How To: Adding an OEM Tachometer Cluster on a 2005-up - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus First Generation > MK1 Interior Mods & Upgrades
Old 10-26-2005, 10:45 PM   #1
zxtunerdotcom
zxtunerdotcom's Avatar
Fan#: 19637
What I Drive: 2005 Cloud 9 White ZX3 S
FF Reputation: 1 zxtunerdotcom Good Standing Member
How to change Speedo Clusters from Non-Tach style to Tach style on a 2005 in 10 Easy Steps:
Estimated time: 30 minutes max.
1. Purchase a Speedo/Tach. In 2005, the instrument clusters were changed in wiring and construction, making it mandatory that a 2005-2006 cluster be used (2000-2004 will not work). I purchased my cluster at car-part.com for $85 shipped.
2. Disconnect the negative cable on your car's battery.
3. Tools needed: 7mm combination wrench, 7mm and 8mm sockets w/ ratchet or nut driver.
4. With the 8mm socket, remove the two bolts on the lower dash trim, at about steering column level. The whole panel does not to be removed, so you can leave the lower hood cable, OBD2 plug, and attaching bolts alone.
5. Pry the lower trim panel back on the far left corner to gain access to the single bolt securing the dash trim, located right below the headlight switch.
6. Remove the bolt with a 7mm combination wrench.
7. Now it's time to remove the instrument trim panel - it just tugs loose. Once it's free from it's clips, disconnect the rubber flap that sits between the steering column and the trim panel. It's held on with rubber nipples that fit in slots on the trim panel - just pull them out one at a time.
Then, disconnect the electrical plug on the Trunk release button. The button pops out easily too. The trim panel should now be ready to lift off.
8. All that's left now is 1 plug and 4 bolts. Remove the 4 bolts attaching the cluster to the dash, and disconnect the plug. The plug latches like a basket handle - just pry up the black handle and the plug will seperate from the cluster. To plug it back on, push the handle back down and it will suck the plug onto the speedo cluster's socket.
9. I found that if your car does not have ABS or Traction Control, the cluster will illuminate the traction control, abs, and brake warning lamps whenever the key is on. To avoid staring at them lit up all the time, I remedied this by removing the upper lens and bezel from the actual speedo cluster and applying black tape over the offending led bulb lenses. When I put the bezel back on, it became impossible to tell they were permanently lit. The only down side I can see by doing this is the Brake warning lamp is now inoperable so if you're one of those who drives away with your emergency brake on or you don't check your brake fluid level periodically, this mod might not be for you.
10. It's time to install the cluster! Just put everything back on in the order it came off and you'll be done! Go enjoy!
Rob
zxtunerdotcom is offline
Old 10-26-2005, 10:47 PM   #2
zxtunerdotcom
Fan#: 19637
BTW, Pic of the completed job:
Old 10-27-2005, 12:25 AM   #3
Lil PZEV
Lil PZEV's Avatar
Fan#: 242
What I Drive: 2003 TwiBlue 2.3 ZX3
FF Reputation: 15 Lil PZEV Great Standing Member
Buy-Sell-Trade Rating: (14)
Nice write-up!
The tachless cluster always looks so sad, it's odd to me to only see the 3 "circles" in some people's dashes
Lil PZEV is offline
Old 10-27-2005, 12:58 AM   #4
zxtunerdotcom
Fan#: 19637
thanks amanda - i agree, it does look very plain with the stock speedo - like you're being punished for not having paid enough for the car.
rob
Old 10-27-2005, 01:00 AM   #5
Lil PZEV
Lil PZEV's Avatar
Fan#: 242
True. Also, mine's an auto, so I use it, but I feel like manuals really Should have one. I know you can listen to/feel what the car's telling you... but it seems more logical to give them one!
Lil PZEV is offline
Old 11-02-2005, 08:47 AM   #6
Algorhythm
Fan#: 20623
What I Drive: 2005 ZX3, 2004 Kawasaki ZX6R 636
FF Reputation: 105 Algorhythm Excellent Standing Member Algorhythm Excellent Standing Member
Buy-Sell-Trade Rating: (17)
What about the mileage?
Algorhythm is offline
Old 11-02-2005, 09:07 AM   #7
lildisco
RespectMyAuthoritah!
lildisco's Avatar
Fan#: 5761
What I Drive: 06 Mazda6i, 08 Mazda CX7 GT AWD
Points 30,715, Level 100
Points: 30,715, Level: 100 Points: 30,715, Level: 100 Points: 30,715, Level: 100
Level Up 0% Completed
Forum Activity 3%
FF Reputation: 47 lildisco Great Standing Member
Buy-Sell-Trade Rating: (8)
that was what i was going to ask......On the older models you could do a cluster swap no problem, but the actual mileage of each car was on the cluster itself and not stored on the car. Is this true for newer models?
"I flushed a bag of skittles down the toilet yesterday and watched a NASCAR race in 8 seconds flat."
06 Spring Into Focus Best Sedan/Wagon Winner
03 SE SVT Wannabe (sold) to help pay for my 08 Cooper Red Mazda CX7 AWD GT
lildisco is offline
Old 11-02-2005, 05:57 PM   #8
five-speed2.3
five-speed2.3's Avatar
Fan#: 25318
What I Drive: 2004 Silver ZTS 2.3
FF Reputation: 1 five-speed2.3 Good Standing Member
umm, proably a dumb question, but will that work for an 04? my ZTS doesnt have a tach, and its killing me. i can drive without it, but tachs are just so much more fun.
instead of buying some extra thing that looks to kid racer, can i just do this same type of install? thanks.
2004 ZTS 2.3----Silver
Team Duratec #56
next to come exhaust.....
first 1/4 mile = 15.94, totally stock then
youtube.com/watch?v=TJlOJCqV8uU
five-speed2.3 is offline
Old 11-02-2005, 06:33 PM   #9
stpower
Fan#: 22432
What I Drive: 2005 Liquid Grey ST
FF Reputation: 1 stpower Good Standing Member
I can't beleive your zts is tachless. I'm sure it will work you just need a cluster from your year
2005 Focus ST- Typhoon Cold Air, Cosworth Header/ Flex, blah blah blah
1998 Escort ZX2- winter beater; K&N Short Ram
stpower is offline
Old 11-02-2005, 06:37 PM   #10
blkZX32005
Fan#: 26857
What I Drive: 2014 Focus Hatch
FF Reputation: 3 blkZX32005 Good Standing Member
wow I am going to do that to mine
FS CAI, Custom Eyelids, Silver star head lights and turns, FC Strut Bar, OBX stainless exhaust, blue interior LED's LED tail light bulbs, gold 17" Kyowa race wheels with nitto neogen tires......more to come....
blkZX32005 is offline
