| Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, suspension issues and more. Sponsored By:
#1 | ||||
OK...I know you guys get mad when people ask questions that have already been answered. I have looked at bushings topics and not really found what I am looking for. I will be installing the ford racing KW struts and shocks with H&R sport lowering springs very soon. Since I will be ripping my suspension apart I am going to replace bushings. The energy suspension bushings are polyurethane and the prothane bushings are urethane. The prices are similar. Does anyone know the difference and which is better/worse in which ways. I will be buying bushings and I'm not sure which way to go. Help is appreciated. P.S. sorry so long...
GO ILLINI!!! |
Remove Advertisements |
Fan#: 1
#2 | ||||
Sückn' n Blown
I think the big difference is in the front lower control arm. I've done the Prothane version, and while it was hard, the ES sounded harder. The ES require you to cut off a metal sleeve since it replaces it, while the Prothane slides onto the original metal sleeve.
Not sure about the other bushings. They should be more or less the same.
January 2008 Focus Fanatics ROTM 2003 Ford Focus ZX3 2.3l N/A = 206 HP, 150 ft-lbs, 13.967@100.88MPH 2006 Ford Fusion 2.3l Turbo = 244HP, 247ft-lbs duratec.wikispaces.com - Duratec Wiki - Sign up and contribute! |
#3 | ||||
I have the ES system in the suspension set up in my T/A and it is awesome. I plan on buying it for the Focus but will probably get someone to install them.
#4 | ||||
I here that the urathaine are the best.But i would ask around.You don't have a good performence shop nere by do you.
PERFORMANCE:Aem cai, Aem air bypass valve, Autolite double platinum plugs,Ford Racing 9mm plug wires, Full magnaflow cat back exhaust, Fc race header, Focus Central Flex Pipe, Fc 65mm throttel body ,Fc strut brace, Prothane lower mount inserts, Prothane front and rear swaybar bushings and rear endlink kit, Fc spark plug cover EXTERIOR: Aerospeed lowering springs, Sidemarkers, Svt upper grill, 03 Grey Headlights, Flat Black Stock 15s, APC Gen. 2 Mirrors, Euroglow Xenon Headlights INTERIOR: Fc short shifter, Auto meter duel a-piller guage pod, Auto meter phantom oil pressure and Volt gauges, Ford racing tach w/shift light, SVT alum. pedals, Rear seat removed |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| energy suspension hyperflex polyurethane bushings | 2KSESport | Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack | 5 | 02-04-2007 04:59 PM |
| energy suspension bushings | idunrider | Archive | 2 | 08-11-2006 05:07 PM |
| QUICK HELP Energy suspension motor mount bushings... | mn12bird | DURATEC Performance (2003-2011) | 0 | 08-06-2006 09:51 PM |
| prothane vs energy | imprtslyr0223 | Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack | 8 | 03-07-2005 10:33 PM |
| Energy Suspension bushings | Joni Nitro | ZETEC Performance (2000-2004) | 5 | 02-19-2005 11:27 PM |
