New Cylinder Head? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-26-2004, 10:41 PM   #1
jmltapp
Fan#: 2835
What I Drive: 2000 LX Sedan
FF Reputation: 1 jmltapp Good Standing Member
Unhappy New Cylinder Head?
Hey
Took my 2000 Focus in for a check up today. It has been idling badly on startup in the extreme cold (down to -30 some mornings). The emission light came on yesterday during a bad spell.
They have come back to tell me that the problems are due to carbon deposits building up on the valves between the stem and guides, and that the only option is to replace the cylinder head at a cost of $1000 in parts plus labor.
Surely a car on 55,000 miles shouldnt be looking at a newhead, and surely there must be other things that can be done to remove the deposits rather than replacing the head. I know Ford do not recomend use of gas treatments but do these work?
Opinions are gratefully recd, in 6 months the car has had $2000 in repairs done and I do not believe that this can be the only option available, despite the garages quote, and fords own repair release detailing this work.
Thanks for any help.
Jason
Focus LX
6 months of ownership, and only a transmission job, starter motor, ignition cylinder & keys, oil pressure switch, axle support bearing, new radio and cylinder head :O)
jmltapp is offline
Old 01-26-2004, 10:44 PM   #2
Kicknzx3
AKA Toyotech
Kicknzx3's Avatar
Fan#: 9
What I Drive: A few
FF Reputation: 1 Kicknzx3 Good Standing Member
Buy-Sell-Trade Rating: (4)
sounds like a sludge motor too me, usually caused by lack of maint. but it should not have the head replaced...only removed, go back to the dealer and see what else they say
2012 Toyota Camry SE
2012 Chevy Cruze LT/RS
2006 Ford Escape XLE V6
1991 Ford Mustang LX/5.0
Kicknzx3 is offline
Old 01-26-2004, 10:44 PM   #3
dudeman
Fan#: 2509
What I Drive: 2001 red zx3
FF Reputation: 1 dudeman Good Standing Member
i dont know what to say,i just hope someone can help you.as far as that stuff that u pour into the gas is concerned from what i hear it just ends up puttin wear on parts,but yall feel free to correct me if im wrong on this.
dudeman is offline
Old 01-26-2004, 10:53 PM   #4
Kicknzx3
AKA Toyotech
Kicknzx3's Avatar
Fan#: 9
What I Drive: A few
depends on the treatment used. i just reread ur statement, bring the car to a local shop thats good if possible, have them remove the tb, head, manifold and clean everythign thouroughly, if need be they could knurl and ream the head, add larger valves and install new seals...would be much less than going through a dealer
Kicknzx3 is offline
Old 01-27-2004, 04:52 AM   #5
focaltech
Fan#: 490
What I Drive: 2001 Pitch Black ZX3
FF Reputation: 1 focaltech Good Standing Member
Buy-Sell-Trade Rating: (-1)
Before you do anything go to another dealer and see if they give you the same answer.
Did you do proper maintenance to the car, change oil etc?
focaltech is offline
Old 01-27-2004, 08:21 AM   #6
jmltapp
Fan#: 2835
In the short time I have had it yes. When I asked the ford dealer if there was anything I could have done to cause it they said no, it is a known issue that ford recognizes in cars going back to 1997.
I am going to book it in with another garage and see what they say.
I have seen on the web that some people have had similar problems in Fords when the wrong grade of oil has been used. My last oil change was a week ago, and from speaking to the garage it sounds like 5w30 was used instead of 5w20. Possibility?
jmltapp is offline
Old 01-30-2004, 08:17 AM   #7
HotRodWagon
CostraNostraTabasco
HotRodWagon's Avatar
Fan#: 145
What I Drive: 02 Infra ZTW
Points 16,453, Level 82
Points: 16,453, Level: 82 Points: 16,453, Level: 82 Points: 16,453, Level: 82
Level Up 21% Completed
FF Reputation: 25 HotRodWagon Great Standing Member
Buy-Sell-Trade Rating: (38)
no
HotRodWagon is offline
Old 01-30-2004, 08:56 AM   #8
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
The engine was designed to use 5W30, and then amazingly it changed to 5W20 in a year. Its only to get more MPG out of the car.
Did you try running one of those fuel addatives that claim to clean your valves and pistons?
January 2008 Focus Fanatics ROTM
2003 Ford Focus ZX3 2.3l N/A = 221 HP, 162 ft-lbs, 13.967@100.88MPH
2006 Ford Fusion 2.3l Turbo = 244HP, 247ft-lbs
duratec.wikispaces.com - Duratec Wiki - Sign up and contribute!
Egz is offline
Old 01-30-2004, 10:26 AM   #9
had one
Fan#: 2516
What I Drive: 2002 Ford Focus SVT
FF Reputation: 1 had one Good Standing Member
I know---- but Chrysler motors makes a very good valve and combustion area cleaner. Follow the direction on the can and it should help. Yes I know it is numbling to go to Chrysler but.
1158 of 4788
had one is offline
Old 02-02-2004, 04:52 PM   #10
jmltapp
Fan#: 2835
Ok, took car to an independant garage. They have diagnosed an ignition fault involving the spark plug wires and the coil.
The work has yet to be done, but surprisingly after they looked at it, its running better, and the check engine light has now gone off and stayed off.
I am gonna replace the wires and coil this week and see how it goes, but as far as they were concerned definately no fault with the head.
We will see what happens.
Thanks all of you for your advice and input.
Jason
jmltapp is offline
Similar Threads
DTC Codes (Detailed Descriptions) S2 General Technical Chat 13 12-11-2006 12:06 PM
zetec cylinder head craze173 Central Florida Motorsports 0 09-07-2006 07:48 AM
Cylinder head lowslowzx3 Archive 0 03-09-2006 12:11 PM
cosworth zetec cylinder head Spec3VR6 SVT Performance (2002-2004) 7 03-03-2006 12:01 AM
Changing the FocusSport Cylinder head compression dwdgsi03 General Technical Chat 4 07-28-2005 01:26 PM
