Check engine light codes & meanings - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-20-2005, 03:41 AM   #1
focusin
FF Cleaning Squad
focusin's Avatar
Fan#: 4322
What I Drive: All Focus' sold
FF Reputation: 63 focusin Excellent Standing Member
Buy-Sell-Trade Rating: (17)
This is for those of us with a Flasher with CEL reading options or OBD-II Scanners.
PO102---- Mass airflow (MAF) Sensor circuit low input
PO103---- Mass airflow (MAF) Sensor circuit high input
PO106---- Barometric pressure sensor circuit performance
PO107---- Barometric pressure sensor circuit low voltage
PO108---- Barometric pressure sensor circuit high voltage
PO109---- Barometric pressure sensor circuit intermittent
PO112---- Intake air tempature (AIT) sensor circuit low input
PO113---- Intake air tempature (AIT) sensor circuit high input
PO117---- Electronic coolant tempature (ECT) sensor circuit low input
PO118---- Electronic coolant tempature (ECT) sensor circuit high input
PO121---- In range Throttle posistion sensor (TPS) fault
PO122---- In range Throttle posistion sensor (TPS) circuit low input
PO123---- In range Throttle posistion sensor (TPS) circuit high input
PO125---- Insufficiant Coolant Tempature
PO127---- Intake air tempature sensor "A" circuit
PO131---- Upstream heated O2 sensor low voltage (Bank 1)
PO133---- Upstream heated O2 sensor circuit slow response (Bank 1)
PO135---- Upstream heated O2 sensor heater circuit fault (Bank 1)
PO136---- Downstream heated O2 sensor fault (Bank 1)
PO141---- Downstream heated O2 sensor heater circuit fault (Bank 1)
PO151---- Upstream heated O2 sensor low voltage (Bank 2)
PO153---- Upstream heated O2 sensor slow response (Bank 2)
PO155---- Upstream heated O2 sensor heater circuit fault (Bank 2)
PO156---- Downstream heated O2 sensor fault (Bank 2)
PO161---- Downstream heated O2 sensor heater circuit fault (Bank 2)
PO171---- System adaptive fuel too lean (Bank 1)
PO172---- System adaptive fuel too rich (Bank 1)
PO174---- System adaptive fuel too lean (Bank 2)
PO175---- System adaptive fuel too rich (Bank 2)
PO176---- Flexable fuel sensor "A" circuit
PO181---- Enginefuel tempature sensor "A" circuit range
PO182---- Enginefuel tempature sensor "A" circuit low input
PO183---- Engine fuel tempature sensor "A" circuit high input
PO186---- Engine fuel tempature sensor "B" circuit range
PO187---- Engine fuel tempature sensor "B" circuit low input
PO188---- Engine fuel tempature sensor "B" circuit high input
PO190---- Fuel rail pressure sensor circuit performance
PO191---- Injector pressure sensor system performance
PO192---- Injector pressure sensor low input
PO193---- Injector pressure sensor high input
PO300---- Random misfire
PO301---- Cylinder #1 misfire detected
PO302---- Cylinder #2 misfire detected
PO303---- Cylinder #3 misfire detected
PO304---- Cylinder #4 misfire detected
PO320---- Ignition engine speed input circuit performance
PO325---- Knock sensor circuit fault
PO326---- Knock sensor circuit performance
PO330---- Knock sensor 2 circuit malfunction
PO331---- Knock sensor 2 range
PO340---- Camshaft position sensor circuit malfunction
PO350----Ignitioncoil primary/secondary circuit malfunction
PO351---- Ignitioncoil #1 primary circuit fault
PO352---- Ignitioncoil #2 primary circuit fault
PO353---- Ignitioncoil #3 primary circuit fault
PO354---- Ignitioncoil #4 primary circuit fault
PO400---- EGR flow vault
PO401---- EGR insufficient flow detected
PO402---- EGR excessive flow detected
PO411---- Secondary air injection system upstream flow
PO412---- Secondary air injection system circuit malfunction
PO420---- Catalyst system efficiency below threshold (Bank 1)
PO421---- Catalyst system efficiency below threshold (Bank 1)
PO430---- Catalyst system efficiency below threshold (Bank 2)
PO431---- Catalyst system efficiency below threshold (Bank 2)
PO442---- EVAP Small leak detected
PO443---- EVAP VMV circuit fault
PO451---- FTP sensor circuit noisy
PO452---- EVAP fuel tank pressure low input
PO453---- EVAP fuel tank pressure high input
PO455---- EVAP control system leak detected, very small leak
PO457---- EVAP control system leak detected, fuel filler cap loose/off
PO460---- Fuel level sensor circuit malfunction
PO500---- VSS Malfunction
PO501---- VSS range
PO502---- VSS intermittent
PO505---- IAC valve system fault
PO552---- Power steering sensor circuit malfunction
PO553---- Power steering sensor circuit malfunction
PO602---- Control module programing error
PO603---- PCM keep alive memory test error
PO605---- PCM read only memory test error
PO703---- Brake switch circuit input malfunction
PO720---- Out put shaft speed sensor, insufficient input
I hope this helps, it came straight from Haynes Repair manual which can be bought at any auto parts store.
