Car audio know-it-alls: what is a non-fade output? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-31-2003, 11:10 PM   #1
SVT4ME
Fan#: 61
FF Reputation: 4 SVT4ME Good Standing Member
Okay, so I finally got my Nakamichi HU installed - I gave up and took it to a specialist in the area. It works, most importantly, and they didn't mess up the stereo or dent the car so I'm happy. But I noticed the sound from the factory sub is no longer the same, the stock factory head unit produced ONLY low frequency sound from the sub, whereas now I can hear mid-range sounds leaking into the sub's sound.
The work order says the installer wired the sub to a non-fade output on the deck. So, what exactly does that mean? Is there a practical way for me to "filter" out the higher-frequency sounds from the factory sub? Sorry this is probably painfully obvious to most but me not know much about car audio...
SVT4ME is offline
Old 12-31-2003, 11:19 PM   #2
Sublime
Fan#: 192
What I Drive: 02 Focus ZTS, 02 Escape V6, 80 Turbo T/A
FF Reputation: 1 Sublime Good Standing Member
Buy-Sell-Trade Rating: (14)
A non-fade output is an output that cannot be faded to either the front or the rear. Most sub outputs from an HU are non-fading.
Sublime is offline
Old 01-01-2004, 01:09 AM   #3
SVT4ME
Fan#: 61
Okay, well that makes sense then. What I don't understand now is the "leaking" of the higher-frequency sounds. If the sub is hooked up to the sub output on the HU, shouldn't it be "filtered" so that only frequencies low enough for the sub are going to it?
SVT4ME is offline
Old 01-01-2004, 03:08 AM   #4
guerro
guerro's Avatar
Fan#: 339
What I Drive: 2013 Focus ST Oxford White
FF Reputation: 1 guerro Good Standing Member
It may be a full frequency output. Or, the installer may have bypassed the crossover in the sub. Where is the crossover for the factory sub ?
Annoy a Liberal: Work hard, succeed, be happy.
guerro is offline
Old 01-01-2004, 03:22 AM   #5
SVT4ME
Fan#: 61
I don't know. I suspect that it was (is) built into the factory HU. The Nak HU has a dedicated sub output, but maybe the installer didn't connect to that... Some day when I have more money I'll probably just go back and replace the stock sub anyway.
SVT4ME is offline
Old 01-01-2004, 03:55 AM   #6
guerro
guerro's Avatar
Fan#: 339
Well, the sub isnt going to last long playing full frequencies. Might be okay as long as you dont turn it up to high.
guerro is offline
Old 01-01-2004, 02:29 PM   #7
sa_pyro_ne
sa_pyro_ne's Avatar
Fan#: 1437
What I Drive: 2000 Ranger V6 4.0L 4x4 XLT Ext Cab
FF Reputation: 4 sa_pyro_ne Good Standing Member
you could put fmods on the rca's if the hu or amp has no crossover
http://www.partsexpress.com/pe/showd..._ID=6766&DID=7
i'm not familiar with the factory sub but i think it has rcas going to the amp, otherwise you could use other 2-way crossovers on partsexpress.com, playing frequencies over 120 hz is generaly harmful to the sub so it's something you definately need to get fixed.
- Scott
sa_pyro_ne is offline
Old 01-01-2004, 05:18 PM   #8
DidHeFocus?
Fan#: 1704
What I Drive: 2003.5 ZTW PZEV
Points 26,532, Level 97
Points: 26,532, Level: 97 Points: 26,532, Level: 97 Points: 26,532, Level: 97
Level Up 19% Completed
FF Reputation: 1 DidHeFocus? Good Standing Member
Why would this be harmful to the sub?
It would only use up extra power and not sound right.
Playing lower frequencies in tweeters could be harmful though!
The stock head unit's sub out is extremely filtered from higher frequencies, so the stock sub amp probably has no filter for highs and relies on the head unit for it.
Maybe the Nakamichi deck's crossover is adjustable, check the manual.
I'm a middle aged guy, with a middle school mind.
DidHeFocus? is offline
Old 01-01-2004, 11:21 PM   #9
sa_pyro_ne
sa_pyro_ne's Avatar
Fan#: 1437
playing higher frequencies than the sub can play is very harmful actualy. the frequncies it can't play are "used up" by giving it off as heat on the voice coils which can fry them, also, more distortion is created when playing those frequncies around 140 that are border-line that it can sort of play, and distortion creates heat, that why you should never play a sub over 120hz.
- Scott
Old 01-01-2004, 11:53 PM   #10
SVT4ME
Fan#: 61
Huh. Sounds like I might want to fix that soon then. I had already started looking at the F-Mods, I think that would do the trick. Is there anything else that I could use to do the job, like instead of an inline crossover? The sub out cord is RCA, but I can't see the end of it, so I don't know if they cut the RCA plugs off to tap into the wires or what - the factory sub connector was (is) most definitely not an RCA connection. I don't think the deck has any kind of crossover or filter built into it?
SVT4ME is offline
Similar Threads
State Car Audio Laws dcbassdc Car Audio, SYNC, MyFord Touch & Electronics 14 06-12-2006 11:03 AM
Car Audio F/S scoobasteve Archive 2 06-02-2006 11:31 AM
YOU may be a ricer John Ford Focus & General Car Chat 66 09-13-2005 09:50 AM
Aussie Cleaning whippet_zetec Auto Washing, Detailing & Paint Protection 1 09-28-2004 08:32 AM
Car Wash... Megamanx907 Auto Washing, Detailing & Paint Protection 3 10-20-2003 03:03 PM
