How to: Paint your Headlights 2005 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-20-2005, 09:58 PM   #1
HeelToe
HeelToe's Avatar
Fan#: 27666
What I Drive: 05 CD Silver ST
Points 7,273, Level 56
Points: 7,273, Level: 56 Points: 7,273, Level: 56 Points: 7,273, Level: 56
Level Up 62% Completed
FF Reputation: 3 HeelToe Good Standing Member
Buy-Sell-Trade Rating: (-1)
Ok well as I said I would I'm making this write up for painting the inside of your 2005 Focus headlights black.
Materials needed:
Black paint (recommend gloss finish)
Silicone Sealant
Scour pad
Beer
Masking tape
Tools needed:
10mm wrench
8mm wrench
Phillips screwdriver
Flathead screwdriver
torx bits (allens will work but torx will be better)
Car jack
Your hands
Razor Blade
Time require:
Total - 12-48hrs
Headlight removal - 30min - 1hr
Headlight opening - 2-3hrs
painting - 2-3 hrs
paint dry time - at least 1hr
Headlight reassembly - 30min - 1hr
Sealant cure time - at least 8hrs
headlight reinstall 30min - 1hr
Step 1
Using a Phillips screwdriver Remove the Black plastic radiator shroud.
Step 2
With a 10mm wrench loosen the two bold hold the upper grill to the radiator frame. Then while pulling forward lift the two clips on either side of the hood latch to remove the upper grill.
Step 3
Using a 10mm wrench loosen the top two bold on the headlight assembly.
Step 4
Using a car jack lift the side of the car to lower the wheel to gain access to wheel well shroud.
Step 5
Loosen and pull wheel well shroud back using a 8mm wrench and torx bit or allen wrench.
Step 6
Using a 10mm wrench loosen and remove the third and final bolt holding the headlamp assembly on the vehicle.
Step 7
Turn on oven to 200 degrees.
Step 8
While oven is warming remove the rubber trim from the headlamp assembly.
Step 9
After oven as fully warmed place one headlamp on a baking/cookie sheet in the oven for about 15minutes.
Step 10
Pull out the headlamp. CAREFUL ITS GOING TO BE HOT! I'd wear some sort of oven mitt or work glove to handle the headlamp.
While the head lamp is still hot using a thin flathead work around the edge of the headlamp seal to break the seal.
**NOTE**
You may have to repeat steps 9 & 10 several times over in order to fully break the seal.
Step 11
Once the clear plastic cover is removed from the black plastic housing you will have to next remove the chrome trim that is going to be painted from the clear plastic housing. TO do use remove the 2 bolts with either a torx bits or allen drive to do so.
Step 12
Mask off the area not to be painted. I'd suggest masking of at least the turn signal reflector to keep the fuzz from giving you grief. Using a razor blade to cut the outside edge of the reflector seemed to work well for me.
Step 13
This step is important. Rough up all the surfaces to be painted with the scouring pad so the paint will stick to the plastic. Not doing so will result in poor adhesion of the paint.
I personally forgot this step so I didn't get as good as results as I should have.
Step 14
Pop the next headlight in the oven
Step 15
Paint. Make sure to paint in several thin layers as to one thick one. The will help avoid runs and still provide good coverage and overall consistency.
Step 16
Have a beer.
Repeat steps 9 thru 15 for your second headlight.
Allow the paint to dry at least an hour before handling.
Step 17 remove the tape from the now black trim. And reinstall the painted trim into the clear housing. Don't forget the 2 screws that holds on to the clear plastic.
Step 18
Using the silicone sealant run a good thick bead around the black housing where the clear plastic seats into the black housing.
Step 19
Using some tape, tape the two parts together tightly and let it sit at least 8 hours.
Step 20
Remove tape and marvel at you new hotness of headlights.
Step 21 Perform steps 1-6 in reverse order.
DONE!!! Now you have a unique 2005 Focus that all your friends will drool over.
