"How To" - Clutch Master Cylinder Replacement - Page 6 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Closed Thread
Old 11-14-2007, 09:00 PM   #51
dartfork
Fan#: 23403
What I Drive: 2003 Yellow ZX3
FF Reputation: 1 dartfork Good Standing Member
Don't forget
One thing that is easy to overlook on this job is: hooking the master cylinder clutch piston thing onto the clutch pedal. Its easy to think after wrangling the pedal set back under the dash, "Cool, I'm almost done. I just have to bleed the clutch!" Then your inner Red Foreman should jump out and say, "Nope, don't tighten that pedal set yet. You still have to attach the piston to the clutch pedal ! With out that attached you'll never be able to pump the clutch!" If Red doesn't appear in your garage you'll have had the luck of seeing this post and you'll still be OK.
Enjoy getting to know your Focus all that much more intimately!
dartfork is offline
    Quick reply to this message
Old 11-15-2007, 09:19 AM   #52
kettle-one
kettle-one's Avatar
Fan#: 22664
What I Drive: Magnum R/T for sale
FF Reputation: 1 kettle-one Good Standing Member
Originally Posted by gtcars2006 View Post
How about changing the other part on the engine compartment? is that a brake booster? the one that the master cylinder attaches to...
I think so, I'd leave it alone unless its bad.
Former owner 2003 Comp Orange Euro SVT then 2002 WRX Wagon, now 06 Magnum R/T, selling it to get another SVT Focus...
1979 Ford F-150 SWB 4x4 460/ZF 5 speed
1969 Dart GTS 340/4 speed
kettle-one is offline
Old 11-15-2007, 09:37 AM   #53
WUGcatsvt
Obama Can't Gymkhana
WUGcatsvt's Avatar
Fan#: 36697
What I Drive: 02 SVT, 86 BMW E30, 10 VW GTI
FF Reputation: 62 WUGcatsvt Excellent Standing Member
Buy-Sell-Trade Rating: (18)
Once I get home Ill show you an Easier way to ge the hoses off the Cylinder... You can go in through your wheel well... Ive got Pics that Ill post..
"No, the Focus is SLOW and just kinda stays that way."-Joe GCR SCCA VP
gumpcrew#10
Gulf Coast Region #12 - Me-45 DSP
My Girl-451 DSPL
WUGcatsvt is offline
Old 11-17-2007, 03:17 PM   #54
WUGcatsvt
WUGcatsvt's Avatar
Fan#: 36697
Dirty Floor and Crappy Rice mats... (Cause of the brake fluid.. I didnt bother to vacume and I put rubbermats down to protect the carpet...?
Take off the Clutch Peddle because it makes it so Much easier...
No more Clutch..
Jack up the car.. and Make sure you use jack stands...
I wasnt done jacking the car up in this Picture...
Its Alot Easier if you fold back the wheel Liner and take off the clutch lines from a hole in your wheel well... Its to much of a pain to mess with your brake cylinder...
Heres the Hole... Both hydrologic lines are right there..
HINT: When ever you are reinstalling the pins tie a string around them so when you drop them you wont lose them
gumpcrew#10
My Girl-451 DSPL
Old 11-19-2007, 09:41 AM   #55
perrobox8
perrobox8's Avatar
Fan#: 45037
What I Drive: '01 silver ZX3
FF Reputation: 1 perrobox8 Good Standing Member
that sucks
zetec crew #144
AEM CAI,FC header,Borla catback,STR fuel rail,MSD ignition and wires,Massive speed UDP,Ford Racing LSD,X-Cal 2,Comp 2 cams,2000 intake manifold,NX
perrobox8 is offline
Old 11-20-2007, 02:02 AM   #56
starfuryt550
I Speed Often.
starfuryt550's Avatar
Fan#: 18440
What I Drive: Audi S4, Turbo ZX3
Points 23,065, Level 93
Points: 23,065, Level: 93 Points: 23,065, Level: 93 Points: 23,065, Level: 93
Level Up 72% Completed
Forum Activity 23%
Activity: 23% Activity: 23% Activity: 23%
FF Reputation: 23 starfuryt550 Great Standing Member
Buy-Sell-Trade Rating: (58)
tell me about it..this was horrible to change!! make sure you dont lose the clips like he said...i lost 2, thank god the new piece came with 2 new ones!
Daily: Audi S4 b5 | Project: Turbo ZX3
LED Conversions | Vinyl Carbon Wrapping | Powdercoated Valve Covers
starfuryt550 is offline
Old 11-21-2007, 06:25 PM   #57
oldfocusguy
Fan#: 51040
What I Drive: 2002 silver ZX3
FF Reputation: 1 oldfocusguy Good Standing Member
My son and I did this change today on our 2002 ZX3. It took about 5hrs. from start to finish. We would have been done sooner but for two things. When we went to reinstall the clutch pedal we found that we had forgotten to keep track of the clutch return spring and it had popped off. We had to take some stuff back off so we could get the spring back on it's hold down. Also, the bolt that holds down the battery tie-down strap was corroded and I sheared it off (real bad choice of materials). I had to drill it out and fashion a new bolt. Oh, and we just noticed that the brake lights were stuck on so we had to adjust the switch.
I'm not sure how much this would have cost at the shop but I figure we saved a couple of hundred bucks anyway.
oldfocusguy is offline
Old 11-28-2007, 11:52 PM   #58
sissyneck1
Registered User
Fan#: 51360
What I Drive: 2003, Pitch Black, Focus SVT 2D
FF Reputation: 1 sissyneck1 Good Standing Member
does anyone know which wilwood master clutch cylinder will replace the stock one for the svt's?
sissyneck1 is offline
Old 01-04-2008, 03:49 PM   #59
scrammer
scrammer's Avatar
Fan#: 26570
What I Drive: February 2010 ROTM
FF Reputation: 172 scrammer Excellent Standing Member scrammer Excellent Standing Member
Buy-Sell-Trade Rating: (29)
i just replaced my CMC today. took 2 hours from start to finish. took an hour to bleed! prolly close to 500 pumps with my son. other than that, the hardest part of this job is getting the bottom line hold-pin on and off.
scrammer is offline
Old 01-05-2008, 07:48 PM   #60
hgiles
hgiles's Avatar
Fan#: 44334
FF Reputation: 1 hgiles Good Standing Member
Did mine today. It was a bitch!! I ended up cutting the old one out! Came out much easier!
Now I gotta figure out how to bleed the damn thing! Is the bleed screw accessible underneath the car?
03 Pitch SVTF
Tom's Tune, Taylor 8.2, CFM STS, CFM tranny mount, AEM SRI, (seeking ORP)
hgiles is offline
Closed Thread
