Timing belt troubles on my ZX2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-27-2005, 01:02 PM   #1
xxltall
Fan#: 24631
FF Reputation: 1 xxltall Good Standing Member
Unhappy Timing belt troubles on my ZX2
Need some help with my 98 ZX2.
I replaced the timing belt and got something wrong. The motor stalls out easy and has no bottom end, itís all revs like a Honda. I checked all the timing marks before starting the motor and thought everything was cool. I checked the instructions with both the Hayes manual and the ones that came with the timing belt set. What can I do to fix this? Did I mess up the VCT some how? Any help would be great.
Thanks,
Rob
PS
I know this is not a Focus just asking for knowledge.
xxltall is offline
Old 06-27-2005, 01:15 PM   #2
PortugalFocus
PortugalFocus's Avatar
Fan#: 13418
What I Drive: 05 Saturn VUE 2.2L 5-Spd
FF Reputation: 1 PortugalFocus Good Standing Member
is there a misfire some where? check timing with a timing light. Go back and recheck the marks that the belt didn't skip a tooth and the helt is nice and taught. If you have no power down low it definately sounds like the timing may be too advanced or too retarded.
Zetec > VTEC
Shorty w/ HKS Filter / JBA Shorty Header / Ported TB / Early Style Intake Manifold/ Ractive 9 mm Wires/ Autolite Platinum Plugs/ 2.25" Mandrel Exhaust/ SCS Short Thow Shifter / Front Strut Bar
Focus Shop Cup Front Lip/ Painted Front Grille Signals / CF M3's/ De-Badgged / Focus Badges Over the Blue Ford Ovals
Panasonic / American Legacy / Stinger / Audiobahn / Q-Logic
But I traded her in......
PortugalFocus is offline
Old 06-27-2005, 06:26 PM   #3
crazymechanic
Fan#: 12900
What I Drive: 2003 SVT Focus
FF Reputation: 1 crazymechanic Good Standing Member
you probably didn't quite tension it properly so it skipped a tooth
crazymechanic is offline
Old 06-27-2005, 10:48 PM   #4
tension001
tension001's Avatar
Fan#: 2278
What I Drive: 2001 Infra-Red 5sp ZX3
FF Reputation: 1 tension001 Good Standing Member
there is no VCT to mess up, so rule that one out. Im going to guess your timing is wrong. I second checking it over with a timing light and making sure you tensioned the belt properly..
2001 Red ZX3 5spd
OBX 4-2-1 Race Header; Borla 2.5" SVT Catback; MAC Short Ram; FC 65mm TB; FC Race Shifter; Gear Concepts Aluminum Pedals; Painted Interior; SVT Front Bumper and grille
tension001 is offline
Old 06-27-2005, 10:53 PM   #5
SkaAddict
Fan#: 1690
FF Reputation: 69 SkaAddict Excellent Standing Member
Buy-Sell-Trade Rating: (6)
ZX2s have VVT on the exhaust side...its part of the emissions control system, they don't have an EGR system like we do as a tradeoff. Although I doubt that it would cause the problem you're describing, it might be something to look into.
SkaAddict is offline
Old 06-28-2005, 01:01 AM   #6
crazymechanic
Fan#: 12900
actually, if the timing procedure isn't followed correctly, the VCT will not work properly. the VCT depends on the pulley being in a certain position when it is tightened to the 0 degree times camshaft.
Old 06-28-2005, 08:27 AM   #7
xxltall
Fan#: 24631
Some more info and questions that can shed some light.
Yes this is on the ZX2 Escort not a ZX3 Focus. You guys seem to know more about the motor than most the other Ford small car guys and this is why I ask for your help. I have been trying every Form forum tiring to find the proper way.
Tension is correct. That is very easy to do I know that is good.
I thought I had all the timing marks set but the instructions had some different looking marks. I would like to find a way to verify the marks if possible.
I did turn the motor over by hand to see that I would not crunch a valve and it does run and does not show any sign of crunching, thank God.
Some people in the other forums have said to stick a screwdriver in cyl #1 and find TDC that way rather than using the marks.
When the motor is in TDC what should the cams look like? How can I tell if they are in the right spot?
How can I reset the VCT?
I sooo wish I had the money just to take it to someone to get it right but it really was not that hard of a job except for this problem.
Thanks,
Rob
xxltall is offline
Old 06-28-2005, 08:51 AM   #8
crazymechanic
Fan#: 12900
when the cams are properly lined up and the crank is at TDC cyl 1 compression, the intake cam should have the cylinder 1 lobes pointing toward the back of the car, and the exhaust cam should have the lobes pointing toward the front.
Old 06-28-2005, 05:38 PM   #9
j0hnZ
Fan#: 24163
What I Drive: 2001 Escort Zx2
FF Reputation: 1 j0hnZ Good Standing Member
Correct face the cam lobes facing apart. You should have gotten a cam alignment tool. There are indents on the cams opposite of the cam gears you stick the alignment tool there and stick the belt on. Of course after cylinder 1 is at TDC.
By the way their are a million zx2 sites all over the place. Check my sig for one of them.
www.bamachips.com
www.nwzx2.com
140whp/138wtq
j0hnZ is offline
Old 06-28-2005, 05:43 PM   #10
crazymechanic
Fan#: 12900
there's actually two timing tools, though if you're real careful you only need one. one is the cam alignment bar, the other is a crank TDC peg. you remove a blanking plug from the block and put the peg in and turn the crank over until it hits the peg. now you're at cyl 1 TDC
