re-adjusting of the inlet cam gear - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-20-2005, 08:31 AM   #1
geospy
Fan#: 19381
What I Drive: FOCUS ST170
FF Reputation: 1 geospy Good Standing Member
We know all of us that by adjusting proper the exhaust cam gear (retard -4 to -6 degrees) we can take 7 - 10 hp more. For this purpose we can use an adjustable cam gear e.g. KENT/PIPER/AEM OR a good mechanic can setup the existing one (default/OEM from FORD) and by the use of a proper tool to retard it in the correct degrees.
My question is how many power we will gain by setting up the inlet cam gear in advance? Did any of us tried to do this?
I believe that 4-6 hp will be gained at least.
geospy is offline
Old 07-20-2005, 08:55 AM   #2
SLIP STREAM SVT
Fan#: 1693
What I Drive: 2002 Pitch Black Focus SVT
FF Reputation: 1 SLIP STREAM SVT Good Standing Member
i believe that our intake cam gear is variable and can't be changed unless you want to eliminate it all together.
2002 SVT Focus
#2760 of 4788
Born: 6/13/2002 in Hermosillo Assembly Plant
Current Implants: Grounding Wires, AEM Cold Air Intake, Ford Racing Strut Bar, Smoked Nite Shade Side Markers, Home Made Shorty Antenna, Steeda Tri-Ax Short Shifter, VF Engine Mounts, SCT Xcalibrator 2 (tune by Wayne @ Hypnotic Illusions ), Nx 50 Shot Wet Kit
SLIP STREAM SVT is offline
Old 07-20-2005, 09:09 AM   #3
Daeron
Daeron's Avatar
Fan#: 20554
What I Drive: 03 Pitch Black SVTF
FF Reputation: 1 Daeron Good Standing Member
Buy-Sell-Trade Rating: (8)
talk to Tom at Focus-power.com...it's something he's been tooling around with :)
#2277 of 3985 born on 5/27/03
SVT Squad #20
SCT XCal2 (Hypnotic), AEM CAI, VR rear engine mount, FC ORP, FRPP STS, FC 2pc UDP, Eibach Pro-Kit springs/KYB AGX dampers, FRPP HIDs, Sony CDX-M8815X, Pioneer TS-A6880R front speakers, 16" Rota Grid (Royal Gunmetal) w/Falken Azenis RT615's
2004 Ford SVT Mustang Cobra Convertible, Mystichrome
#292 of 1896
Daeron is offline
Old 07-20-2005, 09:12 AM   #4
geospy
Fan#: 19381
No, I don't want to eliminate it. But by setting it in advance few degrees, I believe that we can take some more power.
geospy is offline
Old 07-20-2005, 09:25 AM   #5
crazymechanic
Fan#: 12900
What I Drive: 2003 SVT Focus
FF Reputation: 1 crazymechanic Good Standing Member
won't work, the computer monitors how far advanced/retarded the cam is and keeps it within a certain range. if it goes outside that range it'll throw a check engine light and revert back to 0 degrees timing
crazymechanic is offline
Old 07-20-2005, 09:35 AM   #6
geospy
Fan#: 19381
Crazymechanic are you sure or it's just your feeling? Because a friend of mine did the same on a VW Golf FSI and the Variable timing of this machine is similar to our SVT.
geospy is offline
Old 07-20-2005, 10:55 AM   #7
crazymechanic
Fan#: 12900
I work on ford cars for a living. you would have to get your computer reflashed to keep it from throwing a code, but most of the tuners have been unable to get much power out of messing with the VCT. besides that, to accurately set the factory gears at other than 0 degrees would require a degree wheel, and I don't know of any company that makes one small enough to fit our engines. just leave the VCT as is, unless it starts acting up, then get Tom's VCT eliminator and adjustable cam gears
Old 07-22-2005, 03:06 AM   #8
geospy
Fan#: 19381
Ok Thank guys!
geospy is offline
Old 07-25-2005, 03:58 AM   #9
geospy
Fan#: 19381
Well guys I did the test and played with the inlet cam gear.
The gains are amazing. Now I have 187 HP (program + exhaust + typhoon + exhaust cam gear), by putting the inlet cam gear to be in advance between +8 to +10 I reached 203 HP at 6500 rpm and 239 Nm torque. The gains of power/torque started from very low up to high (not only high).
Ofcourse as crazymechanic told me this was only for the dyno, since on the road after 5 min of usage the Check Engine light was enabled.
I'm seriously thinking of getting the VCT eliminator. Does anybody knows what exactly is and how it works? If by using it we will be able to get +15HP then it's very cool. Does it have any known disadvantage?
geospy is offline
Old 07-25-2005, 08:45 AM   #10
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,387, Level 100
Points: 51,387, Level: 100 Points: 51,387, Level: 100 Points: 51,387, Level: 100
Level Up 0% Completed
Forum Activity 25%
Activity: 25% Activity: 25% Activity: 25%
Buy-Sell-Trade Rating: (28)
It is just what it said a VCT Elim , It eliminates the VCT gear where you can install an Adj cam gear
If you have tuning why didnt you just go in the tuning and adjust the cam gear with the ECU
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
