"How To" Broken DSI Clip Fix - Page 6 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus SVT > SVT Performance (2002-2004)
Old 05-23-2006, 01:55 PM   #51
daddio69
daddio69's Avatar
Fan#: 35355
What I Drive: 2002 INFRA-RED SVTF
FF Reputation: 1 daddio69 Good Standing Member
well after looking and looking i finally found somewhere to do this-thanks alot man i really really appreciate it-but let me ask you-i did everything just as you stated to do and the noise stops-but when i shut my car off and re-start it the noise comes back for like maybe 5 sec. then its gone-did i do something wrong or is there a quick fix-i disconnected the battery and re-programmed but it still does it only on start up??????
daddio69 is offline
Old 05-23-2006, 05:13 PM   #52
WD40
The Librarian
WD40's Avatar
Fan#: 5157
^^^You're cool...don't worry.
You'll hear that noise at start up, because when you shut the car off, the DSI defaults back to the short runner position.
When you fire it up, the IMRC will pull the DSI back to the long runner position.
Perfectly normal.
WD40 is offline
Old 05-23-2006, 07:35 PM   #53
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 mazdaspeed3
Points 4,094, Level 40
Points: 4,094, Level: 40 Points: 4,094, Level: 40 Points: 4,094, Level: 40
Level Up 72% Completed
Forum Activity 6%
FF Reputation: 22 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (17)
Wow, my mechanic Rojas must of saw this thread when he was fixing my broken shifter linkage cables (yeah right!). When I picked it up I noticed a bolt driven thru the clip. Must of pulled the DSI wire too hard when installing the cables.
I now drive a Japanese Ford.
macdiesel is online now
Old 05-23-2006, 09:53 PM   #54
daddio69
daddio69's Avatar
Fan#: 35355
well i have never heard that noise before-it is making the same noise that it did when the cable was off-the only difference is now it only last for 5 sec. or so-plus my check engine light is still on-i triple checked and the bolt is still hilding the wire on so i have no idea what it could be-
daddio69 is offline
Old 07-08-2006, 11:36 AM   #55
TacBear
Fan#: 17195
What I Drive: Sonic Blue SVT 3 door #3601 of 4788
FF Reputation: 1 TacBear Good Standing Member
I fixed the DSI Clip and mine does the same thing on start up--I hear the actuator pull the cable 4-5 times then it stops and my check engine light comes on. The code is "Intake runner stuck open".
Does this mean the actuator is bad? When the clip first broke my wife drove the car with the actuator making noise for about 50 miles.
2004 Expedition XLT (company car)
2002 Supercharged DSG Harley Davidson F150 #6549 of 12,000 14.75@94
2002 SVT Sonic Blue Focus #3601 of 4788
2000 Mustang GT Vortech V2 SQ trim (white Cobra"R" clone) 12.90@110 spinning in 2nd and 3rd.
TacBear is offline
Old 08-20-2006, 06:20 AM   #56
Jason2o
Fan#: 36872
What I Drive: 2002 Black w/blue SVTF
FF Reputation: 1 Jason2o Good Standing Member
I have this exact problem as well what ever came of it?? Except i dont have the cel and error code..
Jason
Edit: Fixed the DSI clip mine was broken but i still get the throttle pulsing on startup..?!
EDIT: ALSO A QUICK NOTE, THE CAR PASSES CALIFORNIA SMOG WITH NO PROBLEMS WITH THE DSI CLIP BROKEN AND THE RUNNERS SPRINGING TO DEFAULT POSITION. JUST AN FYI..
Jason2o is offline
Old 10-27-2006, 03:06 PM   #57
Raziel510
Fan#: 2098
What I Drive: 2003 Sonic Blue SVT Focus
FF Reputation: 1 Raziel510 Good Standing Member
I got the same problem as TacBear, fixed up the clip, turned on engine and noise cycles like 4-5 times and then CEL comes on. says intake runner stuck open/closed
Where can I get the parts to fix this problem? I miss my DSI
Raziel510 is offline
Old 10-27-2006, 04:59 PM   #58
RocFoc
Fan#: 34856
What I Drive: 02 Black SVT ZX3
FF Reputation: 1 RocFoc Good Standing Member
Sounds to me like the screw was run in too far, and it is interfering with the rotation of the DSI unit. See if you can swing it fully by hand with no binding.
02 SVT Focus ZX3
04 SVT Cobra
RocFoc is offline
Old 10-27-2006, 10:36 PM   #59
dundadda
dundadda's Avatar
Fan#: 10911
What I Drive: Silver SVT
FF Reputation: 1 dundadda Good Standing Member
Mine does the same thing with the 5 second noise and the CEL code and i did not use a screw to reattach the actuator cable i drilled out the reminder of the post and stuck the end of the cable in the broken ckip ands squirted a whole bunch of superglue on it.
I actually had assumed that the cable was a little slack as a result of my jimmy rigging and thought that was the cause of the actuator noise. Has anyone had a broken clip replaced and had no issues with the 5 second noise at startup?
I really want to replace the clip with the Central Florida Motorsports all metal one i purchaced but i just cant get the old clip off its post. I really do not want to fully dissasemble the whole assembly just to replace the clip. I tried popping the lock ring off the post and pulling on the clip and it does not budge.
Any ideas?
Scott
dundadda is offline
Old 10-28-2006, 11:41 AM   #60
Raziel510
Fan#: 2098
hmmm, ok I tried to move it by hand and there was a lil bit of binding. So i readjusted the screw and then tried to move it by hand again. No binding the second time around. Cleared the CEL with the SCT tuner got codes P0135 and P1518, started her up and the noise is still there so took it out for a test run, nothing out of the ordinary. Came back to my driveway and turned her off then back on and noise cycles again and CEL came back on, so does this mean that I need to replace the whole DSI unit???
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
