2002 Ford Focus - poor fuel efficiency - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-06-2005, 11:46 PM   #1
Deft
Fan#: 26450
What I Drive: 2002 Ford Focus
FF Reputation: 1 Deft Good Standing Member
I have a 2002 Ford Focus... the registration card says model "LP", but I'm assuming it's either an LX or an SE (the car doesn't have an SE on the back). My fuel efficiency was great when I first got the vehicle (automatic); around 26-28 city, 30-32 highway. Unfortunately, that's changed and I'm now down to 18-20 city, and 22-24 highway. I've put fuel injection cleaner in the gas tank, and changed out the spark plugs, still no improvement. My father was a mechanic, and he said the only other thing he could think of that would be affecting gas mileage would be the catalytic converter. I've also heard suggestions about tire rotation, pressure, etc.
Any suggestions?
- Rob
Deft is offline
Old 08-07-2005, 12:10 AM   #2
xFOCIx
Fan#: 23553
What I Drive: 2005 ZX3 5spd
FF Reputation: 15 xFOCIx Great Standing Member
Any codes in the computer?
Other possibilities are failed lock-up mechanism in transmission and failing oxygen sensor(s). You have a 2002, so you should have a tachometer. Push very gently on the gas at highway speed. RPM should not change at all. Keep pushing the gas in, then the RPM should "jump" a little as the torque converter unlocks.
Tire pressure or rotation won't affect fuel economy to this extent.
xFOCIx is offline
Old 08-07-2005, 12:21 AM   #3
Deft
Fan#: 26450
I have an automatic, thus no tachometer.
Deft is offline
Old 08-07-2005, 12:27 AM   #4
xFOCIx
Fan#: 23553
Logically that make sense, but that's not really how it works. My 2003 5spd had a tach, my current 2005 5spd doesn't, but the 2005 SES trim has a tach even in auto.
Anyhow, since you don't have a tachometer, you'll have to use the test mode on odometer.
With the car off, hold the clear button while you start the car. Keep it held down until "test" appears. Release button. Needles will go crazy but not to worry. Push buttons over and over again until " tAc ####" shows. I don't know how many times, but its less than ten times.
That is your engine RPM readout. It changes rapidly so it is hard to read, but it should help you in this case.
To exit test mode, turn off car, then turn back on.
xFOCIx is offline
Old 08-07-2005, 11:19 AM   #5
Tbones00SE
Tbones00SE's Avatar
Fan#: 9982
What I Drive: 2000 Toreador Red SE
Points 1,367, Level 20
Points: 1,367, Level: 20 Points: 1,367, Level: 20 Points: 1,367, Level: 20
Level Up 67% Completed
FF Reputation: 10 Tbones00SE Great Standing Member
Buy-Sell-Trade Rating: (7)
Just for clarification, when he says the "clear button" he's talking about the tripometer reset button located on the guage cluster.
Tbones00SE is offline
Old 08-07-2005, 11:45 AM   #6
StealthGray
StealthGray's Avatar
Fan#: 19017
What I Drive: '04 Liquid Gray ZX3
FF Reputation: 12 StealthGray Great Standing Member
Buy-Sell-Trade Rating: (6)
Yup, that's what he means!
StealthGray is offline
Old 08-07-2005, 07:53 PM   #7
Deft
Fan#: 26450
I'm not sure what kind of response I'm supposed to be getting from the engine.. I tried the said test and didn't get any response, then again I may not be doing it correctly. After turning on the tach, I seem to get pretty normal RPMs... 800-900 idle, and shifting RPM seems to be fine. How much does something like an O2 sensor cost to have diagnosed and replaced?
Deft is offline
Old 08-07-2005, 08:06 PM   #8
xFOCIx
Fan#: 23553
You push on the gas lightly at highway speed. It should stay quite steady, then jump. If you don't see this pattern you might have a slipping TQ converter.
go to the test mode again and keep pushing buttons until you see 'dtc' in funky LCD font. Do you see NONE? or do you see a rotating list of stuff? Write them down and post here. These are trouble codes. Don't go randomly replacing parts unless you know it is the cause.
xFOCIx is offline
Old 08-07-2005, 08:40 PM   #9
Blurvfocus
Blurvfocus's Avatar
Fan#: 15299
What I Drive: 03 ZX3 Wine Cooled Eng.
FF Reputation: 54 Blurvfocus Excellent Standing Member
^-^ Are these the same codes you would get with a code reader?
Often wrong but never in doubt.
Blurvfocus is offline
Old 08-07-2005, 08:57 PM   #10
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
"Are these the same codes you would get with a code reader?"
No. I real life those particular codes are somewhat useless as some of them are "false positive" codes.
Go to somewhere that reads codes for free, such as AutoZone, and see if anything shows up.
How many miles do you have on the car?
penguin is offline
