"How To" - Clutch Master Cylinder Replacement - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Closed Thread
Old 10-26-2005, 07:50 PM   #1
pokeySVT
Fan#: 26986
What I Drive: 2002 Pitch Black SVT
FF Reputation: 1 pokeySVT Good Standing Member
Well I just finished this repair on my 02 SVTF. While it was not fun, it was not nearly as difficult as some people lead me to believe. I thought that it might be good to have a list of tips and tricks that I used for others in case anyone wants to attempt this repair.
(1). I started by removing my airbox and intake tube (I left the MAFS alone)
(2). Then I unclipped the fuse box from the fire wall and pulled it towards the front of the car to let me access the clutch hydralic lines.
(3). Move to the inside of the vehicle and remove the clutch pedal position sensor and the clutch interlock sensor.
(4). Unbolt the master cylinder from the pedal assembly bracket, a metric sized GearWrench will greatly speed up this process.
(5). Once the master cylinder was unbolted from the pedal assembly bracket I loosen the entire pedal assembly bracket, there are four nuts that need to be loosened and a looong extension will allow access to the top two.
(6). With the bracket loosened I moved back to the engine compartment and unbolted the junction block (where the lines pass through the fire walll), then I removed the clips that hold the hydralic lines in place.
(Tip!!) Here is a little trick to help stop fluid loss from the resevior, I pulled the rubber cap off of the clutch bleeder screw and put it on the line that runs from the resevior to the master cylinder.
(7). I found that it was easier to push the master cylinder back into the car as I removed the lower clutch line.
(Tip!!) Here is the second tip that I learned, make sure that you put the lower line back into the master cylinder before you bolt the master cylinder to anything.
(8). Reinstall in reverse order and have a friend help bleed the system.
All in all it took me about 1.5 hours to complete the repair, and I think that it is well within an average mechanics abilities, no special tools required.!!
Help me!!
pokeySVT is offline
    Quick reply to this message
Old 10-27-2005, 12:25 AM   #2
Portuga
Portuga's Avatar
Fan#: 22452
What I Drive: 2002 Blue Focus SVT
FF Reputation: 1 Portuga Good Standing Member
Did you get the newer updated part, the one that doesn't break down for no reason?
If so, what is the part number so I can order it?
SVT Squad #84
RP Engine\Trans Syntetic _ Fidanza Flywheel _ Clutchmasters FX100 _ VF Rear Engine Mount _ Hyp SRI _ Hyp 93 Oct Tune _ Grounding Kit _ Taylor 8.2mm Wires _ Autolite Double Platinums _ Clutch Sensor Mod
Portuga is offline
Old 10-27-2005, 02:09 PM   #3
pokeySVT
Fan#: 26986
I was not aware that there was an updated part #, I just got mine from the local Ford store. I will look-up the part number that I got and let you know
Help me!!
pokeySVT is offline
Old 10-28-2005, 01:03 AM   #4
WD40
The Librarian
WD40's Avatar
Fan#: 5157
It's a "sticky".
WD40 is offline
Old 11-05-2005, 05:07 PM   #5
pokeySVT
Fan#: 26986
Sorry about the delay, here is the part number that I used. 1M5Z-7A543-AA
hope that helps
Help me!!
pokeySVT is offline
Old 11-08-2005, 01:20 PM   #6
skicat
Fan#: 17600
FF Reputation: 1 skicat Good Standing Member
more tips?
This is a great post and much appreciated. Just a few of questions:
What is a GearWrench?
Did you bleed the system from the master? slave? both?
Where is the slave cylinder located?
Thanx for yr help.
skicat is offline
Old 09-06-2006, 09:50 AM   #7
elwood125
elwood125's Avatar
Fan#: 17784
What I Drive: Mk 3 Blue Candy SE Sport 5spd Hatch
Points 1,128, Level 18
Points: 1,128, Level: 18 Points: 1,128, Level: 18 Points: 1,128, Level: 18
Level Up 28% Completed
FF Reputation: 4 elwood125 Good Standing Member
the part # for an 00-01 is the ys4z-7a543-aa
is the 1m5z an improved part??
is clutch pedal travel a problem you have when this fails??
elwood125 is offline
Old 09-06-2006, 10:35 AM   #8
b16sir1991
Focused Focus
b16sir1991's Avatar
Fan#: 16612
What I Drive: 2004 SVT Focus, Sonic Blue
Points 12,236, Level 72
Points: 12,236, Level: 72 Points: 12,236, Level: 72 Points: 12,236, Level: 72
Level Up 47% Completed
FF Reputation: 175 b16sir1991 Excellent Standing Member b16sir1991 Excellent Standing Member
Buy-Sell-Trade Rating: (116)
That YS4Z# is for an early 2000-'01 model. 1M5Z-9A543-AB is the later one.
"The right driver can work magic"
Oct 2005 Ride of the month.
SVT Squad #25
Call me Mike......
Give rep points and feedback when you appreciate someone on here!
b16sir1991 is offline
Old 09-06-2006, 10:36 AM   #9
b16sir1991
Focused Focus
b16sir1991's Avatar
Fan#: 16612
Your part# superceeds to a 98AB-9A543-AH for the early ones.
SVT Squad #25
Call me Mike......
Old 09-11-2006, 08:46 AM   #10
elwood125
elwood125's Avatar
Fan#: 17784
so they are not interchangeable? I am still having clutch pedal travel issues and after replacing the clutch and slave cylinder, flywheel am getting a little panicky. any help advice would be nice.
elwood125@hotmail.com
Closed Thread
