Replacement Headunit questions - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-05-2005, 09:04 PM   #1
svt_gEEk
oldFart
svt_gEEk's Avatar
Fan#: 18578
What I Drive: nothing
FF Reputation: 3 svt_gEEk Good Standing Member
Buy-Sell-Trade Rating: (4)
I have a 2002 SVTF with the audiophile system and my tuner just crapped out on it 2 weeks after my warranty went out. So now I need a new headunit. I know what headunit I want, but my question is....will I lose use of my factory sub without some extra wiring on my part or do they have the harness for just plug and play?
svt_gEEk is offline
Old 08-06-2005, 12:59 AM   #2
sa_pyro_ne
sa_pyro_ne's Avatar
Fan#: 1437
What I Drive: 2000 Ranger V6 4.0L 4x4 XLT Ext Cab
FF Reputation: 4 sa_pyro_ne Good Standing Member
if you go aftermarket for the headunit. there are no plug and play devices that will give function to the stock subwoofer. sorry, bad luck.
- Scott
sa_pyro_ne is offline
Old 08-06-2005, 01:43 AM   #3
VAfromMN
Fan#: 20592
What I Drive: '13 Focus ST & '04 Focus SVT
Points 1,024, Level 17
Points: 1,024, Level: 17 Points: 1,024, Level: 17 Points: 1,024, Level: 17
Level Up 24% Completed
FF Reputation: 9 VAfromMN Good Standing Member
QUICK, check with your dealer. In a lot of cases where the warranty has just expired, they'll go ahead and replace the unit anyway. If you've dealt with anybody in particular in the service department, go see them right away.
VAfromMN is offline
Old 08-06-2005, 09:47 PM   #4
PapoSwing
Regulator...mount up
PapoSwing's Avatar
Fan#: 3062
What I Drive: 03 Pitch Black SVT
Points 5,930, Level 49
Points: 5,930, Level: 49 Points: 5,930, Level: 49 Points: 5,930, Level: 49
Level Up 90% Completed
FF Reputation: 28 PapoSwing Great Standing Member
Buy-Sell-Trade Rating: (10)
^^^^^ what he said. What unit are u going with?
PapoSwing is offline
Old 08-07-2005, 02:11 PM   #5
svt_gEEk
oldFart
svt_gEEk's Avatar
Fan#: 18578
Just bought the Alpine 9853 head unit this weekend. I'm about to go see if I can make the sub work.
svt_gEEk is offline
Old 08-08-2005, 11:55 PM   #6
Driveswithfocus
Fan#: 26498
What I Drive: 2001 Pitch Black ZX3
FF Reputation: 1 Driveswithfocus Good Standing Member
What you could do is:
Install the new HU
Run an RCA cable from the new HU to the factory amp
Cut the male ends off the RCA cables (might not have to do this depending on converter)
Splice the RCA cables to one of those line converter boxes, (low level) input side
Run the Hi Level/speaker wire end of the converter to the factory amp
Splice the new Hi level wires to the connector for the factory amp...
Might work...either that, or I'm nuts...I've never looked at the way a SVT stereo is installed from the factory, but it might be doable the way I just mentioned...your local car audio shop might know how to make something like this work...I've seen this kind of setup work in a 91 Honda prelude with the OEM HU for a freind of mine.
Worst case scenario, it won't work and you'll have to disable the factory amp and remove it, and buy a cheap sub amp to use in it's place...
Hope any of these ideas might help....
Clean is the new mean
Driveswithfocus is offline
Old 08-09-2005, 12:01 AM   #7
svt_gEEk
oldFart
svt_gEEk's Avatar
Fan#: 18578
I got it to work. I had to do kinda what was suggested. I took a single RCA cable and tied the shield and signal wires into the corresponding wires on the subwoofer/steering wheel control harness along with the remote turn on....there's a little noise but I'm gonna see if I can't get rid of that tomorrow. There is a wiring diagram for the svt HU in the sticky FAQ at the top of the audio section. Helps tremendously.
svt_gEEk is offline
