Old 10-15-2007, 01:50 PM   #51
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Memberpenguin Excellent Standing Member
> newer cars all have this problem not just ford focus
Correct, but the Ford Focus has this problem much, much more often than most new cars.
Which is why Ford changed the design in 2005.
penguin is offline
Old 10-16-2007, 01:27 AM   #52
knoxrocks222
Fan#: 38601
What I Drive: 2003 black svt
FF Reputation: 3 knoxrocks222 Good Standing Member
new ignition cylender 438 bucks with 2 new ford keys
knoxrocks222 is offline
Old 11-25-2007, 06:27 AM   #53
nahoul
Fan#: 51790
What I Drive: 01, blue ZX3
FF Reputation: 1 nahoul Good Standing Member
Hi, how soon can i get the IC?
nahoul is offline
Old 12-04-2007, 08:46 PM   #54
the_helepolis
Fan#: 52012
What I Drive: 2004 Midnight Blue
FF Reputation: 1 the_helepolis Good Standing Member
You can Unlock the steering wheels telescoping adjustment thing and sometimes that gives you enough give to turn the wheel left and turn the key. Also the tapping the key with a hammer gently works as well, and definetly worth trying before getting your car towed.
the_helepolis is offline
Old 12-11-2007, 11:55 PM   #55
bdewayne
Fan#: 52203
What I Drive: 2002 Blue ZTS
FF Reputation: 1 bdewayne Good Standing Member
My iginition was just replaced by a locksmith for only $220. Ford wanted between $500 & $600. Only problem is that my ignition wouldn't freeze it just won't let the key come out, but it will still start and turn. Any ideas on why this would happen? Oh and btw...the ignition is BRAND new and the key is still stuck in there at this point in time.
bdewayne is offline
Old 01-03-2008, 03:45 PM   #56
john29
Fan#: 52599
What I Drive: 2005, grey Focus
FF Reputation: 1 john29 Good Standing Member
I seem to have a slightly different problem. I could start the car but couldn't remove the key. After taking the cylinder out, I could easily remove the key. It seems that the part that recesses a little inside the column isn't going in so I can't remove the key. In other words, I can take a screwdriver and start the car after the cylinder is out and easily take the key out of the cylinder. When I put the cylinder back in with the key, I can start the car and turn the car off, but not turn it far enough to the left (past the indentation) to remove the key. Any help? Will the new type cylinder work?
By the way, great instructions. Thank you!
john29 is offline
Old 01-08-2008, 05:14 PM   #57
acerbis
Fan#: 52719
What I Drive: 2001 silver se
FF Reputation: 1 acerbis Good Standing Member
help
i need a replacement ignition. can someone give me a call or email me please. I tried pm but it didn't work. rerrett@hermanweissker.com or 760-964-2024 thanks
acerbis is offline
Old 02-11-2008, 01:10 PM   #58
nacnudv8
nacnudv8's Avatar
Fan#: 52725
What I Drive: former owner:Pitch Black '03 SVT 3D
FF Reputation: 7 nacnudv8 Good Standing Member
try this BEFORE you drill - it may work if your key won't turn
I called an auto lock-smith last year and he showed me a good tip. If the key will not turn to the first position (needed I think to take the cylinder out) then he made a regular non-PATS key copy, snapped off the "handle" end and put it into a hand drill like a drill bit. He set the hand drill to a low torque or to "hamer" (to make the key really viabrate) and put the key in the hole and turned on the drill. It makes that viabration noise a hand drill does when the torque is reached and the key then turned!
All the rest was easy and no drilling was required to get the lock out
nacnudv8 is offline
Old 03-04-2008, 05:58 PM   #59
bruinsh
bruinsh's Avatar
Fan#: 18989
What I Drive: 2003 black ZX3
FF Reputation: 1 bruinsh Good Standing Member
i had mine lock up totally and the way i got it moving again was with a rubber mallet. It created enough vibrations that the tumblers went back into place and the key worked enough so i could get the cylinder out. Try this before taking to a dealer!
Also can a admin make this a sticky thread since this is such a big problem with the focus?
bruinsh is offline
Old 10-13-2010, 10:07 AM   #60
cwpc
Fan#: 58782
What I Drive: 2002 Twilight Blue Ford Focus LX
FF Reputation: 1 cwpc Good Standing Member
i just sent B16 a PM - my car has been sitting for 2 weeks since i cant get it started and my dad wants his truck back soon, so i am hoping he still offers the Ic's so i can get my car started
cwpc is offline
