"How To" - Clutch Master Cylinder Replacement - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Closed Thread
Old 01-05-2008, 11:11 PM   #61
nomad327
Fan#: 19440
What I Drive: red 2002 svt focus
FF Reputation: 13 nomad327 Great Standing Member
bleed screw is on top of transaxle at the front, follow the tube to find it. It's hard to get a good bleed, I did some initial priming with a small suck tube, looked like a real big syringe with a short clear tube. Got it at wal-mart for a couple bucks and used it to suck on the bleed screw, that got the fluid drawn down in enough that the master cylinder was wetted inside at least.
nomad327 is offline
    Quick reply to this message
Old 01-06-2008, 12:01 PM   #62
scrammer
scrammer's Avatar
Fan#: 26570
What I Drive: February 2010 ROTM
FF Reputation: 172 scrammer Excellent Standing Member scrammer Excellent Standing Member
Buy-Sell-Trade Rating: (29)
it is wise to bench bleed the CMS. i was told this after the fact. 11mm open end wrench and a friend pumping the pedal.
pump 10 times hold the clutch down and open the nipple a LITTLE. close the nipple and they can pump 10 more times. this will take a while.
scrammer is offline
Old 01-06-2008, 01:38 PM   #63
SkaAddict
Fan#: 1690
FF Reputation: 69 SkaAddict Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Sounds like a good excuse to invest in a power bleeder...
I bought one a few years ago and never looked back. Easiest way to bleed any part of the hydraulic system, fill it to the line with brake fluid, attach it to the brake fluid reservior, give it a few pumps and then just go open the bleeders and the pressure does the rest. Bled my clutch in about 5 minutes when I did my master cylinder and when I replaced the whole clutch. Best $60 I ever spent.
SkaAddict is offline
Old 01-29-2008, 10:37 PM   #64
TeamPrecisionIT
TeamPrecisionIT's Avatar
Fan#: 49174
What I Drive: 2002 Black ZX3 HB
FF Reputation: 1 TeamPrecisionIT Good Standing Member
Why is this not stickied?
TeamPrecisionIT is offline
Old 02-03-2008, 11:06 AM   #65
TeamPrecisionIT
Fan#: 49174
Maybe I am not searching right or am blind, which is possible, but is this even in the How-to Archive? Anyway, I wanted to lend a hand and give out the tools needed list:
Sockets: 13mm (for pedal bracket), 10mm (can be used for MC but will definitely need to be used for removing hose bracket from firewall) and at least a 8in extension (again for pedal bracket and firewall bracket) to go with them
Wrenches: 10mm (opt - will make removing the two bolts holding MC easier if they are rachet-type wrenches - i.e. gearwrenches), 11mm (box end, non rachet) for bleeder screw)
If I am leaving anything else out, please post up.
Damian
Old 03-03-2008, 06:21 PM   #66
rurockn
Fan#: 45008
What I Drive: 2002 Black SVT
FF Reputation: 1 rurockn Good Standing Member
Did anyone every verify what the updated part number is? I called the Ford dealership down the street and after ten minutes I gave up on them.
2003 Mach 1.
2003 Escape.
2002 SVT Focus.
1980 Fairmont 4-door, 351C, S400 turbo, Megasquirt EFI...yep, it moves.
rurockn is offline
Old 03-03-2008, 06:34 PM   #67
mofocus
mefocuslongtime
mofocus's Avatar
Fan#: 5
What I Drive: Beltfed,extra pullified,weeemachine
FF Reputation: 6 mofocus Good Standing Member
Buy-Sell-Trade Rating: (17)
try mike at hilbish, he should be able to get it for you, i might be getting one from him soon too.
MAY 2007 ROTM WOOT [/COLOR][/B][/U]
my dyno video
mofocus is offline
Old 04-03-2008, 12:03 PM   #68
ford'sford
Fan#: 52153
What I Drive: 2004 sonic blue svt
FF Reputation: 1 ford'sford Good Standing Member
hey guys it's me again, since completing the CMC replace Ive had trouble keeping the bolt that keeps the CMC plunger attached to the clutch pedal, because i cannot torque it down enough so that it stays put. Every couple of weeks the outside nut loosens followed by the inside one, then I have some sloppyness in the clutch engagement, so i tighten it down again. Do you guys have any suggestions?
ford'sford is offline
Old 04-08-2008, 09:25 AM   #69
rurockn
Fan#: 45008
Thanks for the tips. I replaced mine with the airbox removal method because I wanted to take the SVT shift lever counter weight off at the same time. I also bench bled the master cylinder before installing it. From start to finish it took about 2 hours tops including one-man-bleeding the clutch line myself and putting tools away. It's nice to finally have that brake fluid stink out of my car!
2003 Mach 1.
2003 Escape.
2002 SVT Focus.
rurockn is offline
Old 04-23-2008, 02:52 PM   #70
Ychocky
Fan#: 55408
What I Drive: 2002 Black Focus ZTS
FF Reputation: 1 Ychocky Good Standing Member
Hello all!
Found this wonderful resource in a pretty simple google search! :D
I have a 2002 ZTS
The Clutch pedal pin's weld snapped and was stressing the white plastic push rod , it finally broke off.
Silly me, I went to the local Ford dealer. I was quoted $930 CDN + tax for the Pedal (simple weld right?) the Clutch Master Cylinder, fluid, and then incredibly the red switch (ignition?)
This thread give me hope.
Any Canadian members reccomend a place to pick up a Clutch Master Cylinder? I was quoted $89 from Ford
Cheers love the site!
Ychocky is offline
Closed Thread
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Audi S3, Mazda MX-5 Miata and Acura TLX. You can find all Ford Focus, Focus ST and Focus RS related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
