Tachdriver install help needed - Page 6 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus First Generation > MK1 Interior Mods & Upgrades
Old 09-06-2006, 03:54 PM   #51
scrammer
scrammer's Avatar
Fan#: 26570
What I Drive: February 2010 ROTM
FF Reputation: 172 scrammer Excellent Standing Member scrammer Excellent Standing Member
Buy-Sell-Trade Rating: (29)
i just installed an Autometer DPSS (Digital Pro Shift System). it has a led tach and progressive shift lights. i used pin48 for the signal wire. but when it reads the rpms, it only reads thousands, hundredths, and tens. it only shows a zero in the 1-9 range. is this normal? or should i try using the FR tach driver? other than that, pin 48 works great for the tach signal wire.
scrammer is offline
Old 12-05-2006, 03:19 AM   #52
BobBernard
Spin
BobBernard's Avatar
Fan#: 36660
What I Drive: 2006 Screaming Yellow Focus ZX3 S
FF Reputation: 9 BobBernard Good Standing Member
Buy-Sell-Trade Rating: (4)
I just want to add one thing to this...awesome write up.
This procedure is made easier by swinging the glovebox all the way open.
By that I mean, open the glovebox (empty it) all the way open and there are two
rubber bumpers on either side of the outer side of the glovebox behind the dash
holding the glovebox from opening further.
They are located in the middle outersides of the glovebox behind the dash.
Push in on both outer sides of the glovebox where I mentioned above,
the middle outer sides, and the rubber bumpers will slip from behind
the dashboard allowing you to swing the glovebox all the way open
and down to the floor.
This should make it easier to see/plug/unplug things.
BobBernard is offline
Old 12-16-2006, 02:28 AM   #53
brandon0133
1fastfocus05
brandon0133's Avatar
Fan#: 35345
What I Drive: 2005 zx4,
FF Reputation: 3 brandon0133 Good Standing Member
Buy-Sell-Trade Rating: (31)
my car did not come with a tach,,do i have to have a tach driver to make a new cluster with a tach work or will it just plug and play like the other hot to archives say,,they dont say anything about a tach driver
got a new focus all stock, starting new build
TEAM DURATEC #150
brandon0133 is offline
Old 12-25-2006, 11:17 PM   #55
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,747, Level 78
Points: 14,747, Level: 78 Points: 14,747, Level: 78 Points: 14,747, Level: 78
Level Up 75% Completed
Forum Activity 11%
FF Reputation: 90 goinloco1 Excellent Standing Member
Focus ecu pinout
1 shift solenoid - B gn/bu
2 not used
3 IMRC module signal wh/rd
4 Transmission range sensor - reverse gn/bu
5 not used
6 not used
7 transmission range sensor - 1st / EVAP vent valve gn/wh - bk/og
8 transmission range sensor - 2nd gn/og
9 Barometric absolute pressure sensor wh/bk
10 not used
11 transmission range sensor - drive gn/bk
12 switched ground bk/wh
13 Flash EEPROM power supply og/bk
14 not used
15 SCP - bu/bk
16 SCP + gy/og
17 switched ground bk/wh
18 not used
19 TX signal gy/og
20 Injector 3 control bk/bu
21 crankshaft position sensor + wh/rd
22 crankshaft position sensor - bn/rd
23 ground bk/ye
24 ground bk/ye
25 ground bk
26 switched ground CDA (coil 1-) bk/og
27 start inhibit relay circuit bk/rd
28 vehicle speed signal output wh/vt
29 overdrive cancel switch input gn/bk
30 not used (12v input from auto tranny only. DO NOT hook this up on manual trans ecu's, you will fry them)
31 Power steering pressure sw input / press. sensor bk/yel / wht/vt
32 sensor return (reference/ground) bn/ye
33 Output shaft speed sensor - bn/bu
34 turbine speed sensor + wh/vt
35 HO2S 2 signal wh/rd
36 MAF return bn/bu
37 transmission fluid temp + wh/gn
38 cylinder head temp / coolant temp sensor wht/vt / wh
39 MAF input wh/vt
40 fuel pump monitor gn/bk
41 A/C clutch pressure cycling switch input gn/ye
42 PATS indicator control bk/og
43 sensor signal wh/bu
44 Pressure control solenoid A + gn/og
45 Camshaft timing actuator control bk/rd
46 Low fuel indicator bk/wh
47 electronic vacuum regulator solenoid valve control bk/gn
