"How To" - Clutch Master Cylinder Replacement - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Closed Thread
Old 07-18-2007, 02:49 PM   #41
tua03332
tua03332's Avatar
Fan#: 37555
What I Drive: 2000 Silver Sedan
FF Reputation: 1 tua03332 Good Standing Member
the tubing i was referring to was spare tubing used to hook to the bleeder valve. I didnt lose all the much fluid, but I will still need to bleed it and was wondering if there is a way to do it without a bleeder kit or by making a mess?
34 STS
Funded By: My Back Pocket
tua03332 is offline
    Quick reply to this message
Old 07-18-2007, 10:08 PM   #42
nomad327
Fan#: 19440
What I Drive: red 2002 svt focus
FF Reputation: 13 nomad327 Great Standing Member
The service manual (Ford 02-04) says some focus models require a bleeder pump to get the air out of the system. The one we are discussing is not one of those, and I got mine bled using the normal pedal down, pedal up method. I did not pre-fill the new master cylinder on the bench, which would probably have made bleeding easier, because I didn't want fluid dripping all over the interior while I was installing it. I had a bit more trouble getting it bled than some cars I've done, but it worked out OK. The location of the bleeder screw made it hard to put a box end wrench on it, which is the normal arrangement, and the one that works well with a clear extension hose. I ended up using a socket on an extension to work the valve, and the fluid puddled up a bit, but it did not seem to go all over the place too bad. Brake fluid is water soluble, and I just hosed it all off when I was done.
nomad327 is offline
Old 07-19-2007, 12:19 AM   #43
tua03332
tua03332's Avatar
Fan#: 37555
so basically push pedal, open it, let it drip all over the place, and then close it, repeat til finished, hose done engine compartment? sounds easy enough, thanks bud
34 STS
tua03332 is offline
Old 10-07-2007, 01:41 AM   #44
Ecko200X
Ecko200X's Avatar
Fan#: 31440
What I Drive: 2003 Competition Orange SVT (EAP)
FF Reputation: 30 Ecko200X Great Standing Member
Does Anyone Know Of Any After Market MC? Or In Usual Fashion, Is Ford The Only Place?
Ecko200X is offline
Old 10-28-2007, 09:52 AM   #45
starfuryt550
I Speed Often.
starfuryt550's Avatar
Fan#: 18440
What I Drive: Audi S4, Turbo ZX3
Points 23,483, Level 94
Points: 23,483, Level: 94 Points: 23,483, Level: 94 Points: 23,483, Level: 94
Level Up 14% Completed
Forum Activity 21%
Activity: 21% Activity: 21% Activity: 21%
FF Reputation: 23 starfuryt550 Great Standing Member
Buy-Sell-Trade Rating: (58)
so i was attempting to do this replacement yesterday, and ran into a couple problems. after taking like 6 hours, everything was done. i replaced everything and was expecting it all to start up. BUT...
...when i push the clutch, it feels dead, there is no power behind it. the car wont go into any gears either.
is it possible that a line is not perfectly closed and its not creating a vacuum? or any suggestions? thanksss
Daily: Audi S4 b5 | Project: Turbo ZX3
LED Conversions | Vinyl Carbon Wrapping | Powdercoated Valve Covers
starfuryt550 is online now
Old 10-28-2007, 07:46 PM   #46
nomad327
Fan#: 19440
If the pedal doesn't seem to be doing anything when you press it down, there is still probably air in the master cylinder or the high pressure line. If the clutch isn't releasing, the lever will not put the transmission into the forward gears when the motor is running, and it will grind trying to go into reverse
nomad327 is offline
Old 10-28-2007, 09:40 PM   #47
kettle-one
kettle-one's Avatar
Fan#: 22664
What I Drive: Magnum R/T for sale
FF Reputation: 1 kettle-one Good Standing Member
You'd hear it sucking or pushing air as you pumped it up to prime. Did you get blead out yet? I used a cheap bleeder bottle setup form autozone, worked good, had it blead it 10 minuets.
Former owner 2003 Comp Orange Euro SVT then 2002 WRX Wagon, now 06 Magnum R/T, selling it to get another SVT Focus...
1979 Ford F-150 SWB 4x4 460/ZF 5 speed
1969 Dart GTS 340/4 speed
kettle-one is offline
Old 10-29-2007, 10:58 AM   #48
starfuryt550
I Speed Often.
Fan#: 18440
Forum Activity 21%
Okay i got it fixed! i had to bleed it better, there was still air in the system.
But I had to disconnect the lower line (the second metal one) coming from the master cylinder, from the transmission. It becomes rubber and you can bend it a little lower. I used that to bleed the system using the method of "thumb off, press pedal. Thumb on, lift pedal" and it worked magic!!
Old 10-29-2007, 05:07 PM   #49
gtcars2006
Fan#: 51223
What I Drive: ford focus
FF Reputation: 1 gtcars2006 Good Standing Member
Urgent help!!!!!
Ok, the master cylinder ( crap) broke on me so the fluid cm out when I was driving. I managed to tow the car to my house Now, I replaced the master cylinder from inside the car and we bleed the system ( Including the brakes).
This is a 2005 4 door focus with the 2.0 engine manual.
The clutch pedal is still going to the floor, I am not able to start the car since the pedal doesn't depress to the point were the clutch's safety switch will tell the computer that it is ok to start. But if I depress the switch manually I can start the car but can not engage the gears. When the car is not running I could switch gears.
I bleed the system from the slave cylinder and then from the brake calipers. Gosh! am I doing something wrong?
I got several versions one from Pepboys and another one from the dealer including that I need a new tranny...
could the slave or clutch been damage when the master fluid spilled over? If the slave cylinder or bearing is bad, when I start the car shouldn't I be able to hear a noise or something? TTTTTTTTTHHHHHHHHHHHHHAAAAAANNNNNKSSS!!!!
gtcars2006 is offline
Old 10-29-2007, 05:24 PM   #50
gtcars2006
Fan#: 51223
How about changing the other part on the engine compartment? is that a brake booster? the one that the master cylinder attaches to...
Closed Thread
