Write-up: How to determine approx. HP gains from removing weight! - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Discussions > Ford Focus & General Car Chat
Old 08-11-2005, 02:04 PM   #1
Taiden
Fan#: 26198
What I Drive: 94 Grand Cherokee 55k mi, standard
FF Reputation: 1 Taiden Good Standing Member
Post Write-up: How to determine approx. HP gains from removing weight!
Okay, want to know how to figure out how many lbs = hp? It's quite easy really! Follow these steps, and you'll be able to estimate "hp gains" from removing weight from your Focus!
Car Weight / HP = pounds per HP -or- how many pounds you take off to get 1 hp
((Weight/HP Data Taken from Edmunds.com))
Stock 2003 ZX-3 Zetec: 2598 lbs 130 hp
2598lbs / 130hp = 19.9 lbs/hp
For each 19.9 lbs you remove from your car, you will be getting the equivalent of 1 hp. HOWEVER, when you remove weight the gross weight of your car reduces (obviously) so to figure out how much you need to remove again, you must replug the numbers.
Example:
2598lbs / 130hp = 19.9lbs/hp
Remove 200 lbs? That gives you a gain of approx. 10hp. Now, let's say you want to remove more weight.
2598lbs - 200lbs = 2398 lbs, your current weight.
Since you haven't actually increased your engine HP, we are still using 130 as our number.
2398lbs / 130hp = 18.4 lbs/hp, so now lets say you remove 200lbs more. Now you've gained an approx. 11 HP.
How do you gain HP from taking off weight? In reality you aren't, but since you're car is lighter, it's easier for your engine to move it. Instead of thinking of it as "gaining HP" think of it as "allowing more HP to be used to increase your cars speed/accel instead of trying to get it to move."
A good example is pushing your friend in a shopping cart! (If that's what you do in your spare time. ) Your skinny friend is really easy to get going fast, whereas if you push just as hard, your fat friend will take longer to get going the same speed. By making the fat kid go on a diet, it would make him easier to get going faster even if you were pushing just as hard!
So now you're thinking, "400 lbs = 21hp? Alright!" here's food for thought.
Average AC in a car = 80 lbs
Average Backseat = 40 lbs
Average dampening tar = 15 lbs
Total? = 135 lbs, or about 7 hp from stock.
Now the real question lies, is it worth taking away your backseat and your AC and making your car sound like a tin can for 6 hp? Not for me!
-Taiden
[--- Added 11/8/05 9:23 EST ---]
Figuring Sprung Weight Equivalents for Rotational Mass
Originally posted by havoc7476
what about rotational mass like wheels and brake rotors. how would you figure that out, cause its rotating and changes with the speed of your car.
Well, it depends on how Carrera is figuring these ratios. Carrera, in the rotational weights, are you including the subtraction of the raw weight itself?
Originally posted by Carrera26
And don't forget the ratio of weight loss.
Sprung weight = 1:1 ratio
Unsprung Rotational weight = 1:3 ratio
Driveline Rotational = 1:15 ratio
Example:
The 1:3 Ratio of Unsprung Rotational Weight may just be referring to the rotational properties, and ignoring the fact that scale measureable weight is also being removed.
To answer your question though, assume that you just use the ratio flat out without any conversions, and you'll be close. Want an example? Great! Here's one.
2600 lb Car
30 lb Flywheel stock (I have no idea what the actual weights of Flywheels are, I'm just guessing here.)
20 lb Flywheel upgrade
Since we're losing weight on the flywheel, that's considered Driveline Rotational Weight, which is a 1:15 ratio. This means, take the weight, multiply it by 15, and that's how much "normal weight" you're removing.
30 lb stock
20 lb upgrade
10 lb loss in DRIVELINE ROTATIONAL WEIGHT
10 lbs x 15 = 150 lbs Sprung Weight Equivalent.
This applies to accel/quarter mile based equations only, not handling/slalom!
When you're thinking about handling, consider it to be 10 lbs Sprung Weight.
Thank you Carrera for those Ratios!
I doubt anyone on a Focus board would be interested, but I'm selling a '94 Jeep Grand Cherokee with 55k miles, all power options and a manual tranny. PM for details. :)
Taiden is offline
Old 08-11-2005, 02:06 PM   #2
b16sir1991
Focused Focus
b16sir1991's Avatar
Fan#: 16612
What I Drive: 2004 SVT Focus, Sonic Blue
Points 12,236, Level 72
Points: 12,236, Level: 72 Points: 12,236, Level: 72 Points: 12,236, Level: 72
Level Up 47% Completed
FF Reputation: 175 b16sir1991 Excellent Standing Member b16sir1991 Excellent Standing Member
Buy-Sell-Trade Rating: (116)
LOL, nice point.