48 not used (tach signal, anything needing this signal can be hooked here)
49 CAN bus L bu/rd
50 CAN bus H gy/rd
51 ground bk/ye
52 switched ground CDB bk/gn
53 RX signal wh/gn
54 fuel pump output / switched ground bk/wh - bk/bu
55 hot at all times rd
56 EVAP purge valve control bk/bu
57 Knock sensor + wh/bk
58 VSS / OSS + wh/bu - wh/bu
59 generator monitor circuit gy
60 HO2S 1 signal wh
61 not used
62 fuel tank pressure transducer sensor signal wt/vt
63 fuel rail pressure transducer sensor signal wh/gn
64 transmission range sensor P/N / clutch switch grn/yel / wht
65 exhaust pressure transducer signal wh/bu
66 not used
67 EVAP canister vent control bk/og
68 switched ground bk/bu
69 switched ground bk/ye
70 injector 1 control bk/wh
71 power hold relay output (VPWR) gn/ye
72 generator communicator command lb
73 shift solenoid - A / check fuel cap light grn/yel / blk/wht
74 not used
75 gnd (power return) bk/wh
76 turbine speed sensor - / signal return / sig rtn bn - wh/vt - bn/wh
77 power ground bk/ye
78 not used
79 not used
80 IMRC control bk/wh
81 pressure control solenoid A- bk/rd
82 Shift solenoid C gn/bk
83 idle air control valve control grn/yel
84 not used
85 camshaft position sensor signal / sensor sig rtn wh/vt - bn/wh
86 sensor signal wh/rd
87 knock sensor - bn/ye
88 MAF output wh/bu
89 throttle position sensor signal wh
90 VREF ye
91 transmission fluid temp - bn
92 stop lamp switch input gn/rd
93 HO2S 1 control bk/ye
94 not used
95 injector 4 control bk/og
96 injector 2 control bk/ye
97 power hold relay output gn/ye
98 not used
99 shift solenoid D gn/og
100 HO2S 2 control bk/bu
101 not used
102 shift solenoid E gn/wh
103 ground bk/ye
104 not used
goinloco1 is offline
Old 01-05-2007, 12:19 AM   #56
Jimmydigital00
Jimmydigital00's Avatar
Fan#: 37169
What I Drive: 2003, Pitch Black Focus SVT
FF Reputation: 1 Jimmydigital00 Good Standing Member
I had a Autometer DPSS digital tach/shift light and my RPM window switch hooked up to pin 48 and it worked fine for a while. Now I disconnected the Tach and now pin 48 is not giving me any reading at all. Can you burn out a individual pin? The car is running fine I just am not getting anything.
Jimmydigital00 is offline
Old 01-09-2007, 02:05 AM   #57
43racing
Fan#: 41905
FF Reputation: 1 43racing Good Standing Member
i have a 2006 zx3 hatch with the 2.0 duratec and i have an autometer tach adapter #9117 and a sport comp II, 3 5/8 tachometer. do you know what wires i need to tap into for the tach adapter?
43racing is offline
Old 01-23-2007, 10:54 PM   #58
drsnutz
Fan#: 42625
What I Drive: 2013 ford focus ST
FF Reputation: 1 drsnutz Good Standing Member
Thumbs up tach driver install for 2005-2007 2.0 or2.3 duraqtecs with autometer 9117 adapter
you can,t splice into the power wires for the coils as they also power the injectors. however if you cut the power wires at the #2 pin on the coils you can then connect the wires from the coilsto each other and then connect them to the red with green tracer wire on the adapter, then take the ends of the wires from the wiring harness hook them together and attach them to the red wire of the adapter and hook the rest of the wires from the adapter up per autometers instructions, this is easy to do and can be done with minimal wiring experience
drsnutz is offline
Old 03-04-2007, 03:02 PM   #59
the-truth81
the-truth81's Avatar
Fan#: 38386
What I Drive: 03, grey, ZTS
FF Reputation: 5 the-truth81 Good Standing Member
so on my 03 zetec, all i have to do is tap into the wire that goes to pin 48, that tap will connect to my green wire on my shift light and i will have the correct readable signal needed?
sedan revolution #32
'03 liquid grey zts-currently wrecked, maybe fixable
'02 liquid gray zts(mach edition)
'05 Mustang Gt-
'84 Cut supreme (455 build)
the-truth81 is offline
Old 03-04-2007, 08:46 PM   #60
Jimmydigital00
Fan#: 37169
Pin 48 will not have a wire in it. Just a empty slot where a wire would go.
Do yourself a favor get a Ford Tach adapter and it will be a better install.
I found one on ebay for 30 bucks.
