Timing Belt Replacement - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-27-2005, 08:54 PM   #1
thumper_corey
Fan#: 1781
What I Drive: 2001 Focus ZX3
FF Reputation: 1 thumper_corey Good Standing Member
So I've decided to replace the timing belt on my 2001 ZX3. I'm cool with doing it myself, I figure there's no need to down $150 bucks for a rather straight forward procedure. However, after examining my Hanes manual, I figure there have to be some short cuts. For example, I figure I could cut out the whole valve cover removal by marking the upper most teeth on the camshaft sprockets and crank sprockets in order to maintain the timing.
Any suggestions? Am I completely off base, or what? Thanks ahead of time.
Corey Bennett
2001 Focus ZX3
Silver, Five-speed
thumper_corey is offline
Old 07-27-2005, 11:10 PM   #2
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 236,661, Level 100
Points: 236,661, Level: 100 Points: 236,661, Level: 100 Points: 236,661, Level: 100
Level Up 0% Completed
Forum Activity 3%
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
As long as you mark them and make sure nothing moves, also, count the number of teeth on the belt between your marks.
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 08-04-2005, 01:14 PM   #3
rockNroll
rockNroll's Avatar
Fan#: 25989
What I Drive: 05 Black ZX4 04 Black CBR1000RR
FF Reputation: 1 rockNroll Good Standing Member
You need to remove that valve cover. Taking any short cuts doing a timing belt on these things is a waste of your time. The timing belts almost never fail on these cars...I actually have yet to see one (I'm probably in the 35-40 range now that I have replaced). What actually happens on these things is the idler pullies fail, melt down, or the mounting bolt shears off in the block. So, replacing tensioner and idler pullies is actually more important than replacing the belt itself. My suggestion to you would be pay a professional to replace it. If your still bent on doing it yourself, get yourself a timing belt "kit" from NAPA. This kit will have everything you need (except tools ), belt, pulley, tensioner, and good instructions. Good luck!
rockNroll is offline
Old 08-05-2005, 10:31 AM   #4
svtguy88
svtguy88's Avatar
Fan#: 13476
What I Drive: 2003 Infra Red SVT
Points 8,660, Level 62
Points: 8,660, Level: 62 Points: 8,660, Level: 62 Points: 8,660, Level: 62
Level Up 70% Completed
FF Reputation: 17 svtguy88 Great Standing Member
When is the supposed 'recommended' replacement for the timing belt anyway?
svtguy88 is offline
Old 08-05-2005, 11:23 AM   #5
rockNroll
rockNroll's Avatar
Fan#: 25989
Your 01 ZX3: Recomended at 90,000 miles. I would do it at about 80,000 as I have seen the pulleys fail numerous times in the 80,000-100,000 range.
