How To: Drilling Out Ignition Cylinder Due To Key Won't Turn (Ford Focus ignition lock cylinder) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Closed Thread
Old 07-29-2005, 10:40 AM   #1
microtonal
FF #1 Most Wanted
microtonal's Avatar
Fan#: 470
What I Drive: 2012 GTI, 2014 Forester XT
FF Reputation: 12 microtonal Great Standing Member
Buy-Sell-Trade Rating: (7)
*Click here to see the original thread that started this discussion
Well, I couldn't get my key to turn in my ignition no matter how hard or persistant I tried so I had to drill it out.
I will tell you that this is no easy job. I broke 3 drill bits and my arms are sore as hell from drilling.
For anyone who runs into an ignition cylinder that will not turn with the key inserted, try this first:
1.
Get a regular non-PATS key made at the lock smith.
2.
Using the regular key in the ignition, tap lightly on the end of the key with a medium size screwdriver handle and try to turn the key as you're tapping. Be persistant. I did this for 30 minutes.
3.
If the key still won't turn, try spraying a little WD-40 or some type of lubricant and try again.
4.
If it still won't turn, call the locksmith or get ready for an enduring experience at some drilling.
I would suggest you get some titanium or HSS(High Speed Steal) drill bits because I had a set of the Black and Decker drill bits and broke 3 of them. Even a large one, which was only one size smaller than the 3/8. The IC is made of some very harded metal and it's gonna take some work to get it drilled out.
*Also, mark the drill bit with some tape 1 inch from the top so you know how far to drill. You don't want to go any further or you'll start going into the steering column. (See picture above for example)
Click here for drilling instructions
Click here for ignition cylinder removal instructions
*It's best to drill a little below the X in the instructions. I drilled at the same point and my drill rode up in to the tumbler area and you get this, a larger hole.
Here's what a properly drilled IC looks like.
Now, you will need to get the IC to turn to the Accessory position for 2 reasons.
1.
To be able to push the little button on the side, the IC needs to be turned to the Accessory position. Mine would not push in if it was in the OFF position or in the RUN position. It had to be in the Accessory position in order for the button to push in.
2.
There is a locking ring a the end of the IC that need to go in to a groove/slot in the steering wheel or the IC will not slide out.
So, if you can't turn the IC to the Accessory position, the IC isn't going to slide out even if you can push the little button on the side.
*I used an allen wrench to push the button. There's no way you are going to get a screwdriver to push the button unless you remove the steering wheel.
The new style IC definitely looks different. Looks more like the 2005 IC. It's got a center piece and looks more like a 2 piece IC whereas the old style IC seems to be a 1 peice.
Anyway, I want to say thanks to b16sir1991 (Mike) for getting me the IC for cheap with a regular key and tumblers setup. I basically had to just install it and it worked.
He also provided me with the tips I posted here and he was very helpful.
Anyone who needs an IC, I would suggest sending b16sir1991 a PM since he gets them from Ford and the IC is a new style Motorcraft part which should not have the lock up issue.
Ignition Lock Cylinder
Removal
1. Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
2. Remove the instrument panel lower panel.
  • Remove the screws.
  • Release the fastener.
3. Detach the steering column upper shroud.
Using a thin bladed screwdriver, release the two clips (one each side).
4. Remove the audio control switch (if equipped).
  • Using a thin bladed screwdriver, release the locking tang.
  • Disconnect the electrical connector.
5. Remove the steering column lower shroud.
  • Release the steering column locking lever.
  • Remove the ignition key.
6. Remove the ignition lock cylinder.
  • Insert and turn the ignition key to position I (Accessory).
  • Using a thin bladed screwdriver, depress the detent.
  • Remove the lock cylinder.
