so there are no gripes from my end.
#38 | ||||
Now that's good news!
Sounds like you'd better drop off a box of candy or a six-pack of micro-brew for your service advisor this Christmas! Thanks for the update! |
#39 | ||||
hmmm. i have had the long cranking times - almost came to accept it as a quirk of my car until i saw this thread - but i don't know if the oil filter has anything to do with it - my car has been serviced at the dealership since new - so, i have only been running oem (the magic motorcraft filter) - at times i have also had the studder, i don't have a perimeter alarm, but i had the dealer take it out before i bought it, maybe there is a ground issue? - most of the time i think it is my rpm's not corresponding to the correct gear - i forget about the computer on the car - the only other issue i have is the loud lifter tick at idle
cheers, Jbs |
#40 | ||||
There is one more thing about this. It shouldn't have anything to do with it, but the Service Tech also replaced the Noise Suppressor coming off of the Coil On Plug Packs. It is mounted next to the cams and is mounted on a short bracket. It has a grounding wire that attaches to the frame, next to the Strut Tower on the right side on the engine compartment. He found out that the ground wire was broken. It is a small black square box. For those of you having this issue, check that wire. Being a former mechanic in the military, I see no reason for this to cause any issue. But then again, I was working with 1950-1970 technology. This is 2005. Anyone have any ideas on this?
Dean
| Thread Tools | |
| Display Modes | |
