#1 | ||||
throttle body problem
I just installed a 65mm throttle body on my 2003 ford focus, manual transmission. a list of my mods are: stage 3 comp cams, dark force cai, msd ignition, obx headers, custom duel exhaust 2.5". I have no problems in first gear. But if i pop the clutch u know where u bark the tires when u shift (jam down on the throttle when u let the clutch up). the car bogs out. Doesnt die just no power till i take my foot off the gas and rehit the throttle and it goes with no problem.
now if i easy the clutch and gas with each other doesnt have to be slow. but no tire barking it dont do it. What would be causing this problem? Can it be im not able to supply enough fuel on the stock fuel regulator for the extra air im adding due to the cams. i need your help. but other than that i can feel a huge difference in the throttle body. |
Remove Advertisements |
Fan#: 1
#2 | ||||
do you have a tune? where are you shifting at wot? if you dont have a tune then that might be your major problem. anybody please correct me if i'm wrong. also, you might not have enough backpressure due to your exhaust being so open. duel exhaust works great on a mustang, but I wouldn't have it on a focus. do you have any head work done(port and polish, 3 angle valve job)? I can see a few different factors here, but again, if I'm going out in left field, then ignore me.
02 Black ZX3 5-spd. anti squad/crew member #2 |
#3 | ||||
I would also check your fuel pressure, maybe a weak fuel pump, after a heavy accel and then you add the engine load of second gear scratch may not have enough fuel
#4 | ||||
if been told now by like 3 mechanics that im not getting enough fuel. So lets see im going to look into getting my ecu reprogrammed locally and have the fuel pressure jumped up. I know some pretty repable people around jacksonville Fl that will do it for me.
#5 | ||||
back pressure on my car aint no problem. I kept the stock flex pipe so i wouldnt run into problems. and the exhause is single till the end then it splits off too two. I dont think its problems with the head. I think i need to take it in for tunning. So i can get the fuel bumped up. Ive been told by 1 ase master mechanic 1 ase mechanic and some friends who race for a living that im not getting enough fuel in the combustion chambers. They say i need to have the fuel pressure increased to add more fuel diffently when the cars at wot. ill be calling some places around to see about tuning and how much.
#6 | ||||
Re: throttle body problem
k a few things:
however, it could be something as simple as you not putting your tps on right... that'll foobar your car's mixture... check that first... THEN get tuned!!!
Past: 2001 Blue Focus ZX3 - ('03-'05) Boltons and S2 wing. I miss you ------2001 Red Focus ZX3 S2 - ('07-'12) Have fun at Auction ------2008 Red Mazdaspeed 3 GT - ('08-'11) Sold Present: 2005 Silver Focus 2.3L ST Sedan - 5-speed w/all the options |
#7 | ||||
ya i checked my tps and tried it stock direction and flipped. seems to work better flipped. so im going to call around and see how much it is to tune my ecu till i can get the chip.
#8 | ||||
sorry about the exhaust thing, I assumed you had true dual exhaust for some reason.
#9 | ||||
ok just talked to focus sport about the sct chip for the focus. I told him all the mods i had done to my car and asked him what options i need to have done to the chip to get the car to run correct. their answer is "increased fuel pressure, raise idle, rear o2 sensor disabled and the rest is gravy." very fast reply on their behalf. and its exactly what i wanted to do also. So if u all run into problems like i just did theirs your answer of what u need to get done.
#10 | ||||
Jetsetter
with the new tb it might be a good idea for some new injectors and fuel rail and maybe then you will get your tires to bark when going into second gear again?!?!?
ZETEC Crew #26 SR #20 YELLOW BLAZE OWNERS GROUP#4 Moderator Pilot, 2 foci Owner! 04 SE Sedan [P RNDL], 12 SE HB ╠╬╝ Ford Focus Discussions, Ford Focus Marketplace, Ford Focus Tech Discussions, Movies & Music Fanatics, Regional Forums Advocare 24 Day Challenge! |
| Thread Tools | |
| Display Modes | |
