odometer dashes - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-08-2005, 02:31 PM   #1
coyote2
coyote2's Avatar
Fan#: 25341
FF Reputation: 1 coyote2 Good Standing Member
odometer dashes
my 2000 Focus Zetec won't start and odometer shows dashes. The computer is disabling the starter relay. If I bypass the output from the computer I can crank the engine no problem but of course the computer will not operate the engine. Anyone know what is wrong before I tow the car to the dealer?
coyote2 is offline
Old 07-08-2005, 03:28 PM   #2
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
Have you tried both keys?
penguin is offline
Old 07-08-2005, 05:40 PM   #3
Blurvfocus
Blurvfocus's Avatar
Fan#: 15299
What I Drive: 03 ZX3 Wine Cooled Eng.
FF Reputation: 54 Blurvfocus Excellent Standing Member
^-^ Good call, penguin.
Often wrong but never in doubt.
Blurvfocus is offline
Old 07-08-2005, 05:41 PM   #4
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
When the odometer changes to dashes, that usually means there is a problem with the Vehicle Speed Sensor. It also can have to do with the engine management system losing its memory.
That could be a reason why it won't start, the engine management system is pootched. Take it in to the dealership and they can reload it.
Usually when the odometer gets those dashes (when the car is running) the speedo drops to zero also which is cause to determine that the problem is the VSS.
I'm guessing your engine management is causing the problem. If the software is 'losing its memory' it could explain the instruments resetting on startup as well if that is the case, hard to know unless I was there.
Chad (S2)
S2 is offline
Old 07-09-2005, 07:04 AM   #5
03Z_ex_Three
03Z_ex_Three's Avatar
Fan#: 45
What I Drive: Liquid Grey 03 ZX3
FF Reputation: 1 03Z_ex_Three Good Standing Member
Pretty much the dealer is going to give you a bull shit run around and tell you that it is not a factory issue and make you pay for it.
The only time I dont like Bush is when Im at the "Y".
03Z_ex_Three is offline
Old 07-11-2005, 07:28 PM   #6
coyote2
coyote2's Avatar
Fan#: 25341
Thanks for the replies. It appears to be a problem with the "power hold" relay. Tapping the relay got the car going again. The dealer was pretty good at finding this quickly.
coyote2 is offline
Old 07-03-2013, 11:57 AM   #7
zetecfocus
Fan#: 96880
What I Drive: 2000 Silver ZX3
FF Reputation: 1 zetecfocus Good Standing Member
Question about Power Hold Relay
Coyote, where is the power hold relay? Secondly, how did this issue for you come about? Because my engine cut out one day while driving and then the dashes showed up on the odometer.
zetecfocus is offline
Old 05-14-2014, 02:34 PM   #8
freek
Fan#: 163346
What I Drive: 2003,blue,ford focus Zetec 1,6
FF Reputation: 1 freek Good Standing Member
Hi guys, it seems I got the same problem (for a long time) but now its pretty annoyng and car is barely usable when I cant rely on it.
Did you manage this problem? Its a long time with last reply to this problem?
to Chad (S2) - I got problem with vehicle speed sensor too, its replaced 2 year earlier and this problem is still occured (dashes on odometer when Im starting)
Thank a lot!
freek is offline
Old 05-14-2014, 03:09 PM   #9
zetecfocus
Fan#: 96880
My issue was due to a loose ground wire. I had a mobile mechanic come diagnose the car for 60$ bucks. He traced back all the connections from the fuse panels with an Ohm meter. I forget exactly which ground it was, however it was located near the battery. Looking at the front of the car, battery on your right; it was down the right side of the battery box in front of the strut tower(towards you). Basically, I'd say check all your connections and wiring which can be cumbersome.
Old 05-14-2014, 03:50 PM   #10
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,582, Level 53
Points: 6,582, Level: 53 Points: 6,582, Level: 53 Points: 6,582, Level: 53
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
Buy-Sell-Trade Rating: (23)
S2(Chad)hasn't been around here is quite some time now.
Hatch Nation #140
Caeci caecos ducentes
freemind is online now
