Oil pressure gauge install - Page 2 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus First Generation > SPI Performance (2000-2004)
Old 11-11-2005, 03:55 PM   #11
MUTTLEE
MUTTLEE's Avatar
Fan#: 27086
What I Drive: 03 SE Turbo SPI
FF Reputation: 1 MUTTLEE Good Standing Member
I know this is a ZETEC block. But the SPI block is identical in this area...big red arrows are pointing to this. Trust me. Pressurized oil comes from this plug. Been using it as my turbo oil feedline for months now.
Turbo SPI - cuz I can
MUTTLEE is offline
Old 11-11-2005, 07:28 PM   #12
waterboy
Guest
Fan#: 2258
What I Drive: 2k SPI-T, with Lentech automatic stuff on it
FF Reputation: 1 waterboy Good Standing Member
Buy-Sell-Trade Rating: (4)
YEAH BOIIIIIEEEEEEE!!!!!!
waterboy is offline
Old 06-10-2009, 09:39 PM   #13
X-Rated
X-Rated's Avatar
Fan#: 55237
What I Drive: 03 Tan ZTW
FF Reputation: 4 X-Rated Good Standing Member
Buy-Sell-Trade Rating: (12)
Originally Posted by waterboy View Post
1) Locate your oil pressure sensor. It is about 2-3" above your oil filter.
2)Unscrew it and thread in a 1/4"x 2" brass or galvanized nipple. Then thread on a similar tee. Make sure you use teflon tape or virgin teflon sealer on the threads.
3) Thread your sensor and then your compression fitting into your ends of the tee. Again, thread sealer.
4) Route your gauge tubing into the car wherever you want to mount it. Mine is mounted in the dash above the ashtray, but most guys go with a gauge pod. I went for stealth.
5) Wire up to your running lights so the gauge is illuminated only at night. I want off the downside of the fuse. There's a clip you can get at Radio Shack that fits on the blade of the fuse and slides in with the fuse. Then on the other end it had a spade plug connector. Done. works great.
6) Mount your gauge and run her and check for leaks.
Don't be suprised if you hit 100+# of oil pressure when she's cold. It'll settle down after you get her warmed up. Just like a woman. I peg my Ford Racing gauge at 100# just pulling into traffic when she's cold.
Jim
I have looked at many threads on the "Oil Gauge Install" and all are the same..1/4 NPT by 2" long nipple, however, what I haven't seen is what thread it is...METRIC OR STANDARD.
Can anyone enlighten me on this?
2003 ZTW - 2.0L 16v Zetec: 9mm Racing plug wires, long style CAI, shorty header w/down pipe, glasspack for a resonator & raptor muffler
Drive it like you stole it!!
X-Rated is offline
Old 06-10-2009, 10:10 PM   #14
jrdyfocus84
jrdyfocus84's Avatar
Fan#: 64726
What I Drive: 2001 Silver SE Sedan SPI
FF Reputation: 3 jrdyfocus84 Good Standing Member
Buy-Sell-Trade Rating: (8)
Originally Posted by W~Phoenix~{RC} View Post
Well, I'm not so sure about that. I haven't seen a close-up of that same area on an SPI engine before so I couldn't say. Maybe one of the SPI guru's could answer that.
definitely have that plug on an spi motor... i pulled two spi motors recently and noticed it on both of them... will be using it for my turbo oil feed.... 4" left of the oil pressure sensor...<from back of motor>.... can post pics of this location if needed...
also on the spi we don't have the same connection near the coil pack like they do on the zetec....
Cause for DIVORCE Racing
team GATOR'S AUDIO
www.napoleonvillefire.org/focus/focus.htm
jrdyfocus84 is offline
Old 02-27-2012, 05:38 PM   #15
fordcrazi
Fan#: 86801
What I Drive: 2003 white Focus
FF Reputation: 1 fordcrazi Good Standing Member
since my engine desided to die due to oil pump failure i'll be putting a oil pressure gauge on the engine im sticking in.. The spot right behind the start is where im hooking it up at
fordcrazi is offline
Old 02-28-2012, 01:22 AM   #16
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
What I Drive: 04 WRB WRX / 00 se zxw
FF Reputation: 33 Djzx3 Great Standing Member
Buy-Sell-Trade Rating: (6)
http://www.focusfanatics.com/forum/s...pressure+gauge
Pretty much the same, which idk why it never got added to the archive?
2000 SE wagon 2.0l Zetec.
HN #17
D23 crew-#1
Djzx3 is offline
Old 07-31-2012, 07:49 PM   #17
adrst2.3
adrst2.3's Avatar
Fan#: 80621
What I Drive: 07,red,st
FF Reputation: 4 adrst2.3 Good Standing Member
Buy-Sell-Trade Rating: (9)
hey my oil pressure gauge reads low at idle between 10 and 15 but as soon as i drive of it climbs up to around 56-68.is this normal?.i figured at idle theres not much pressure since theres no load.i just want to make sure im correct.
adrst2.3 is online now
Old 07-31-2012, 07:59 PM   #18
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
Where is your sender located?
If next to the oil filter, then no 10-15 PSI fully warmed up at idle is normal.
It's when you start seeing 5PSI, there is a problem, or when the oil pressure light comes on.
HN #17
D23 crew-#1
Djzx3 is offline
Old 07-31-2012, 09:53 PM   #19
adrst2.3
adrst2.3's Avatar
Fan#: 80621
Seems like i was little low on oil .ill double check tomorrow on the way to work but when i added some an turned it on it sat around 30-35.
Old 07-31-2012, 10:43 PM   #20
Djzx3
WRX/Focus:)
Djzx3's Avatar
Fan#: 76864
wow, how low were you? Below the low mark on the stick?
HN #17
D23 crew-#1
Djzx3 is offline
