Understanding :Adding Water/Meth Injection - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Closed Thread
Old 10-13-2005, 06:12 PM   #1
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,859, Level 100
Points: 51,859, Level: 100 Points: 51,859, Level: 100 Points: 51,859, Level: 100
Level Up 0% Completed
Forum Activity 30%
Buy-Sell-Trade Rating: (28)
There seems to be some that think that adding Water Meth Inj = WMI is a power adder that by using it you retune for it and it adds power
I cannot say enough DO NOT change the tune when adding WMI , there are soooo many things that can go wrong when adding WMI , pump go out , lines come loose , turn on switch not work , empty the Res , and on and on , If the tune is changed for the WMI and the WMI goes out this will 100% for sure cause an engine failure
I use WMI on many of my customers turbo and some SC kits but i never and will never change the tune to make more power with them , I use it STRICTLY to make the higher HP safer why into WOT and making high HP/TQ numbers
Air is HP/TQ and water takes the place of the air but i feel the benefit from the way the heat is reduced in the charge is worth the trade off but most of the cars i put them on are over 300HP at the wheels , anything below 200 to 250 in my opinion would be a waste of time because your just not moving that much air/psi and shouldnt be getting that hot unless you have heat soaking issues from poor piping placement
Use WMI as a safety adder ONLY i cannot stress that enough
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
    Quick reply to this message
Old 10-13-2005, 07:35 PM   #2
_RED_
Sonic's MK3 Crew #02
_RED_'s Avatar
Fan#: 10712
What I Drive: 2014 Fiesta ST
Points 41,251, Level 100
Points: 41,251, Level: 100 Points: 41,251, Level: 100 Points: 41,251, Level: 100
Forum Activity 3%
FF Reputation: 2 _RED_ Good Standing Member
Good info Tom
I think someone should make this a "Sticky"
'14 Fiesta ST
234 HP / 274 TQ
SCT Tune & Injen Intake, MBRP Catback
Moderator: Third Generation Ford Focus, DURATEC Ti-VCT GDI Performance Chat & Florida regional section
_RED_ is online now
Old 10-13-2005, 07:38 PM   #3
blanezx3
blanezx3's Avatar
Fan#: 764
What I Drive: 03 twi-blue zx3
Points 2,455, Level 30
Points: 2,455, Level: 30 Points: 2,455, Level: 30 Points: 2,455, Level: 30
Level Up 4% Completed
FF Reputation: 5 blanezx3 Good Standing Member
Buy-Sell-Trade Rating: (10)
Tom, maybe you can explain a little more about WMI and how you install it, how it works, etc. Make this the WMI sticky thread. *nod*
performance?
FR stg 2 cams, UR cam gears, FC 65mm TB, ported 2k manifold, 50lb injectors, FC race header, Bosal flex, Borla catback, Zex, Procharger, Xcal2
blanezx3 is online now
Old 10-13-2005, 10:48 PM   #4
Goat Roper
The Godfather
Goat Roper's Avatar
Fan#: 8634
What I Drive: 2003 Black ZTS
FF Reputation: 6 Goat Roper Good Standing Member
Stickied it is!
Scott Sweeney Photography
Goat Roper is offline
Old 10-14-2005, 04:27 PM   #5
barts
barts's Avatar
Fan#: 16187
FF Reputation: 1 barts Good Standing Member
Re: Understanding :Adding Water/Meth Injection
It can happen with an intercooled system air/water/air and all the people i know change the tune with that...so why it is different with the WMI?
barts is offline
Old 10-14-2005, 06:35 PM   #6
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 30%
Not realy if an air to water cooler fails the IAT will go up and timing will be pulled in the tuning , Like the STD tuning 200AIT takes out 40 Deg of timing
If WM fails and the engine was tuned for the WM there isnt anything to tell the sensors that controle the timing that is isnt working (read above)
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 10-15-2005, 06:42 PM   #7
IslandFocus
Fan#: 22161
What I Drive: 2000 Imperial Blue Focus ZX3
FF Reputation: 3 IslandFocus Good Standing Member
So Tom, just for clarification, if the WMI is placed before the IAT sensor, couldn't the timing be pulled once the IAT rises like in the case of the intercooler?
IslandFocus is offline
Old 10-15-2005, 07:37 PM   #8
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 30%
I think your asking IF the WM fails and the IAT go up the timing will be pulled to save the engine?
Yes it could but there are other issues that will come into play from spraying the IAT with WM , the bigges one is atated above , I have seen on a 95 deg day, the WM spraying before the IAT sensor the IAT go to 65 deg yet the true IAT were well over 110 , with IAT in the 65 range a ton of timing can be added and isnt needed because of the TRUE IAT being 110 and going up
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 10-15-2005, 08:36 PM   #9
03OrangeSVT
LETS TURN DIRT!!!!
03OrangeSVT's Avatar
Fan#: 19169
What I Drive: MINI Cooper S TURBO
FF Reputation: 152 03OrangeSVT Excellent Standing Member 03OrangeSVT Excellent Standing Member
Any news on the TB spacer so we can put the Meth/water after the throttle body?
I thought about putting it into the aluminum manifold, but I figured it would just get blown out since the intake doesn't seem to bo think enough to drill and tap.
[B]1951 McCormick FARMALL M
2007 MINI Cooper S Turbo... new project car
1998 Chevy 3500 Ext cab, long bed, 4x4, duelly, turbo diesel
2004 Harley V-Rod.... sex on wheels
2011 Harley Electra Glide Ultra Limited
[/b]
03OrangeSVT is offline
Old 10-17-2005, 01:11 AM   #10
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 236,661, Level 100
Points: 236,661, Level: 100 Points: 236,661, Level: 100 Points: 236,661, Level: 100
Forum Activity 3%
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
^^^ That would be a great way to go I would think..
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Closed Thread
