Old 06-05-2005, 07:49 AM   #1
xFOCIx
Fan#: 23553
What I Drive: 2005 ZX3 5spd
FF Reputation: 15 xFOCIx Great Standing Member
Matched rev = easier to push shifter into gear?
Is it just my perception or is it easier to get the shifter into a lower gear when I match the revs even with the clutch pushed in?
Let's say I'm going 35mph and I want to shift into second. I have the clutch all the way in first. I can shift the lever into 2nd but with quite a resistance. If I rev the engine up to right RPM with the clutch in, the lever seems to go into 2nd with less effort.
Is this just my perception? I really don't get why it can be anything else, because I think the transmission is hooked up directly th the drive-train while the engine and transmission are isolated by clutch. I can' t see why the transmission would care what RPM the engine is when the clutch is disengaged.
xFOCIx is offline
Fan#: 1
Old 06-05-2005, 10:26 AM   #2
hEaT
Fan#: 20699
What I Drive: 2013 Oxford White Focus ST
FF Reputation: 11 hEaT Great Standing Member
Yea, it does. I've noticed that with any standard car I've driven. Maybe it has to do with the synchros?
ZETEC Crew #49
Originally posted by DrkKnight614
......hmm if that works then if i put a spinner on my butt hole and rip one will i be able to run faster. ...idiots
hEaT is offline
Old 06-05-2005, 10:43 AM   #3
I Nvr Wn
I Nvr Wn's Avatar
Fan#: 16109
What I Drive: 2002 Liquid Gray ZTS 5/sd
FF Reputation: 1 I Nvr Wn Good Standing Member
its because of the rev matching that makes it easier, rev matching is an alternative to heel toe esp. for guys like me who are 6'4'' with size 13 shoes....hell toe is not a poss.
Now: FS UDP, AEM SR intake, Eibach Sportline Springs, Focus central Race Shifter
Inside: Kenwood KDC-MP628 headunit, Aluminum A/C Knobs, Aluminum Focus RS shift knob
Have you ever worked with an ERP or CRM software? If so let me know!
I Nvr Wn is offline
Old 06-05-2005, 11:42 AM   #4
xFOCIx
Fan#: 23553
I don't understand why though. If the engine is ISOLATED, how would the transmission know what the engine's rev is?
xFOCIx is offline
Old 06-05-2005, 02:01 PM   #5
RS3RS
RS3RS's Avatar
Fan#: 19416
What I Drive: 2003 Black ZX5 SVT
FF Reputation: 1 RS3RS Good Standing Member
That doesn't make sense to me... It would be easier to put into gear if you were double clutching, but with the clutch in the whole time it doesn't make sense...
RS3RS is offline
Old 07-01-2005, 03:49 AM   #6
tricker_luke
tricker_luke's Avatar
Fan#: 24102
What I Drive: 2001 State Blue 1.6 Zetec
FF Reputation: 1 tricker_luke Good Standing Member
ye, i had a packet of peanuts the other day which had this as a tip, saying to rev to the number of the gear you want to shift into to make it smooth, e.g 2000 revs for 2nd gear, 3000 revs for 3rd etc
tricker_luke is offline
Old 07-01-2005, 12:58 PM   #7
BornAgainFordOwner
Fan#: 9408
What I Drive: 2004 Liquid Grey ZX3 PZEV 5Sp.
FF Reputation: 7 BornAgainFordOwner Good Standing Member
My guess would be that there is enough drag on the clutch disk even with the clutch depressed that the transmission input shaft will try to keep up with the engine rpm increase so that the synchronizers have a little less work to do to match the input shaft speed with the new speed of being in 2nd gear.
BornAgainFordOwner is offline
Old 07-01-2005, 10:44 PM   #8
junehhan
Fan#: 23769
What I Drive: 2004 Screaming Yellow SVT
FF Reputation: 1 junehhan Good Standing Member
Post
Matching rpms, and even double clutching when downshifting 2 or more gears is something that would be good to learn. What you are experiencing is completely normal. It takes a little practice, but double clutching would help greatly to extend the life of your syncros, and your transmission in general, as well as probably your motor mounts.
2004 Screaming Yellow SVT Focus
-European appearance package
2005 Light Tundra Blue Focus ZX4
junehhan is offline
Old 07-02-2005, 07:17 AM   #9
tricker_luke
Fan#: 24102
what is double clutching?
Old 07-03-2005, 03:02 AM   #10
SkaAddict
Fan#: 1690
FF Reputation: 69 SkaAddict Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Double clutching is where you let the clutch out and put it back in between neutral and the gear you're selecting. You used to have to do in in non-synchonized gearboxes unless you were really good with rev matching, and AFAIK some big rigs still require it when skipping multiple gears.
There's also a "ricer" term that denotes dropping two gears (e.g. 5th to 3rd) for quick acceleration from a roll.
SkaAddict is offline
