2005 focus and alarm trunk problems -solved - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-05-2005, 08:45 PM   #1
spudgunman
Fan#: 3952
What I Drive: 05 ST Black on Black
FF Reputation: 1 spudgunman Good Standing Member
dont know if you have this same issue. i had my alarm using the negative pulse form the light in the trunk for the trunk release ground pulse.
my problem - the alarm woudl go off after 30 minuets when everythign was closed, doors etc.
my fix - put a relay in line with the light to flop the negative pulse with the positive from the light then the relay throws the trunk sense wire
cause - after relashing the ECU from the dealer somethign in the new ECU code will send out a pulse ever 30 seconds to make sure that the doors and trunk is closed and the lights are off.
in my install i had no issues with other door or hood sensors, but the same fix can be applied to any source. i think it has somethign to do with the powersaver circut in the 2005. anyway problem solved if you have same issue frustration.
My Car Site Wire Diag Help My CarMy Sub Box
___
Current FAQ: OEM SUB
spudgunman is offline
Old 06-06-2005, 03:23 PM   #2
SQFocusZTS
Fan#: 4729
What I Drive: 2000 Focus ZTS
FF Reputation: 2 SQFocusZTS Good Standing Member
Fords are known for this problem. never seen it in a focus before... Taurus, Explorers/F-x50s.... the car's ECM will 'check' these triggers by pulsing them...
pretty sure two diodes would've solved the same problem, but a relay works too! good job.
-john
SQF
John
SQFocusZTS
Certified MASTER Installer
one of 72 in the world...
SQFocusZTS is offline
Old 06-06-2005, 04:13 PM   #3
spudgunman
Fan#: 3952
yea same here i had the diode isolation and it still wouldnt fix it which was why i posted this relay trick i had to do.
yea same as you said the other cars i seen this. when i bought my focus it didnt do it. when i upgraded the ECU to the B36.12 and higher or B37.3 and higher. is when i noticed it.
thanks for the feedback!
___
