| Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, suspension issues and more. Sponsored By:
#11 | ||||
You want to watch it letting the halfshaft dangle like that - the inner CV joint could be damaged because it has a limited range of motion and allowing it to hold up the outer halfshaft and CV joint like that can overflex it.
Always support the shaft on both sides of any CV joint when you have the outer one disconnected from the hub or the inner one disconnected from the tranny. |
#12 | ||||
so what if I did this same swap on an '03 zx3 that doesn't have ABS is that a problem?
if only this modding stuff didn't take so much money Mac SRI, FC 65mm TB, SVT 5 spokes SVT brake kit, SS lines up front, it's getting there slowly 1984 Celica GT, it's got better options than my focus |
#13 | ||||
Moderator
None at all . I do not have ABS. I just left the sensors in place ( as a water seal) and clipped the wires off. Nothing to it!
#15 | ||||
is it my eyes, or is the stock rotor larger than the svt?
wouldn't that make it more effective....front I mean. Rear swap to disc would be lovely though!!! nice. |
#16 | ||||
Moderator
Nope, no need for a porportioning valve, it works just fine the way it is. I had to put a valve on my mustang when I did it, but the FoFo did not need one.
The SVT disc is larger, so it must be your eyes..LOL the SVT uses a 300 mm disc and stock is 238 I think |
#19 | ||||
Moderator
You have to remove the rear ehaust shield, but it is really easy. It is held on by 4 speed nuts, that is it! You remove those and pull the shield off and they are easy to get to. Total time doing the e-brake cables from start to finish was maybe 30 minutes or less... Just buy the svt rear cables from Ford. That is all you need.
#20 | ||||
Great setup i did the same thing myself last year although i have abs i added goodridge stainless lines and dot 5.1 brake fluid
Fronts ![]() Rears
Garret GT28R roller bearing turbo, 86mm pistons, custom tubular manifold, Omex 500 management. The car is running 17psi which is giving me 300bhp/310 lb/ft torque at the fly |
| Thread Tools | |
| Display Modes | |