"The right driver can work magic"
Oct 2005 Ride of the month.
SVT Squad #25
Call me Mike......
Give rep points and feedback when you appreciate someone on here!
b16sir1991 is offline
Old 08-11-2005, 02:19 PM   #3
eazyrider_tim
eazyrider_tim's Avatar
Fan#: 7011
What I Drive: 2005 Ford Focus ZX4 SES Gloss Black
FF Reputation: 2 eazyrider_tim Good Standing Member
Buy-Sell-Trade Rating: (4)
agreed, never understood the taking out spare tires/back seats, lol
Thats like leaning forward going downhill on a girls bike, you make look like you are going faster, but just look like a
eazyrider_tim is offline
Old 08-11-2005, 05:18 PM   #4
Kneel
Kneel's Avatar
Fan#: 6590
What I Drive: '05 Sonic Blue Escape
FF Reputation: 1 Kneel Good Standing Member
Weight reduction will improve performance, but not HP.
There are only 3 sports, Bullfighting, Motor Racing and Mountain climbing. All the rest are games.
Earnest Hemingway
Kneel is offline
Old 08-11-2005, 05:30 PM   #5
oneill8769
Fan#: 12797
What I Drive: 2006 Whitewater Pearl Mazda3 Hatch
FF Reputation: 4 oneill8769 Good Standing Member
^^^ exactly.
Mazda3 Traitor Party #2
oneill8769 is offline
Old 08-11-2005, 06:09 PM   #6
Carrera26
Carrera26's Avatar
Fan#: 12237
What I Drive: 2005 Mazda3 2.3/2003 VW Passat GLX
FF Reputation: 2 Carrera26 Good Standing Member
Not to mention the much more impressive HANDLING benefits that result from strategic weight loss. Losing 80lbs of AC might not be a ton of help in the 1/4 mile, but it will make a very noticeable difference in handling. (Especially front-end response and grip)
Don't waste another minute waiting on parts, or anything else. Just get out there and start racing! You will suck at first, and you will be slower than many other cars, but the only thing you will regret is not starting earlier...
Carrera26 is offline
Old 08-11-2005, 06:30 PM   #7
SD_Focus
New Member
SD_Focus's Avatar
Fan#: 11575
What I Drive: 2001 BMW Z3 Roadster 3.0
Points 7,903, Level 59
Points: 7,903, Level: 59 Points: 7,903, Level: 59 Points: 7,903, Level: 59
Level Up 77% Completed
FF Reputation: 34 SD_Focus Great Standing Member
Buy-Sell-Trade Rating: (14)
Those calculations are silly. If I take 1,000 lbs off of that 2,600 pound car, its going to be faster than a 50 horsepower difference. My bike weights something like 400 lbs and has 96 horsepower. If I took off 2198 lbs to make that focus 400 lbs then that would be a 110 hp increase? Sorry but a 240 hp 2,600 pound car isn't gonna keep up with my bike, but a 130 hp 400 lb. car would beat the hell out of it. Those calculations might make sense for maybe the first 100 pounds you lose.
SoCal Crew #21
SD_Focus is offline
Old 08-11-2005, 06:58 PM   #8
Taiden
Fan#: 26198
It's silly because you aren't realizing the the equation works on a curve. Every time you remove weight, you have to redo the equation and it gives you a new lb/hp ratio.
Example: if your car is 1000lbs and you remove 100lbs, and then another 100lbs you will get a different amount of HP "increase" with the equation than if you take 50 lbs off and then 150 lbs off. The more you rerun the equation and add up the gains, the more accurate you will be. If you run the equation for every 1 lb you remove, it will be accurate and make more sense. I hope that made sense.
To summarize, when your weight changes so does your lb/hp ratio, so everytime you change the weight you must run the equation a second time. To make your math more accurate, if you run the equation for each pound you remove it will be far more accurate.
Taiden is offline
Old 08-11-2005, 07:11 PM   #9
havoc7476
havoc7476's Avatar
Fan#: 12504
What I Drive: 2003 SVT Focus
FF Reputation: 1 havoc7476 Good Standing Member
havoc7476 is offline
Old 08-11-2005, 07:20 PM   #10
dispense05
Fan#: 17177
What I Drive: 2000 Sonic Blue ZX3, 1993 Civic B16A swap
FF Reputation: 1 dispense05 Good Standing Member
hahaha. thats a good point.
the only spot my pics would work.
dispense05 is offline
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
