Long Crank/Hard Start 2.0L And 2.3L Engine With MTX-75 Transaxle Bulletin - Page 12 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-10-2013, 10:15 AM   #111
dooor
Fan#: 51395
What I Drive: 2007 se stick
Points 926, Level 16
Points: 926, Level: 16 Points: 926, Level: 16 Points: 926, Level: 16
Level Up 26% Completed
FF Reputation: 1 dooor Good Standing Member
Question
This long crank, hard start, run the fuel pump before trying to start problem is a b---h. Could fuel be flowing away from the injectors when the engine is off which would have the injectors passing only air for awhile? When replacing the fuel pump, a waste of time &$, no fuel pressure was in the system. A few miles later the fuel filter replacement again had no fuel pressure in the system when opened up. No fuel leaks to the atmosphere can be seen nor smelled. The fuel tank cap is new. Is there some kind of mechanism that keeps pressure in the fuel system when the engine is not running? I know that sounds stupid but the no pressure deal seems important to me. Thought, ideas, speculation and wild guesses are welcome. This one is -out of the box- strange.
dooor is online now
Old 11-18-2014, 02:17 AM   #112
malim
malim's Avatar
Fan#: 55004
What I Drive: 2007 Ford Focus ST - Black
Points 972, Level 16
Points: 972, Level: 16 Points: 972, Level: 16 Points: 972, Level: 16
Level Up 72% Completed
FF Reputation: 4 malim Good Standing Member
Hey, reviving the thread here.
Wanted to see if anyone that had this issue had it solved? There is no verdict on the fix besides the ECU flash which is also debatable. Wanted to hear from some of you who may have an answer.
Replaced fuel filter and spark plugs, the problem continues.
malim is offline
Old 12-01-2014, 05:59 PM   #113
JEEPers
Fan#: 61184
What I Drive: 2007 Pitch Black Zx4 SE
Points 82, Level 1
Points: 82, Level: 1 Points: 82, Level: 1 Points: 82, Level: 1
Level Up 64% Completed
FF Reputation: 1 JEEPers Good Standing Member
Same here. wondering if a fix was available aside from a dealer visit for a flash to ECU.
-Frank
JEEPers is offline
Old 12-01-2014, 11:45 PM   #114
dooor
Fan#: 51395
Let's face it. If you bought new, Ford got your money and doesn't care if you ever buy another Ford. My dealer here in Bakersfield, Ca. made that clear.
dooor is online now
Old 12-22-2014, 05:11 PM   #115
CT-ST
Fan#: 100421
What I Drive: 2006 Ford Focus ST
Points 165, Level 3
Points: 165, Level: 3 Points: 165, Level: 3 Points: 165, Level: 3
Level Up 30% Completed
FF Reputation: 2 CT-ST Good Standing Member
You have got to be joking.
"Sometimes my car starts slowly. FORD IS EVIL AND DOESN'T LOVE ME. MY CAR IS A TURD!!!"
CT-ST is offline
Old 12-22-2014, 06:32 PM   #116
dooor
Fan#: 51395
The local dealer sells so many trucks that cars are a nuisance.
dooor is online now
Old 12-25-2014, 12:39 PM   #117
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,021, Level 74
Points: 13,021, Level: 74 Points: 13,021, Level: 74 Points: 13,021, Level: 74
Level Up 43% Completed
Forum Activity 99%
Every now & then I have a long crank, 2nd time it fires off. A 23 Ranger that I drive at work has the same problem on the 1st start of the day & I just leave the key into the start postion for 15 or so seconds & it fires off. Selling & servicing the different vehicles are 2 different things. If thats what you think, about your dealer, I'd be looking at another dealer.
felixthecat is offline
Old 12-25-2014, 03:21 PM   #118
dooor
Fan#: 51395
I ignored CT-ST's nonsense and hoped that this post would stop, but that hasn't happened.
I know or am related to seven dealer line techs., two worked at Ford dealerships, two dealership owner operators, one dealership accountant, one financier for customer purchases, two salesman, two parts dept. managers, and one sales manager. All work for or have worked for new car dealerships.
FOMOCO allows dealers extremely wide latitude when handling warranty and customer treatment matters. Case in point.
The upper part of my cars driver seat began to lean back unevenly. The dealer claimed that the seat was not covered under the extended warranty that I had purchased even though the warranty period had not expired. I forwarded my complaint to FOMOCO 's customer complaint dept. in Dearborn, Michigan. That dept. waited several months until the warranty had expired. Then they called me to inform me that they would not handle my complaint because the warranty had just expired.
I stripped the upholstery from the seat and found that the stamped steel frame had broken all around the top portion right next to the welds. A professional welder suggested that the welds were too large and hot. That caused the adjacent frame metal to become too brittle for it's intended service. The steel next to the welds was too brittle to flex when the seat was in use. This seat had a side air bag attached. If the air bag had deployed on the broken upper seat frame the driver's back could have easily been BROKEN.
I still have the broken seat frame.
The nearest Ford dealers are 38, 51, 52, 53, and 55 miles away.
$125.00 at a recycle yard secured a replacement seat.
Ford goes to market with product that they know will drive away a certain percent of buyers. Advertising is relied upon to bring in new customers. Ford advertises more that any other car mfg. in this country.
dooor is online now
Old 12-25-2014, 04:29 PM   #119
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 99%
I had a squeaky seat (upper back rest) I removed the seat covers & foam & find a few of the brackets that are welded to the frame, were coming undone & rewelded them & welded a few more places also. That was in early '12 & no issues since. Pretty cruddy that no dealer would help you, let alone the complaint dept. Glad you got your seat issue fixed.
Old 01-09-2015, 03:55 PM   #120
malim
malim's Avatar
Fan#: 55004
Well, it seems like you guys went a bit on a off-topic rant here about Ford.
For those who are having the same problem and have not reprogrammed the ECU, a suggestion was made in this topic that works to help with the start.
When cranking it and it doesn't start after 2-3 seconds, stop. Let is sit for a few seconds and when you go to crank it the second time just slightly BLIP your throttle while cranking it. It'll start right up, you will see. Ever since I've been doing this, it worked like a charm every time. I no longer have to kill my starter with these long cranks.
Hope this was useful.
malim is offline
