Tachdriver install help needed - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus First Generation > MK1 Interior Mods & Upgrades
Old 08-02-2005, 01:22 AM   #11
OAC_Sparky
Fan#: 25741
What I Drive: Liquid Grey 2005 ZX4 ST
FF Reputation: 1 OAC_Sparky Good Standing Member
Just a follow up to Caleb,
Microtonal is correct.
PCM pin# 21 is crankshaft position sensor + white/red stripe
PCM pin# 22 is crankshaft position sensor - brown/red stripe
Your PCM is in the same location (passenger side kickpanel), but instead it has one large plug on it.
I cannot tell by the diagram if the connector is held in by as screw in the center of the plug (it looks like it is, maybe someone can confirm) but if you can get the plug out, turn the face toward you.
Looking at the face, there are 4 rows of pin sockets, with a gap in the middle (around what I'm assuming is the screw)
Orient the plug so that the wire at the UPPER LEFT is a GREEN wire with a BLUE stripe. This is PIN 1
Pins are numbered LEFT to RIGHT -- LOOKING at the FACE
Each row has 26 pins
Row 1 >> 1 to 26
Row 2 >> 27 to 52
Row 3 >> 53 to 78
Row 4 >> 79 to 104
Looking at the face of the plug #21 & #22 should be the 5th and 6th wires from the RIGHT on the top row.
There have been reports that #48 is a clean tach signal, but the official schematics say that this pin is "not used". If you are at all electrically competent, you can test this with a DC voltmeter, between PIN #48 and a good ground. If it is a tach signal you should be able to watch a voltage increase with an RPM increase. Make sure you have the right pin, there won't be a wire in it. It'll be the 5th hole from the RIGHT in the second row. Apparently the connector is very deep, so you'll have to push the wire in FAR.
If it is indeed a tach signal, you don't NEED the driver.
Good luck
Edit: Corrected pin count orientation. Make sure you count pins looking at the face of the connector.
OAC_Sparky is offline
Old 08-02-2005, 04:27 PM   #12
Caleb
Fan#: 1534
What I Drive: 2002 Focus LX
FF Reputation: 1 Caleb Good Standing Member
thanks a ton
Caleb is offline
Old 08-02-2005, 05:17 PM   #13
microtonal
FF #1 Most Wanted
microtonal's Avatar
Fan#: 470
What I Drive: 2012 GTI, 2014 Forester XT
FF Reputation: 12 microtonal Great Standing Member
Buy-Sell-Trade Rating: (7)
Thanks for the detailed instructions. This will allow you to install the tach driver in the car and no need to get into the engine bay to splice the CPS wire.
Very informative.
Just reading.....
microtonal is offline
Old 08-04-2005, 01:15 AM   #14
DareDevil03
Across the Pond
DareDevil03's Avatar
Fan#: 13938
What I Drive: 2001 Nissan Primera (UK Spec)
Points 5,262, Level 46
Points: 5,262, Level: 46 Points: 5,262, Level: 46 Points: 5,262, Level: 46
Level Up 56% Completed
FF Reputation: 1 DareDevil03 Good Standing Member
Buy-Sell-Trade Rating: (18)
What about for the 02 SVT? I just installed a shift light. I'm running it off the stck tach and having a hard time finding the signal to set it off at the right RPM.
Proudly Serving
Ask me about UK parts.
DareDevil03 is online now
Old 08-04-2005, 01:45 AM   #15
OAC_Sparky
Fan#: 25741
You have to be more specific. What shift light do you have? What does the instructions for your shift light say?
A shift light needs something to trigger it. Internally, or externally.
Internally triggered shift lights basically have a tachometer integrated into it, you then set it to trigger when it senses the proper RPM, whether digitally set (like my Stewart-Warner GUS) or by a "pill" which is hardware set.
An externally triggered shift light needs the trigger coming from an aftermarket tach. There is no "shift signal" you can tap into on the PCM, that upshift idiot light in your gauge cluster is for fuel economy, not performance or RPM.
Old 08-04-2005, 10:51 AM   #16
DareDevil03
Across the Pond
Fan#: 13938
It's an Autometer Pro-Shift light. It's a one or two pulse light. It uses a "pill" to tell when to light up. I bought it used. The 2002 SVT Focus does not have that dummy shift light that you mentioned.
Here is the link to Autometer's instructions:
http://www.autometer.com/download_instruction/440B.pdf
Proudly Serving
Old 08-04-2005, 11:14 AM   #17
bledandbeaten
bledandbeaten's Avatar
Fan#: 18996
What I Drive: 2002 Dark Blue ZX5
FF Reputation: 1 bledandbeaten Good Standing Member
is there any way to make the "idiot shift light" light up for performance, jw cause in my opinion it would look much cleaner than having some random light turning on and off sporadicaly in my car
damage left to fix on my focus: hood, bumper, upper grille, headlights (L and R), driver side fender, radiator support, radiator, and other small asthetics...
bledandbeaten is offline
Old 08-04-2005, 01:28 PM   #18
OAC_Sparky
Fan#: 25741
The shift light that you listed basically has the tach built in. It counts PPR (Pulses per revolution) and when it matches the RPM setting of the "pill" it lights up.
The problem you might have will be that you are trying to hook a motorcycle shift light into a 4 cylinder car.
In theory it should work. That shift light has two settings, 1 PPR and 2 PPR.
Since you have a Zetec, (even though it's an SVT) it should be the same PCM as Caleb's (maybe someone can confirm, I don't have the schematics in front of me). So you should be able to use the pin #48 signal which should be 2 PPR if that is indeed the tach signal.
Now, once you hook it up, the only way to change the point that the light triggers is to change the "pill".
As far as the tach driver method, you can't use the Ford tach driver easily, it puts out a converted 4 PPR signal that you would have to use a pill that is double the RPM value. ie If you want it to trigger at 6000RPM you need a 12000RPM pill.
However, you may be able to use the Autometer tach driver, IIRC you can set the output PPR.
bledandbeaten
is there any way to make the "idiot shift light" light up for performance, jw cause in my opinion it would look much cleaner than having some random light turning on and offsporadicaly in my car
I doubt it, the light is governed by a combination of sensors that concludes that you are running at an inefficient throttle setting for the load you are pulling. That is why it is telling you to upshift.
You may be able to get a tuner to turn the light off, but I'm not sure if you can get it to change function.
Old 08-04-2005, 02:12 PM   #19
DareDevil03
Across the Pond
Fan#: 13938
Now how do I find pin #48? And am I connecting this to one of the 5 plugs, or one of the others behind them?
Proudly Serving
Old 08-04-2005, 03:10 PM   #20
OAC_Sparky
Fan#: 25741
I'd have to check the schematics. I don't own a SVT.
But 5 plugs? Are you certain you have the PCM?
Sounds like you have the GEM -- the door lock/alarm module.
