Tachdriver install help needed - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus First Generation > MK1 Interior Mods & Upgrades
Old 08-04-2005, 03:35 PM   #21
Caleb
Fan#: 1534
What I Drive: 2002 Focus LX
FF Reputation: 1 Caleb Good Standing Member
PCM pin# 21 is crankshaft position sensor + white/red stripe
PCM pin# 22 is crankshaft position sensor - brown/red stripe
i have the spi engine, not the ztech. are these still the correct wires to tap into?
Caleb is offline
Old 08-04-2005, 03:45 PM   #22
DareDevil03
Across the Pond
DareDevil03's Avatar
Fan#: 13938
What I Drive: 2001 Nissan Primera (UK Spec)
Points 5,115, Level 45
Points: 5,115, Level: 45 Points: 5,115, Level: 45 Points: 5,115, Level: 45
Level Up 83% Completed
Level up: 83% Level up: 83% Level up: 83%
FF Reputation: 1 DareDevil03 Good Standing Member
Buy-Sell-Trade Rating: (18)
Mine looks kinda like this. This is what I meant by the five pugs. If it would help, I could take pics and post them to show you what it looks like.
Proudly Serving
Ask me about UK parts.
DareDevil03 is offline
Old 08-04-2005, 09:05 PM   #23
OAC_Sparky
Fan#: 25741
What I Drive: Liquid Grey 2005 ZX4 ST
FF Reputation: 1 OAC_Sparky Good Standing Member
Yes. I specifically looked at the schematics for the SPI for you.
OAC_Sparky is offline
Old 08-04-2005, 09:12 PM   #24
OAC_Sparky
Fan#: 25741
Now, personally, I bundled the wires and 3M double-face taped the driver to the face of the GEM module ( the module piggy backed on the PCM). This made the install a bit neater.
That pic is of the GEM module for the door locks, alarm, etc, not the PCM. The PCM is beneath it in the silver case.
Your PCM should be similar, but like Caleb's it should only have one plug, but I'll have to check.
Old 08-05-2005, 04:05 AM   #25
DareDevil03
Across the Pond
Fan#: 13938
ooOOoo, so that's what I'm doing wrong. d-oh!!!!
Proudly Serving
Old 08-06-2005, 03:46 PM   #26
xFOCIx
Fan#: 23553
What I Drive: 2005 ZX3 5spd
FF Reputation: 15 xFOCIx Great Standing Member
There is engine RPM signal available at the OBD II diagnostic connector. I can't see why you can't tap into that instead of taking the car apart to get to other connectors.
xFOCIx is offline
Old 08-06-2005, 05:02 PM   #27
DareDevil03
Across the Pond
Fan#: 13938
And do you know what wire to splice into?
Proudly Serving
Old 08-06-2005, 10:34 PM   #28
xFOCIx
Fan#: 23553
http://www.obdii.com/connector.html
Ford should be J1850-PWM protocol and there should be a tachometer that can derive a standard tachometer signal from the J1850 signal(contains everything ranging from speed, injector pulse, coolant temperature etc.)
Or you could use a product like this that will work with Ford signal. I beliee this one is for GM signal...
https://www.flp2win.com/store/produc...7cf9e3a2d5fbfc
xFOCIx is offline
Old 08-06-2005, 11:23 PM   #29
OAC_Sparky
Fan#: 25741
That would be good for its intended use, but not for a shift light or a stand alone tach.
The reason people are asking how to get the tach signal from the car isn't because they want a smalldigital tach readout.
You can do that with the digital section of the gauge cluster in test mode.
Most are interested because their cars don't have a conventional analog sweep tach or they want to (like myself) put a shift light in.
Old 08-09-2005, 04:52 PM   #30
Caleb
Fan#: 1534
ok i started installing my tach driver but i have some more questions. first, i found the #21 and 22 pins and one wire was grey and the other was white, so i figured that i needed to hook the white wire from the driver up to the white wire on the pcm, and that left the black to the grey. I need to know if that was right first of all. next, do i hook the red wire from the driver to its own power source or does it go to the red wire on the tach? and then i could use locations of where to hook all the other wires up. like what are good places for the power sources and where is a good ground and then what light wire do i need to tap into for the lights. sorry for so many questions but im not that great with electronics. thanks
Caleb is offline