Jon
Retired Moderator
GumpCrew #1 (dismantled)
focusin is offline
Old 10-04-2006, 04:26 AM   #2
RSVT170
FocusRush
RSVT170's Avatar
Fan#: 28451
What I Drive: '13 ST2 & '05 ZXW
Points 15,294, Level 79
Points: 15,294, Level: 79 Points: 15,294, Level: 79 Points: 15,294, Level: 79
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
FF Reputation: 42 RSVT170 Great Standing Member
Buy-Sell-Trade Rating: (13)
Here are a few more
P1131 - Lack of H02511 Switches Indicates Lean (See P2195)
P1246 - Alternator Load Input (See P0622)
P1270 - Engine RPM or Vehicle Speed Limiter Reached
HATCH NATION #139 | 2013 ST2 "P5" | 2004 SVT EAP "P9" | FocusRush.com
RSVT170 is offline
Old 10-04-2006, 05:56 AM   #3
SC7672
Fan#: 39795
What I Drive: 2001 Mustang Bullitt
FF Reputation: 1 SC7672 Good Standing Member
My wifes sisters car shows the code PO442---- EVAP Small leak detected
Now the problem is where is the leak coming from. Anyone have any ideas
where to start? I already replaced the gas cap with a new one,so its not that
from what I can tell. Any help here woould be great.
PS
I am new here, so be gentle with me Thanks for having forums like this
to try and help.
SC7672 is offline
Old 10-26-2006, 08:49 PM   #4
lomita
Fan#: 40561
FF Reputation: 1 lomita Good Standing Member
CEL
Can anyone direct me where to find the plug in for the Check Engine Light module code reader? Thanks. Lomita
lomita is offline
Old 10-27-2006, 09:05 PM   #5
FF Founder
Tom's Avatar
Fan#: 2
What I Drive: 2005 Saleen ZX3 SES Turbo
Points 86,036, Level 100
Points: 86,036, Level: 100 Points: 86,036, Level: 100 Points: 86,036, Level: 100
Level Up 0% Completed
FF Reputation: 60 Tom Excellent Standing Member
Buy-Sell-Trade Rating: (7)
Its underneath the dash and left of the hood release.
Tom is offline
Old 10-27-2006, 10:06 PM   #6
lomita
Fan#: 40561
Thanks Tom, will check it out tomorrow in the daylight. Also going to get a copy of the Haynes manual at Pepboys.
lomita is offline
Old 10-28-2006, 04:32 PM   #7
lomita
Fan#: 40561
Good news Tom, I found the receptacle. If it had been any closer it would have bit me. I can chock it up on wearing my midrange glasses instead of my bifocals. Anyways, found a hose hissing under the hood, $27 for the hose replacement from Ford, (EGR hose), plugged in the OBD II reader, it went through the process, blinked a couple of times, the fault codes cleared, and the check engine light extinguished. Mission accomplished. Thanks for the directions. Fred
lomita is offline
Old 10-28-2006, 05:43 PM   #8
FF Founder
Tom's Avatar
Fan#: 2
Nice, glad you've found it as well as the problem and thanks for the update.
Tom is offline
Old 10-28-2006, 06:14 PM   #9
jlemond
jlemond's Avatar
Fan#: 30058
What I Drive: 09 Subaru Impreza WRX OBP (Black)
FF Reputation: 1 jlemond Good Standing Member
The P0420 has to do with your exhaust. Either you O2 sensor or Cat. The cat has a 100,000 mile warranty. Just thought you all might want to know.
R.I.P. 2003 CD Silver ZX3 3-9-09
Team Duratec #44,Team D23 #8, Team So-Cal D23 #1
jlemond is offline
Old 11-16-2006, 03:31 PM   #10
FellowsDrake
FellowsDrake's Avatar
Fan#: 34502
What I Drive: 2001 Blue SPI 5spd
FF Reputation: 3 FellowsDrake Good Standing Member
hey, you guys do know that the focus has it built into it right? Hold the odo button, start the car, continue to hold the button till u see ur needles go *WHHEEEEEZE* (go up and down) the second the move, let go. Using the odo button you can cycle through many modes. There will be a time when it will flash DTC then a number or NONE. Check that. This works with almost any ford that has a digital ODO PLease see the original post in the performance forum that reads "The tach you never new you had" Spelled just like that in the SPI performacne forum.
Originally Posted by Focusnewb View Post
Do your own repairs, it's not rocket surgery !!
FellowsDrake is offline
