Timing Belt Info - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Closed Thread
Old 04-28-2009, 09:48 PM   #11
jsanta
Fan#: 64729
What I Drive: 2000 Ford Focus
FF Reputation: 1 jsanta Good Standing Member
2000 Ford Focus
How do you remove the Rear Cam Plug from the cylinder head in order to remove the Cam Shaft. This is the last step in removing the Shaft but the manual does not say how it just says remove.
jsanta is offline
    Quick reply to this message
Old 04-29-2009, 10:26 AM   #12
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
^^ You should start your own thread instead of resurrecting an old one. People who have the answer might get confused.
I'd also strongly consider posting in the SPI performance- although this is tech related- you're likely to find a better and quicker answer in the SPI forum.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 09-30-2011, 11:44 PM   #13
GoldenRod
Fan#: 90406
What I Drive: 2002 Gray ZX3
FF Reputation: 1 GoldenRod Good Standing Member
I thought I needed to adjust my timing because of a diagnosis a mechanic gave me. They thought it had jumped timing. This guide was very helpful for me to get up the nerves to dive into this.
After taking the top cover off and seeing the teeth on the belt were fine I figured it hadn't really jumped timing.
I saw the serpentine belt was cracked and needed replaced. Once I took the belt off I was able to check all the pulleys. The AC pulley was completely siezed up. That was what was causing my VERY slow labored cranking. I got a replacement from pick n pull, replaced the serpentine belt and it started right up.
While I was in there I replaced the shot motor mount as well. My car had been having very high vibration problems and I had even had a mechanic tell me the motor mount was fine. The rubber was completely separated and had no dampening at all. My car is running smoother than I ever remember it running. I sometimes even think it's died at stop lights or when I'm parking.
I also just recorded a new personal MPG record for my car @ 36.8 mpg. I still need to switch to synthetic oil and change my manual transmission fluid to something better. I don't think it's ever been changed.
GoldenRod is offline
Old 09-30-2011, 11:54 PM   #14
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,703, Level 94
Points: 23,703, Level: 94 Points: 23,703, Level: 94 Points: 23,703, Level: 94
Level Up 36% Completed
Forum Activity 17%
Activity: 17% Activity: 17% Activity: 17%
that's good to hear. this is a pretty old thread, I think we should lock it now but glad to hear it worked out for you and welcome to FF :)
mikebontoft is online now
Closed Thread
Similar Threads
"How To" VCT Trouble-TSB 03-6-07 Springbuck SVT Performance (2002-2004) 26 08-18-2009 02:21 PM
2002 1/2 zx3 timing belt removal With a twist not the same as most of the other cars Knuckles899 General Technical Chat 4 03-11-2007 04:34 PM
timing belt and tensioner installman General Forced Induction 5 02-15-2006 09:41 PM
Timing Belt help TheRedZTS General Technical Chat 1 07-20-2005 10:54 PM
timing belt withering away *w/ pics* bartlomiej ZETEC Performance (2000-2004) 34 04-02-2004 10:50 PM
