Sponsored by Tire Rack
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack
Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, suspension issues and more.
Sponsored By:
Tire Rack
Old 01-05-2004, 01:48 PM   #1
djpopeye
Fan#: 2468
FF Reputation: 1 djpopeye Good Standing Member
Exclamation Broken Caliper Bolt
Requesting help here...
While attempting to change out the brake pads, I was trying to remove the bolt on top of the driver side caliper (the 18mm one) and broke the head off the bolt. I tried everything in the world (dremel, drill bits, etc.) to get the bolt out, but no luck. The bolt is still in the chamber. So I removed the bolt on the passenger side. I can't see that it does anything. It doesn't appear to connect anything. In fact, you don't have to remove it to remove the calipers and pads, although I'm sure you pro's already knew this.
So my question is: what is this bolt for? and, do I need get it fixed (i.e., is it safe to drive)? My Focus is the stripped down, no power anything, non-zxe version, auto transmission.
Thank you for you help,
DJ
djpopeye is offline
Fan#: 1
Old 01-05-2004, 02:04 PM   #2
whiteboyslo
whiteboyslo's Avatar
Fan#: 180
What I Drive: 04 Pontiac GTO - Yellow M6
FF Reputation: 2 whiteboyslo Good Standing Member
Buy-Sell-Trade Rating: (11)
was wondering the same thing when i did mine. you're right. it doesn't need to come out to do the brakes. what it does... dunno. you might wanna run down to the hardware store and buy an easy-out set to remove what's left of the stud.
Mike
just visiting now....
whiteboyslo is offline
Old 01-07-2004, 06:49 AM   #3
djpopeye
Fan#: 2468
I did as you recommended, but couldn't get it out. The bolt is reversed and the set wouldn't work. I still don't know what that bolt is for. I 'm sure that someone on these forums knows. Surely someone has a Haynes or Chiltons. Otherwise, I guess I will have to pack up my pride and head down to the dealership and ask.
djpopeye is offline
Similar Threads
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 10:54 PM
Will it fit? CheckMyVitals MK1 Focus 14 08-12-2005 02:55 PM
caliper bolt size kbkmonoxide General Technical Chat 4 07-26-2005 10:00 PM
Bolt broken off into head! Man! ampedout General Technical Chat 12 05-08-2005 08:09 AM
Help, broken header bolt!!! Assasin Ford Focus & General Car Chat 18 11-28-2003 12:46 AM