Installation
1. To install, reverse the removal procedure.
keywords: ford focus ignition cylinder, ford focus stuck ignition, ford focus sticking ignition cylinder, ford focus ignition, ford focus ignition lock cylinder
Just reading.....
microtonal is offline
    Quick reply to this message
Old 07-29-2005, 01:07 PM   #2
Lil PZEV
Lil PZEV's Avatar
Fan#: 242
What I Drive: 2003 TwiBlue 2.3 ZX3
FF Reputation: 15 Lil PZEV Great Standing Member
Buy-Sell-Trade Rating: (14)
Vote for Sticky status.
Locked ignition is a quasi-common issue on the previous Focus models, this looks very helpful if someone ran into the problem! Thanks Bob.
Also, does Ford still not have a recall or TSB out on this?
Lil PZEV is offline
Old 07-29-2005, 01:28 PM   #3
microtonal
FF #1 Most Wanted
microtonal's Avatar
Fan#: 470
No recall because I believe this is not a safety issue. More of a hassle because of a part that may become defective over time. I believe there is a TSB though.
Just reading.....
Old 07-29-2005, 01:53 PM   #4
b16sir1991
Focused Focus
b16sir1991's Avatar
Fan#: 16612
What I Drive: 2004 SVT Focus, Sonic Blue
Points 12,236, Level 72
Points: 12,236, Level: 72 Points: 12,236, Level: 72 Points: 12,236, Level: 72
Level Up 47% Completed
FF Reputation: 175 b16sir1991 Excellent Standing Member b16sir1991 Excellent Standing Member
Buy-Sell-Trade Rating: (116)
Thats right, no recall and there are ssm's on it, but Bob just covered everything you need to know. Working here at Ford im really suprised that they have not issued a recall though because there have been many other recalls that were not as big of a problem as this and didnt have anything at all to do with safty.
"The right driver can work magic"
Oct 2005 Ride of the month.
SVT Squad #25
Call me Mike......
Give rep points and feedback when you appreciate someone on here!
b16sir1991 is offline
Old 10-17-2005, 10:19 AM   #5
microtonal
FF #1 Most Wanted
microtonal's Avatar
Fan#: 470
^^^ bump for bacc231
Just reading.....
Old 10-18-2005, 03:37 PM   #6
nilskje
Fan#: 11478
What I Drive: Focus -04 5door 1,6 Ghia
Points 454, Level 9
Points: 454, Level: 9 Points: 454, Level: 9 Points: 454, Level: 9
Level Up 8% Completed
FF Reputation: 17 nilskje Great Standing Member
My god we are lucky in Europe, here they use a diffrent lock sylinder, the key is basically round, looks quite different 2 the ones you have .. Wonder why they dont use the same in the US area, i will try 2 finr the Ford p/n ...
nilskje is offline
Old 10-18-2005, 03:52 PM   #7
ampedout
ampedout's Avatar
Fan#: 16956
What I Drive: White 00 SE Sedan Zetec
Points 5,085, Level 45
Points: 5,085, Level: 45 Points: 5,085, Level: 45 Points: 5,085, Level: 45
Level Up 68% Completed
FF Reputation: 1 ampedout Good Standing Member
Buy-Sell-Trade Rating: (8)
Ive had my key stuck in my cylinder for 5 months.. I will NOT spend the 320 bucks to have ford fix it. I would rather include a ignition start button located in a hidden place under the steering column.
Roush Turbo kit
ampedout is offline
Old 10-18-2005, 05:30 PM   #8
microtonal
FF #1 Most Wanted
microtonal's Avatar
Fan#: 470
If you can turn the IC with the key, you can change the IC yourself for about $50.
It's not hard to remove the IC.
The instructions are in the first post.
Just reading.....
Old 10-20-2005, 10:00 PM   #9
microtonal
FF #1 Most Wanted
microtonal's Avatar
Fan#: 470
^^^ Bump for TheFoci01
Just reading.....
Old 10-20-2005, 10:10 PM   #10
vanace
Fan#: 350
What I Drive: 2005 ST
FF Reputation: 1 vanace Good Standing Member
micro.. why in the sam hell would you drill the igntion when you have an 05 under warantee?
ST crew #18
vanace is offline
Closed Thread
