throttle body position sensor - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus First Generation > ZETEC Performance (2000-2004)
Old 06-16-2005, 09:29 PM   #1
crobro24
crobro24's Avatar
Fan#: 1684
What I Drive: 2003 Focus zx5
FF Reputation: 1 crobro24 Good Standing Member
i have a 2003 zx5 5 speed i bought the fc 65mm tb now i have a tps off of a junked focus i wanna set the sensor up with the tb what are the if anyone has the resistance readings between closed fully open or whatever what is involved with that...so i can get stock readings help thanx!!
crobro24 is offline
Old 06-17-2005, 08:42 AM   #2
elitekorri
Fan#: 10376
What I Drive: 2004 ZX3 5 SPEED
FF Reputation: 1 elitekorri Good Standing Member
Are you just trying ot get readings or are you trying to install the new TPS on the new 65mm tb?
elitekorri is offline
Old 06-17-2005, 09:00 AM   #3
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Curious as to why you need those readings? All you have to do with a aftermarket TB install is of course install the thing, put the TPS in the correct holes on the side of the TB and do an ECU reset, that's it.....
Chad (S2)
S2 is offline
Old 06-17-2005, 09:23 AM   #4
elitekorri
Fan#: 10376
that's what I was thinking... I didn't understand why the original TPS wasn't installed (unless it was broke... I broke mine onces... TPoS) hehe
Old 06-18-2005, 01:06 PM   #5
crobro24
crobro24's Avatar
Fan#: 1684
ok i have the tps and the throttle body i would like to put the tps on it now so i dont have to worry bout it later and get it all properly set up...will the tps from an auto focus work a sensor is a sensor my focus is a 5speed 2003...and when the tb is closed what is the resistor reading 0ohms or should it be a differnt number?
crobro24 is offline
Old 06-18-2005, 02:15 PM   #6
Kicknzx3
AKA Toyotech
Kicknzx3's Avatar
Fan#: 9
What I Drive: A few
FF Reputation: 1 Kicknzx3 Good Standing Member
Buy-Sell-Trade Rating: (4)
...shouldn't be ohms at all...should be volts. just like the maf you run through a 0-5volt range. at idle you will see from .50-1.0 or so.
i don't get why you need this information, its not like you are drilling the throttle body for the correct location and then fitting the tps
2012 Toyota Camry SE
2012 Chevy Cruze LT/RS
2006 Ford Escape XLE V6
1991 Ford Mustang LX/5.0
Kicknzx3 is offline
Old 06-19-2005, 03:24 PM   #7
crobro24
crobro24's Avatar
Fan#: 1684
never mind the auto tps dont fit...it is a resitor in the tps and it registers weather the plate is open or closed or whatever to the ecu....i would be drilling into the tb...only enlargining the holes in the tps oh well....thanx anyways
crobro24 is offline