Please Note
This how-to is nothing but merely a guide on the best methods to go about the project. I do not take any responsibility of any ill-effects that occur to you vehicle from this mod or any legal issues they may arise do to the modification of your cars headlight system. PERFORM AT YOUR OWN RISK!
-Matt
ST Crew #26
We would have ruled it as an accidental shooting but you reloaded... twice.
HeelToe is offline
Old 09-20-2005, 10:01 PM   #2
SJB
SJB's Avatar
Fan#: 17261
What I Drive: 01 zx3
FF Reputation: 1 SJB Good Standing Member
sweet write up but i would feel weird putting my headlight in an oven
Zetec Crew #25 Whoever said "knowledge is power" never got blown off by some pimple-faced kid in a ratty trans-am after screaming, " The area of the square built upon the hypontenuse of a right triangle is equal to the sum of the areas of the squares upon the remaining sides!"
SJB is offline
Old 09-20-2005, 10:02 PM   #3
Zach16789
Fan#: 1790
What I Drive: 2000 Pitch Black ZX3
FF Reputation: 1 Zach16789 Good Standing Member
Very nice how to, and amazing looking lights, have to say this is the best headlight work i have seen, good job.
Zach16789 is offline
Old 09-20-2005, 10:13 PM   #4
Kamui
Fan#: 10647
What I Drive: 2003 Infra-Red ZX3 5SP Zetec
FF Reputation: 1 Kamui Good Standing Member
Very nicely done and great write up (y)
Saving money for a new car ^^
Maybe a 350Z >.>
Kamui is offline
Old 09-20-2005, 10:15 PM   #5
fspeed
fspeed's Avatar
Fan#: 21082
What I Drive: 2003 Liquid Grey ZX3/ 97 dodge ram
FF Reputation: 1 fspeed Good Standing Member
Maybe this will go to the "How-to". Great write up. The oven thing is weird, but hey, it works.
-chris
Zetec Crew #13
cruisin' low n' slow
fspeed is offline
Old 09-20-2005, 10:17 PM   #6
cpyder
cpyder's Avatar
Fan#: 150
What I Drive: 2007 Focus SES
FF Reputation: 1 cpyder Good Standing Member
Congrats..... are they eatable after baking...
Very nice job.
"There is more room for the boom."
cpyder is offline
Old 09-20-2005, 10:24 PM   #7
2005sangriaZX3
2005sangriaZX3's Avatar
Fan#: 25773
What I Drive: 2004 Merc Grand Marquis
FF Reputation: 1 2005sangriaZX3 Good Standing Member
very cool and looks awesome! I would be afraid that I would screw something up though.
MECP Master Certified Autotech
Milwaukee, WI
2005sangriaZX3 is offline
Old 09-20-2005, 10:29 PM   #8
Onyx flash
Onyx flash's Avatar
Fan#: 19859
What I Drive: 05' pitch black ZX3
FF Reputation: 1 Onyx flash Good Standing Member
Buy-Sell-Trade Rating: (10)
OMG your a friggin genious that would look so awesome on my black ride man.
great write up.
what brand paint did you use, and i have a gas oven :would this work in this project?
Onyx flash is offline
Old 09-20-2005, 10:37 PM   #9
JohnMichael
Michael J. Caboose
JohnMichael's Avatar
Fan#: 21469
What I Drive: Black Hemi Ram & Honda Shadow VT600
FF Reputation: 7 JohnMichael Good Standing Member
Wowsers, looks totally great! If I had an '05, I would be doing this pronto...definitely should make the How-To Archive!
Cap America and Deadpool walk into a bar, Cap orders a glass of milk, because he's Cap. DP orders a glass of Human Crap, because he's Deadpool.
O'er Pirates from the Black of Pitch
JohnMichael is offline
Old 09-20-2005, 10:39 PM   #10
Onyx flash
Onyx flash's Avatar
Fan#: 19859
^^^^^ditto(archive)
