2005 ZX3 S model - wanting rear sway bar - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-06-2005, 10:25 AM   #1
Hexx
Hexx's Avatar
Fan#: 18117
What I Drive: 2005 ZX3 S
FF Reputation: 1 Hexx Good Standing Member
So I know theres a post somewheres over at FJ about this, and some guy rigged up his own way of mounting a rear sway bar...my question is, what do I have to do to get a rear sway to fit?
Ford has told me that as of Sept 03 til present, all focus rear sway bars are the same (im not talking about SVTs here). People have told me to drill holes in the cross member, others say dont do that, make a bracket...I dont know how the bracket is made.
I went to the dealer again to look at the cars there with the rear sway, but didnt get a good enough look at how its mounted.
Besides telling me "well why didnt you have the dealer install it when you bought the car" what should I do?
Hexx is offline
Old 07-06-2005, 10:31 AM   #2
Hexx
Hexx's Avatar
Fan#: 18117
So I found a picture...http://www.sportcompactcarweb.com/pr...scc_projfocus/
and Ill hop under my car later to see where the middle bracket holes are. I know the ones for the end links are there...its just the middle part.
Also, so anyone know of the end links size - length and diameter? If I cant find a couple, I wanna hit up the local stores for some poly.
Mods: MM CAI, Rear Poly Tranny Mount Inserts, SVT Dark Agent EAP Rims, Steeda STS, Progress Springs, SVT Leather Wrap Parking Brake Handle, and some clear corner side markers.
Hexx is offline
Old 07-06-2005, 11:44 AM   #3
bigal
Fan#: 21961
What I Drive: 2005 CD Silver ZX3
Points 403, Level 8
Points: 403, Level: 8 Points: 403, Level: 8 Points: 403, Level: 8
Level Up 6% Completed
FF Reputation: 1 bigal Good Standing Member
swaybar
I had the same problem on my 05 SE. Look in the Search forum for the user name overfocused on FJ post #2416640093 Feb 05 and he did a rear mount. I did the same thing on mine only made a little different. I'll explain in a pm if you wish. He has pictures of the install. The holes in the crossmember have nothing to do with the mount. The original mounts are welded on at the factory. Buying another crossmember is expensive. The SE and S unfortunately have been slighted as far as the rear bar is concerned. I mounted a Progress 22mm rear bar on mine and it works perfectly even autocrossing.. A front bar isn't really necessary. I also have the Eibach prokit.
bigal is offline
Old 07-06-2005, 04:38 PM   #4
Hexx
Hexx's Avatar
Fan#: 18117
yeah and I see from some pics that its welded...maybe ill just weld them in...or junkyard hunt for a crossmember.
Hexx is offline
Old 07-06-2005, 04:45 PM   #5
Hexx
Hexx's Avatar
Fan#: 18117
i def cant find his post....
Hexx is offline
Old 07-09-2005, 10:33 PM   #6
BlacKnight
BlacKnight's Avatar
Fan#: 23119
What I Drive: 2007 Black F150 STX
FF Reputation: 1 BlacKnight Good Standing Member
On the 05's, Uncle Henry has 2 different rear crossmembers. One is for with the rear sway bar, and the other, of course, is without. Guess which one I have (unfortunately). I'm just waiting for someone to total one and have a body shop buddy of mine help me swap it out.
Roger
I sell Ford, Lincoln, and Mercury vehicles one piece at a time.
Shadow may be gone, but I am still around from time to time!
BlacKnight is offline
Old 07-09-2005, 11:11 PM   #7
bigal
Fan#: 21961
Points 403, Level 8
Why you would go to all that trouble and money when you can do a bolt on like I posted before I don't understand. Try the bolt on and if you don't like it then you can do the new crossmember install. It never hurts to try. It cost me about $20.00 to fabricate my mounting bracket. Your choice of course.
bigal is offline
