"How To" - Clutch Master Cylinder Replacement - Page 10 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Closed Thread
Old 05-12-2010, 06:46 PM   #91
Kal-EL428
Kal-EL428's Avatar
Fan#: 47337
What I Drive: 2002 SVT Sonic Blue
FF Reputation: 33 Kal-EL428 Great Standing Member
I finally got around to changing my clutch master cylinder today. It was fairly straight forward, but a bit more involved than I thought it was going to be. All in all, it was not that difficult, more time consuming than difficult.
Since I just did mine (May 12, 2010), feel free to PM me with any questions/ concerns you may have.
* Tip: Have plenty of brake fluid on hand for the bleeding process, I went through way more than i thought.
02 Sonic Blue SVT
#2064 of 4788
Born on: 5-14-02
Kal-EL428 is offline
    Quick reply to this message
Old 05-22-2010, 05:26 PM   #92
nacnudv8
nacnudv8's Avatar
Fan#: 52725
What I Drive: former owner:Pitch Black '03 SVT 3D
FF Reputation: 7 nacnudv8 Good Standing Member
Did my CMC today
I did not take the pedal off I just took the two bolts off holding the CMC to the pedal bracket and bent the lower tab (that holds the clutch position switch - I took mine off years ago) to enable me to pull the CMC out.
I took the wheel off and wheel liner out so I could get my other hand in to push on the lines from the side.
I removed the battery so I had space to move the fuse box into
NOW the BEST TIP - leave the new clips ON the CMC - DO NOT try to put them on after you put the lines on. The lines are design to push snap into the CMC with the clips IN PLACE. I read many horror stories of people trying to get the clips on when the CMC is installed. It is next to impossible!
Fix the lower line BEFORE you secure the CMC inside the car - the CMC needs to be loose so it can be pushed from the fire wall to make room for re-connecting the lower line.
An eye for an eye makes the whole world blind.
Mahatma Gandhi
nacnudv8 is offline
Old 08-14-2010, 12:34 AM   #93
Trime2X1
Fan#: 77607
What I Drive: 2001 White ZX3
FF Reputation: 1 Trime2X1 Good Standing Member
Does anyone know if there is an aftermarket CMC other than the Ford plastic "toy" CMC?
I'm about to replace my 2nd CMC in 2 years. First CMC broke like many others have mentioned in their earlier posts, but the second CMC broke by the lower line and the pipe flange clip...happy happy, joy joy! I've also noticed that when I push the clutch down, the green plate (part of CMC) wants to push through the firewall. Any thoughts, thanks in advance for this rookie!
Trime2X1 is offline
Old 08-14-2010, 12:47 PM   #94
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,746, Level 73
Points: 12,746, Level: 73 Points: 12,746, Level: 73 Points: 12,746, Level: 73
Level Up 74% Completed
Forum Activity 99%
No replacement that's a "plug - n - play" for the stock unit, making sure all the pieces are there & in the right places so it lines up right is the only "generic" advice I've got to avoid doing it again soon.... Could the first replacement have been a bit out of place? or a clip/clamp not re-used that wasn't included with the new part? (just trying to think of possible issues here....)
sailor is offline
Old 10-16-2010, 04:51 PM   #95
Notorious0ne
Notorious0ne's Avatar
Fan#: 70375
What I Drive: 05 Saleen Focus, 04 Saleen Focus
Points 7,488, Level 57
Points: 7,488, Level: 57 Points: 7,488, Level: 57 Points: 7,488, Level: 57
Level Up 69% Completed
FF Reputation: 15 Notorious0ne Great Standing Member
Buy-Sell-Trade Rating: (6)
is there a way for me to temporary fix it? like throw some rtv in there? its gonna take 3 to 5 days for me to get the damn part.
2004/2005 Ford Focus Saleen
The cops are here to keep us safe.............I'm here to keep them busy!
Hatch Nation #43
Notorious0ne is offline
Old 11-02-2010, 11:22 PM   #96
Notorious0ne
Fan#: 70375
http://www.focusfanatics.com/forum/showthread.php?t=243148
Hatch Nation #43
Old 12-13-2010, 07:44 PM   #97
domesplit
domesplit's Avatar
Fan#: 19448
What I Drive: 2002 ZX5 and 2003 SVT ZX5
Points 990, Level 16
Points: 990, Level: 16 Points: 990, Level: 16 Points: 990, Level: 16
Level Up 90% Completed
FF Reputation: 1 domesplit Good Standing Member
Do you get a check engine light when the clutch master cylinder is failing? I have my car in the shop right now to have it replaced but I also told them to see what that check engine light is all about. The light came on not long after I noticed fluid on my clutch pedal.
I did have a sterio system with amps installed and I'm noticing the car wants to die when I push the clutch in at stop lights for the first 5 minutes after starting my car, but I also noticed that before the sterio intall. I hope it's not an alternator. I have 90,000 on my SVT.
domesplit is offline
Old 12-14-2010, 02:42 PM   #98
WD40
The Librarian
WD40's Avatar
Fan#: 5157
^^^No CEL for bad clutch master.
You may get the brake light coming on due to low fluid, but I hate to say it...your CEL is something else.
WD40 is offline
Old 12-14-2010, 02:51 PM   #99
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
And so a thread started in 06 was resurrected. This is in the How-To Archive on the banner, I'm going to lock it, if there's a reason to unlock it, then contact me and it can be unlocked.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Closed Thread
